It was a love at first sight since it was introduced and I knew I have to get my hands on this flashlight. First one I bought was JM35 with the side switch and that one turned out to be a disaster. Drivers retaining ring was glued so hard and full of aluminium debris to the point that it was impossible to unscrew without ruining the body. Eventually I hacked the head in half and called it a day. At least I saw how it was built. So disappointing, I'm sure many modders here can relate to this.
Aftermath:
After a month I decided to pull the trigger on JM30, pretty much the same flashlight, but with a few differences that should make disassembling much easier. The only downside is there is no side switch.
So, shall we begin?
Project cost:
- JM30 (Banggood) - $39,59
- Vappower 26650 Batteries (Banggood) - $19,80
- LD-2 Driver 6V 7A (led4power) - $15,00
- MT-G2 16mm MCPCB (Intl-outdoor) - $2,00
- Other supplies (wires, copper, screws, thermal paste, switch, sand paper etc.) - $25,00
1. Before mod (214 grams without batteries)
2. MCPCB (32 mm) removed, 50 mm total inside diameter.
3. Drivers cavity. Brass retaining ring seems to be holding the driver. At this point I don't know if it is screwed, glued, press fitted or soldered.
4. Blowtorch treatment. The soldered brass retaining ring was there to make a better contact with the battery tube. The driver was glued to the body.
5. LD-2 in very shallow (5 mm) drivers cavity. How to fit a 17 mm driver in a 29 mm hole? There is no room for a simple piggyback.
6. Three 1 mm copper plates cut and drilled. Two holes are 17 mm and one is 15 mm.
7. Soldered together.
8. Made another 1 mm copper plate with 15 mm hole. I'll use it as a lid.
9. It is a very slow process using hand tools only…
10. Done! Drivers pill, retaining ring and a small heatsink.
11.No soldering, gluing or potting needed to install the driver. Perfect fit and excellent ground contact.
12. The other side. This should provide enough heatsinking for the mosfet.
13. Drivers pill is going to be very lightly glued to the body with Fujik thermal paste. Just enough to hold it in place.
14. Inside the cavity.
15. Old driver, new driver.
16. Since this flashlight is going to be pushed hard at 7 Amps, heatsinking have to be done right. Two 1 mm copper plates soldered together.
17. Slowly getting there…
18. All done! It took forever to get this one filed, sanded and polished.
19. Heatsink ring is bolted down. It is a tight fit. Both surfaces are flat and lapped.
20. Another look…
21. Reflectors base is flat. It should make a good contact with the copper ring below. Aluminium reflector should provide additional heatsinking coming from the body of the flashlight.
22. Like this…
23. Bottom side…
24. MCPCB base. Three 1 mm copper plates ready to be soldered together.
25. Here we go again…
26. Almost done. Copper circle height needs to be sanded down from 3 mm to 2,5 mm.
27. Done!
28. Tightly bolted.
29. Copper ring bolted down on top of the copper circle.
30. Final look with 16 mm Noctigon in its place.
31. Another look.
32. Improving the switch. Forward clicky is going to be replaced with the Omten reverse clicky. Differences between these two switches are significant so a few changes had to be done.
33. Dremeling aluminium ring to gain space for new Omten switch.
34. Switch mod done. 18 AWG wires are soldered directly from the switch to the copper contacts (ring and spring plate). The original contact plate is bypassed completely.
35. The other side.
36. 5 mm x 20 mm copper rods. Eight pieces ready for soldering.
37. Perfect fit. At this point I'm stepping into the unknown. I have never done this kind of soldering.
38. Done. Copper rods are soldered to the copper ring. The bond is hard. It was a success after a few attempts. This should improve heatsinking and overall looks of the flashlight.
39. The other side…
40. Some cleaning (sanding and polishing) needs to be done to make it perfect.
41. Just how I like it.
42. Nice and shiny.
43. Another angle.
44. Copper rods exposed to air going trough cooling fins.
45. Bottom view. Looking good…
46. 54 mm copper pipe needs to be fitted inside 50 mm flashlight head.
47. Prepairing for soldering. Small gap needs to be filled with solder.
48. Done.
49. Sanded and polished. Final part is finished.
50. Parts ready for the final assembling.
51. At least some of them are going to visible from the outside.
52. Assembly day. Artic MX-4 thermal paste was added between all components.
53. The ring is a nice addition to the overall outside looks of the Shadow.
54. AR lenses.
55. Just to get a perspective of the size. Shadow JM30, Courui D01 & Convoy S8.
56. Exactly 123 grams of copper ready to sink the heat from the mighty MT-G2…
57. No words at this point…
58. Final photo.
Tailcap currents (freshly charged batteries):
- Moonligh – 20 mA (0.020 A)
- Low - 150 mA (0.150 A)
- Mid - 1420 mA (1.420 A)
- Hi - 7010 mA (7.010 A)
As You can see, LD-2 delivers. According to Djozz's charts, that should be just around 3500 Lumens when firing on all cylinders. I am very pleased with this driver.
Flashlight heats up pretty fast at 7 amps. In closed environment (room temperature around 23 degrees Celsius) it gets to 50 degrees in about 2 minutes (got it up to 70 degrees and then I stopped). After that test I took it outside (it was windy and colder and flashlight was still pretty hot from previous test) and it didn't get above 60 degrees at full throttle. So environment makes a huge difference.
I'll try to make some beamshots later.
I always wanted a powerful MT-G2 flood flashlight and this one covers everything. Nice tint, decent throw, excellent flood, good heatsinking and beautiful looks. Overall, a usable hot rod. I generally don't use flashlights as often as I would like, but there is something that drives me to buy and mod them. I'm spending a lot of time searching for the right host and much more time thinking what I can do with it. Does that makes me a flasholic? Bet Your ass it does.
Did You like my mod? Please comment. I will gladly answer all questions that you have. Cheers!
Holy smoke. I wish I had that talent. That’s form & function to the letter. The exposed copper thermal-path is simply stunning.
Very nice. Love the copper work. You gave me to much to think about , when I should be sleeping..
Really really nice work!
Beautiful copper work! May ask about your polishing method?
https://www.flickr.com/photos/akrylamid/sets/
Awesome! Well-done on the photo-documentation, too.
Looks like you kept the original reflector. Did you have to make any adjustments to get its focus right?
Rule 1-1 as it applies to life, take it as it comes.
Rouge no doubt, can tell from a mile away..
shockli great imr batteries
Excellent mod, really nice looking with that copper showing.
http://atvillustrated.com/files/logo.2013.yamaha.racing.blue_.jpg
I’m completely amazed by the ingenuity of this mod, the thoroughness and quality of everything you did and made with limited mostly hand tools, and the sheer amount of work that you have put into this! You made an extremely well done and great looking flashlight and thanks for writing it all down with so many great pictures!!
djozz tests translucent S2+ gaskets available for free
Amazing skills. Amazing mod. Beautiful. Thanks for sharing.
عُمَانْ
Excellent work Cula and all that copper, Wow
Let There Be Light
wow, amazing mod!
and what a beautiful result!
It is done when it is done
How my BLF Specials generally work, please read before asking Qs
The Q8, Exciting a groupbuy for a Premium BLF special high lumens soda can light!
The GT, A BLF special GIGA thrower
The FW3A, a TLF BLF special small, elegant, powerful triple
Lithium Ion safety 101 important read
Sorry grammarlovers, I am a real King Typo.
Jeeze. What a meticulously crafted light. Absolutely amazing, and beyond anything I have the patience for.
My YouTube Channel- Flashlight and Headlamp Reviews
Agreed. I would not have even thought of doing what he did. I have not seen a nicer custom light ever. And I’ve seen some rippers.
I don’t think I’ve seen that much copper work put into a single flashlight before. Simply incredible.
Bravo…. Can you make me one?
Just Wow… Amazing skills
-USB power meter/tester thread - YZXStudio, Power-Z, AVHzY, Kotomi, Ruideng
Tremendous ammount of handywork! Bravo
Thanks guys for your comments. It wasn’t easy but it turned out nice. I have few tweaks to do to make it perfect but nothing really serious.
Courui D01 -Mod ZY-T08 Small Sun -Mod Shadow JM30 Mod - copper edition Brinyte 158B mod - copper brass hybrid
Small sun ZY-T08 Mod II - The Next Generation Small Sun ZY-T08 Best Of Both Worlds Warsun X50 mod - a complete makeover
What a beauty! Lots of hard work! Congratulations!
Nothing fancy Mike C, just a lot of patience and work. Wet sanding paper up to 2000 and then plain polishing paste and buffer mounted on the drill or a dremel. I use polishing kit like this: http://www.ebay.com/itm/34Pcs-1-8-Soft-Felt-Polishing-Buffing-Burr-Wheel...
After polishing, copper is thoroughly cleaned with alcohol and I don’t touch it with bare hands anymore. I work in gloves because it prolongs the oxidation of the copper. These are just my observations which came from experience.
Yes, it is the original reflector. I’m not completely satisfied with focus at this moment. I think I pushed MT-G2 a bit far into the reflector and I need to lower it down. Maybe you guys can help me with this when you see a beam shot. I’ll point to what is bothering me and maybe you can suggest what to do. It is not that serious, just a small dim around the hot spot. It is not easy to explain so I’ll upload the photo later.
One of the most ingenious and well made lights I have ever seen!
Well done!
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
My Paracord Stuff
I agree with what everyone else has said. This would have to be one of the most amazing modded lights I’ve read about. Very very creative and perfectly executed. Even the pictures were beautifully done. Thanks for sharing and keep up the orsm work.
My current and or voltage measurements are only relevent to anything that I measure.
Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife.
djozz said "it came with chinese lettering that is chinese to me".
Can`t agree more with you guys above
That is a decadent amount of copper.
Stunning.
I always liked the usefulness of flooder and I think you might have set a new record for hitting the sweet spot for (cost, beauty, usability).
Good on ya mate.
For me I am wondering if more settings something like 2+ 4+ amps might also get some use?
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
Thank you Old Lumens, as I said before, You are one of the main reasons I started this hobby. BTW, I can't wait to see what You come up with Your Palight Boss. I am sure that everybody here misses Your crazy mods.
Some modes between would definitely be very useful but that's the way it is with LD-2. Never the less it is a great driver.
Wow, Cula! Not more I can add to what the others before me have said except that I agree with them wholeheartedly. Bravo!!
The Flashlight Forum (TFF)
The Vaping Forum (TVF)
https://docs.google.com/spreadsheet/ccc?key=0As
