*BLF LT1 Lantern Project* (Awaiting for updates on Colored versions)
10717 posts / 0 new
ZozzV6
ZozzV6's picture
Last seen: 45 min 32 sec ago
DavidEF wrote:
I just noticed your (re)programming pads are there, which is cool. But, looking closer, they are interfering with the ATtiny footprint, or rather the ATtiny footprint is interfering with the (re)programming pads.
They should.
You are reprogramming the ATTiny with them.
DBSAR
DBSAR's picture
Last seen: 1 hour 29 min ago
Lexel wrote:
driver will be likely without power bank equipped but its there, not sure how this goes
Looks good!
i agree that this first lantern version don’t need the power bank, just the ramping design & built in charging. The AMC design is perfect for this first production lantern model.
DBSAR
DBSAR's picture
joechina wrote:
RobertB wrote:
This lantern could make good use of the Sofirn Q8 extension tubes if designed to fit. Imagine having the lantern fueled with 8 or more 3500mAh cells. Runtime for ever
There is a picture with 8 extension tubes. That makes 32 cells Wink
as long as its all in parallel & not any series its doable with up to 32 with extension tubes, to create a taller model that can run for days non stop. (the lantern will be a 4P design)
RobertB
RobertB's picture
Last seen: 8 hours 27 min ago
lohtse
lohtse's picture
Last seen: 5 days 11 hours ago
ToyKeeper wrote:
lohtse wrote:
OH HELL “past 12hours on MAX”…. CRAP I think I need a total of 4 now so please make sure am down for FOUR IN TOTAL
We could increase that to 40 hours on max by removing all but one chip on each power channel. Wink
I need clean underpants!!!!!!!! (scuttles away to change them) Thats better…… WHAT 40 hours by removing a chip or three!? Why has this not been done?
Caving, Climbing, Mountaineering, Kayaking, Diving etc any time anywhere!!! If you in the UK let me know and lets Play!
Current lighting
Olight X7R,M2R,S1 Baton,S10R Baton 3m,S2R 2, I1R EOS,SofirnC8T,Lenser P7'2,Lenser P14,BLF A6,Fenix HL50,HM50R,HL55,CL05,HL05,CL09,CL25,Nitecore HC30,HC65,NU12,NU32,Astolux K1,Petzl E-light,Tikka Xp3,XP3LED,DUO,Atomlight,Xtar Warboys H3,PL47 Manker E03H and many Chinese ones
DBSAR
DBSAR's picture
That’s why were going with the simple, easy to modify AMC 7135 driver design. The factory lantern will come with either 4 or 5 chips per channel for a given output on high, but if you want to increase run times in all the modes, (but at a reduced light output) you can remove one or two of the AMC regulator chips. (of if looking to mod it for more output can add chips to the empty 7135 chip pads.
DBSAR
DBSAR's picture
RobertB wrote:
wow that is cool Smile if Sofirn does use the same battery body as the Q8, then yes the lantern can be modded to a pole-lamp that can run for weeks of nightly use before charging the cells.
DavidEF
DavidEF's picture
Last seen: 1 day 23 hours ago
ZozzV6 wrote:
They should.
No, look at the photos of the driver renderings. At the bottom edge of the driver board, there are several vias for the programming key that he designed. But some of the pads for the MCU cross more than one via and some of the pads for the MCU don’t contact any of the vias. I don’t know if it’s “right” or not but it doesn’t look right to me.
- The YKK Philosophy
DavidEF
DavidEF's picture
But do you have that many cells that you would trust to put together like that? Would it be worth the high cost of buying that many cells just to not have to charge for a few days?
ZozzV6
ZozzV6's picture
DavidEF wrote:
ZozzV6 wrote:
They should.
The MCU outline maybe confusing there. I checked and every Via connects where it should. I don’t think Lexel overlook that noticable problem. It is fine. Wink
DavidEF
DavidEF's picture
Aah, had to zoom way in to see that there’s a little space between the top vias and the pads for the bottom legs of the MCU. Ok. Sorry for the false alarm. Facepalm
ToyKeeper
ToyKeeper's picture
Last seen: 14 hours 42 min ago
It should work fine. The only real risk there is if solder spilled over the edge of a pad and into a nearby via, bridging two MCU pins. It’s underneath so it’d be hard to see if it happened. But that’s probably pretty unlikely to happen.
ToyKeeper
ToyKeeper's picture
It has been done before. Cut the power level in half, and it doubles the runtime. For example, a Convoy light with 4×7135 driver runs twice as long as one with a 8×7135 driver. But it puts out half as much light.
On the lantern, there isn’t much need to remove chips to increase the runtime… just turn it down a level or two and it’ll run longer. Go down all the way, and it can run nonstop for about three months. You don’t have to run it at full power at all times.
sbslider
sbslider's picture
Last seen: 1 hour 40 min ago
wheremydonky wrote:
I’m in for two more. Should be a total of four.
Agreed
updated
gottawearshades wrote:
I will commit to buying two (total) of these.
Has price been discussed, and I missed it?
added one for two total. Price estimate $40 or so (less?) has been discussed, but is not firm.
DBSAR wrote:
OP Updated to that list Smile
Here is another Smile
1079 T18
1080 agent80
1081 efi5phd
1082 Coyotehawk
1083 Terrys8
1084 Rdubya18
1085 wheremydonky
1086 wheremydonky
1087 lohtse
1088 zeroflow
1089 gottawearshades
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
blgrssby
I am also interested. Add me to the list.
skroober
Last seen: 2 months 1 day ago
DBSAR wrote:
Looks good!
New here, can you clarify? Does this mean the first run for people here that said they were interested won’t have power bank function, but it will be added for later production runs? Or does this mean something else? Thanks.
DBSAR
DBSAR's picture
skroober wrote:
DBSAR wrote:
Looks good!
We decided to drop the power bank option to reduce cost per unit, and get it into production sooner. (it will still have the charging function however. Originally the lantern was to be designed to be a simple, low-cost better quality lantern as a better option to all the low-quality plastic lanterns commercially available in stores & on the market, and adding to many bells & whistles will defeat that purpose of the low-cost part.
DBSAR
DBSAR's picture
sbslider wrote:
Here is another Smile 1079 T18 1080 agent80 1081 efi5phd 1082 Coyotehawk 1083 Terrys8 1084 Rdubya18 1085 wheremydonky 1086 wheremydonky 1087 lohtse 1088 zeroflow 1089 gottawearshades
added!
skroober
Got it, was just making sure.
angerdan
angerdan's picture
Last seen: 6 hours 33 min ago
Good point.
But what about the possibility of an advanced version after the BLF Lantern is finished ?
DBSAR
DBSAR's picture
angerdan wrote:
Good point. But what about the possibility of an advanced version after the BLF Lantern is finished ?
There is plans for a deluxe version at a later date.
lightknot
lightknot's picture
Last seen: 3 months 2 hours ago
I am in for one. please add me to the list.
DavidEF
DavidEF's picture
Definitely works for me. I like having the charging function, although I probably won’t ever use it. But, the power bank function is completely useless to me. I’d rather have light than to power anything else. So whatever power is in the lantern needs to stay there in my case. I know others are more hard core in their camping, hiking, caving, etc. and would find having a power bank built-in to be quite useful as it’s one less thing to carry.
DBSAR
DBSAR's picture
For a future model we will look at the power bank function. for now the built in charging will be a great feature to have on long camping trips or off grid use.
MtnDon
MtnDon's picture
Last seen: 1 hour 26 min ago
Agreed, the charging function is much more useful to me.
BLF Member Map Add your name and location.
Tom Tom
Last seen: 10 months 3 weeks ago
DavidEF wrote:
ZozzV6 wrote:
They should. You are reprogramming the ATTiny with them.
“Via in pads” is generally a no-no. Google it. Unless you really know what you are doing, how to tent the solder mask etc.
They potentially suck out the screen-printed solder resulting in a weak joint.
Then there is ROHS lead-free solder which doesn’t like this either.
Then the idea is that the underside provides good gold plated vias for the pogo pins to contact. Which they may not if the via is plugged with solder.
Lots of things to go wrong here, for no good reason. Separate the vias from the pads is my suggestion, I see plenty of area to do so.
Edit: agree on powerbank delete decision. I certainly don’t need or want it.
Tom Tom
PS: I don’t know what charging chip you have chosen, but please be sure that it can cope with a small solar panel and dump every bit of available energy into the cells, no matter how weak the light, and how variable, night, day, clouds, shadows etc. Not all can, some only work in certain conditions and trip out otherwise.
This is nothing like charging up e.g a mobile phone from a mains adapter. Totally different situation.
Edit: I mean accepting current from any solar panel, from a standard nominal 12V panel (actually a lot higher), to one of the the popular portable USB output (5V ? delivered wastefully) devices.
TBH I think that making it only a USB input is a waste. I’d rather see a full-featured input via a rugged co-ax socket, that can accept almost any supply, from a 12V solar panel, to a re-purposed laptop 19V adapter, to a 12V or 24V automotive connection, to a USB passive or active adapter of any type.
DBSAR
DBSAR's picture
That was my original plan & the reason why i want to limit the charge rate to no more than 1 amp-draw from the USB line. I know some have argued & cried to want it to have a 2+ amp “fast charge” but that’s not needed or practical for this lantern to be a true off-grid capable light. I am still wanting it to have the maximum 1-amp charge rate for many reasons. One is that a 10-watt small solar panel can be able to charge the lantern without suffering to much voltage “sag” with the heaver amp draw of a 2+ amp charger. on the V1 Prototype i used a single TP4056 charger module, set at 1-amp. On the 10 watt small panel it still charges the lantern with four 18650, 2500mah cells from 3.4 volts to full charge in 1 sunny day of light. (My test it took 7 hours to fully charge) then using the lantern for 5 ~ 6 hours average per night for 3 nights on medium & high intermittently with no problem or worry of it going dead. My tests also showed that just 4 hours average per day of sunlight on the same charger charged it back up to full after 4 to 5 hours of use per night, meaning the lantern can run every night for years as an off grid light source using small solar panels.
I did a test with two TP4056 chargers charging four cells ( in a 2-bank box) and the 10-watt charger with the 2-amp load, would loose so much voltage from load-sag the charger would continuously turn on & off, and the batteries did not charge up at all after a full day of sun. ( same goes with charging from some of the smaller 12-volt adapter USB power plugs, they can’t sustain much past 1.2 amps before they overheat, cause voltage sag, or burn out. ( i burned out a couple of them during load testing.
To try to design it to be a “multi-voltage” charging is just adding unnecessary costs again, (another reason why were dropping the power-bank option for this first lantern model.) The team has set the design now to get this rolling, as its been to long already discussing different options and delayed this project way to long.
BlueSwordM
BlueSwordM's picture
Last seen: 17 hours 46 min ago
@DBSAR, I have a TP5100.
It’s quite a bit more efficient than the TP4056 since it’s a buck converter, and doesn’t heat up much, if at all, at a 1A charge rate.
Since it’s also more efficient, that means you don’t need as much current from the charger to achieve the same charging rate, meaning you can slightly lower current, which will lower the voltage drop of the solar panel and the cable, making it easier on the panel and more efficient Smile
TLDR: Let’s go with the TP5100 if we can.
DBSAR
DBSAR's picture
interesting, i have not tested that module before. (though it will be Lexel who is designing the driver to determine what he can incorporate on his driver prototype for that built-in charging circuit.
