BLF After Dark, CSS theme
146 posts / 0 new
ToyKeeper
ToyKeeper's picture
Last seen: 10 hours 38 min ago
I’m not really sure what’s up with userstyles.org lately. I checked it just now though, and it appears to be working normally. I did a search for “blf” and it returned several results including both of mine.
About hiding posts, it only needs one line per user. There’s no need to repeat the same UID more than once and if it’s only one person then only the last line is needed. The lines before that, ending in a comma, are optional in case people want to hide more than one person.
Or, instead of hiding people, it can be used to style posts on a per-person basis. For example, sb’s posts are usually important so I have those styled with a green banner and a bigger brighter font to make sure I’ll notice.
jon_slider
jon_slider's picture
Last seen: 3 hours 26 min ago
thanks for all the coaching
much appreciate the details including about the commas,
Next things I would like to learn
How to Hide, or enhance the text of,
1. A Thread, by its specific Title?
2. A Thread, started by a specific User?
I tried to google, but it was not, yet, enlightening
tutorial links, and handholding most appreciated
ToyKeeper
ToyKeeper's picture
I haven’t looked into styling thread titles in the list, but it likely would need selectors based on text content instead of class or ID or anything like that… so it may require really recent CSS features or javascript.
jon_slider
Stylus tangent, non blf
wanted to do hide the Animated Banner at the top of Netflix
this works for me:
.jawBoneContainer
{ display:none !important;
ToyKeeper
ToyKeeper's picture
It’s typically a lot easier to do this with an ad blocker plugin. Some have the ability to right-click on the thing you want to remove, select “hide this”, and then drag a slider to select exactly how much to remove. Same effect, but it only takes a few seconds.
jon_slider
thanks
I used adblocker to determine the .JawboneContainer label to use in Stylus, to hide the opening banner on Netflix..
have not learned how to use adblocker to block that particular animaterd banner element on Netflix
I do have all the banner ads on a couple websites blocked, thanks to adblock right clicks.. but for some reason, it was not that easy with netflix, so I had to use Stylus
I dont have a good understanding of the apps..
and
the netflix style I posted has an unintended consequence,
I lost the ability to see individual previews that I actually want to see..
thanks for the intro to stylus
ive not even scratched the surface, but so far so good
ToyKeeper
ToyKeeper's picture
It looks like an external dependency broke today, so I did a quick minor theme update on userstyles.org.
sb56637
sb56637's picture
Last seen: 7 hours 5 min ago
Thanks a lot for staying on top that!
Pete7874
Pete7874's picture
Last seen: 7 hours 23 min ago
Are you able to show what changes you made exactly?
I don’t want to re-download the updated theme from userstyles.org because it’s going to override all the customizations I’ve made on my end.
Thanks.
ToyKeeper
ToyKeeper's picture
Here are the exact changes:
http://toykeeper.net/torches/css/2019-09-09.diff
If you don’t see any problems on your end though, there shouldn’t be any need to update. I updated it because the subscription page had sad faces all over from a broken tinypic link.
Pete7874
Pete7874's picture
Yup, I was seeing the same thing. Thanks for fixing it.
Coscar
Coscar's picture
Last seen: 2 hours 54 min ago
Is it fixed? Im still seeing something weird on the ‘title/author/last comment/unsubscribe’ header. Im not seeing full sad faces….. just the yellow tops of their heads….Do I need to update something?
Im not a Pessimist …. just an Optimist with a lot of experience
A little John Prine
DB Custom
DB Custom's picture
Last seen: 2 days 13 hours ago
I see that as well C. Not sure if it’s worth messing with but it’s there…
DB Custom
DB Custom's picture
Coscar, I updated and it was so easy I couldn’t believe it! I clicked on the Styles “S” in the bar at the upper right of the screen, then clicked options, it opened up in a new window and I saw an updates button, clicked it and it pretty rapidly downloaded the update TK applied…piece of cake. Closed the new window and right before my eyes the yellow smiley top-of-their-heads vanished. Big Smile
Coscar
Coscar's picture
Thanks Dale………. I tried that and it seemed like it did d/l an update, but it didnt apply for some reason…..Now all I see is an ‘update styles’ button that doesnt seem to do anything……. its saying Sept 10 was the last update but its still there….. just my ‘murphy’s law’ life.
A little John Prine
RapidLux
RapidLux's picture
Last seen: 9 hours 11 min ago
I like Dark Reader, using Dynamic theme.
ToyKeeper
ToyKeeper's picture
Hmm… not sure what failed, but I pushed up a really minor change just now so it should be possible to attempt an update again.
If that still doesn’t work, it might be necessary to copy/paste the code into the edit widget in Stylus. Or maybe uninstall and reinstall the theme. Not sure which would be better for forcing an update.
Grigio
Grigio's picture
Last seen: 2 hours 59 min ago
Update works fine for me. Done 2 days ago, on Firefox browser. No more bright yellow bald heads at the top of the “Recent posts” page. Thanks, ToyKeeper!
Pete7874
Pete7874's picture
FYI, that one offending link (http://i49.tinypic.com/344twz9.png) is in one other place inside your CSS. You can see it when you go to forum statistics at the bottom of this page:
http://budgetlightforum.com/forum
ToyKeeper
ToyKeeper's picture
Thanks, I almost never look at the /forum page. Anyway, the stats box is fixed now.
DB Custom
DB Custom's picture
Once in a while I like to check the members list, it’s always staggering to me how many members we have and how so few are actually online. Getting close to 30,000 members, rare to see 100 online at one time.
Just now I looked, we have 29,660 members with 49 signed in at present. Kinda sad really that we can’t get higher participation than that. Not many giveaways happening at the moment I guess…
MascaratumB
MascaratumB's picture
Last seen: 2 min 37 sec ago
Instaled Wink
My eyes start to need some things like this already Wink
Thanks TK! Glasses
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 / PT18pro / PT28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro // ROVYVON: A2 + A5R / E300S / A8 // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 // XTAR: PB2 Charger // Tricks: 1 / 2 / 3/ 4 / 5 / 6 / 7 / 8 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
mortuus
mortuus's picture
Last seen: 1 hour 53 min ago
im confused, where do u search for theme? installed stylus but after that im lost…. dont see anything in options to search for themes.
userstyles.org ? i search blf nothing happens…..
              つ ◕_◕ ༽つ
moderator007
moderator007's picture
Last seen: 2 hours 33 min ago
Go up about 3 post up to Toykeepers last post and click here sig tag “BLF after dark”
That takes you to where its hosted with instructions, the first post in ths thread. Thumbs Up
I been using it for a year or so and really like it, saves my eyes.
mortuus
mortuus's picture
ah got it working now.. that website was awful slow for some reason… wow what a difference…. i waited this long to find out this haha….. i hate all white now its better… Big Smile thanks
              つ ◕_◕ ༽つ
