ThorFire JM07 Mini Review and Tear Down
A little while back I received a ThorFire JM07 from a ThorFire giveaway. I thought that I would share my thoughts about it.
It can be purchased from ThorFire & More (ThorFire Direct).
ThorFire CREE LED Flashlight 4 Modes Powered by 26650 Battery
Product Description:
ThorFire JM07 is a flashlight with 4 modes: High/Mid/Low/Hidden Strobe.
Flashlight Description:
Brand: ThorFire
Condition: Brand new
Uses Cree XM-L2 LED with a lifespan of 100000hours.
Uses one 18650/26650 3.7v battery.
Size:approx 146mm(length)*32mm(body diameter)*43mm(head diameter).
220-Gram weight (excluding the battery).
Tail tap switch for on/off and middle switch for mode selection.
Made of Aircraft-grade Aluminum.
High -effciency reflection lens.
Accessories: Lanyard, spare O-ring, lens, switch.
Package include
1 x flashlight
We stand behind our products with a 2 year warranty - if you are less than completely satisfied, we will make it right.
Guaranteed by eachine.com! Replacement or money back guaranty!
PROS:
The price!
Very well packaged in large box with lots of foam.
Excellent machining and a smooth unblemished black satin finish.
Clean cut threads.
Knurling feels good in my hand.
Forward click rear switch that can be used momentarily.
Disco mode is hidden.
Can tail stand.
Comes well lubricated.
Comes with spare lens, switch, o’rings and switch boot.
CONS:
None!
I wonder if this driver has any mod potential. :evil:
Conclusion:
I’ve come to the conclusion that the ThorFire JM07 is a very nice quality flashlight. I liked it so much that I bought another one for my grandson when they had it on sale for the awesome price of $9.99!!!
I don’t have any beam shots to show right now. When compared side by side with a ThorFire C8, the ThorFire JM07 has a softer hot spot. I’ll have to swap out the OP reflector with a SMO someday to see if there is any difference.
