Test/Review of LiitoKala Lii-100
LiitoKala Lii-100
LiitoKala has made a couple of analyzing charger, but this model cannot do any analyzing, it is a small universal charger that handles 3 types of LiIon and NiMH, it addition to this it can also work as a power bank.
The packaing was very simple, being just a plastic bag.
The pack contained the charger and a usb cable.
The charger is powered from micro usb and has a full size usb connector for power bank output.
The charger has two red leds to show selected current and four blue leds in a row to select voltage and show battery level.
The button has multiple functions:
When a battery is put into a powered charger, it can be used to select LiIon voltage (NiMH is selected automatic).
When charger is powered a long press (2 seconds) will change between 0.5A and 1A charge current.
A fast click when charging will show the selected battery type.
When used as a power bank a press on the button will turn the usb power on.
The charger uses the typical slider construction, it can handle batteries from 33mm to 70mm.
The charger can handle 70mm long batteries, inclusive flat top cells, this means most protected cells.
Measurements charger
  • LiIon and NiMH Batteries will be discharged with 0.1mA when power is off.
  • Charges LiIon batteries with 0.5mA when connected to power.
  • Charges NiMH batteries with 2.2mA when connected to power.
  • When battery is 0 volt the charger will charge with 3mA, this is enough to reset a protection.
  • From 0.25 volt on the battery the charger will reconize it and start charging.
  • Between 0.25 volt and 1.6 volt a battery is assumed to be NiMH.
  • Between 1.6 volt and 2.2 volt the charger will charge with less than 2mA and not allow selection of battery type.
  • Above 2.2 volt a battery is assumed to be LiIon.
  • Charger will not restart if battery voltage drops.
  • Charger will restart charging after power loss, or battery insertion.
Charging 4.20 volt LiIon
The charger has a fine CC/CV voltage charge curve, it starts reducing current a bit early, due to voltage constrains, this will give slightly longer charge time.
No surprise on these two cells.
Reducing the charge current to 0.5A works fine, except the termination current is not reduced (Cells will miss the last few percent of the charge).
With this older cell the current reduction starts very early as expected.
Good charging on these smaller cell, again the higher termination current means a few percent loss in capacity.
Adding a resistor in series with the usb power supply to simulate a long cable or weak supply did not prevent the charger from doing a good job, but it needed some more time.
M1: 32,4°C, M2: 31,4°C, M3: 40,0°C, HS1: 48,8°C
The charger needs some time to start up, this is because it is waiting for voltage selection.
There is no problem with changing current while charging.
Charging 4.35 volt LiIon
The 4.35 volt charge works as expected.
Charging 3.60 volt LiIon
Both LiFePO4 cells is charged fine, but the voltage is a bit high (This is not a big problem with LiFePO4).
Charging NiMH
This is a fine NiMH charge with voltage termination and no trickle charge.
When using voltage termination without a top-off charge the batteries will be slightly below full capacity.
Using 0.5A charge current is also stopped on voltage termination.
On this cell it looks like a voltage termination.
Here it is -dv/dt termination.
My new powerex cell is stopped on -dv/dt.
The AAA cell is stopped on voltage.
Fast detection of a full cell, this is voltage termination.
M1: 35,4°C, M2: 34,2°C, M3: 41,9°C, HS1: 53,5°C
The charger is also slow to start with NiMH, but it is not possible to select any other battery type.
There is no problem with changing current while charging. The charger uses the typical pulsing, where it can measure voltage with current off.
Power bank
  • USB output will turn off after 10 seconds with less than 65mA load.
  • When input power is applied, usb output will be off.
  • Mode button can be used to turn usb output on.
  • USB output is coded as usb charger (DCP).
USB output can deliver 1.3A before it starts dropping, the overload protection first kicks in at 2A.
Running with 0.5A load looks very good.
1A output also looks very good.
The noise is fairly good at 0.5A load with 20mV rms and 170mVpp
At 1A the noise increases, but is still acceptable with: 38mV rms and 310mVpp
Conclusion
It looks like this model often is a bit high in charge voltage, but within allowable tolerances. I did not see any problems real with it.
This makes it a good charger for all supported batteries and also a good power bank.
Notes
Read more about how I test USB power supplies/charger
awesome! thanks for the review. Glad I bought a few and they are very good.
Thanks for the detailed review. Informative as ever. Been waiting for it
:bigsmile:
Thank you for this review!
Great information posted when promised
thanks for all your good work
cheers
Nice review hkj, and a nice little charger too. Can’t believe it was delivered without a wrap of padding round it, some have got to get damaged in transit, surely.
Thanks for another good review.
Thanks HKJ, I had bought a couple of these but was waiting for your review before I used them :slight_smile:
Amazing, thank you HKJ!
You didn’t talk about the battery SOC indicator. Is it accurate for both Li-ion and NiMH?
Thanks again.
They are usual not very precise and the Lii-100 is very bad with NiMH, it basically stays on the last led all the time.
Time to give my Miller ML102’s away since the Liito can also charge NiMH, especially since the ML102’s seem to be dodgy when new versions come out.
Thanks HKJ
Amazing charger, considering the price/function.
I also love this charger, because of its quality for the money, and because it is EASY TO MOD for other charge currents and charge voltages.
Thanks HKJ for another excellent review. I’ve been watching this model and after seeing your review above it looks to be a good purchase.
Another great one HJK! I'll get a few of these for our vehicles. Just-in-case.
Never can have too many chargers I always say...
I’ve been using and testing 2 of these chargers for the past 4 weeks.
As is visible in HKJ’s review, the Lii-100 has one problem: it generally charges about 50mV to high. This ist certainly not dangerous, and within most battery’s specifications, but still less than perfect. However, it can be solved by an easy resistor mod. There is a thread about how to do this.
Great, thank you for that. I'll look around and see if I can find that thread...
Thanks HKJ
Another great job truly appreciated.
