*BLF LT1 Lantern Project* (Awaiting for updates on Colored versions)
10759 posts / 0 new
KalmJ
Last seen: 1 day 2 hours ago
Hi, please put me on the list for one.
Thank you.
BlueSwordM
BlueSwordM's picture
Last seen: 39 min 40 sec ago
@DBSAR, 12-15ft is 4-5m, which is still extremely long, and you will be getting high power losses.
A max of 2-3m, or a max of 9ft, would be the best bet.
cm64
Last seen: 17 hours 44 min ago
Please put me on the list for one.
Thank You.
Lexel
Lexel's picture
Last seen: 1 hour 8 min ago
I have done a quick test of the charging port
also 2. measurement I have overwritten the automatic protocol to charge at 12V to test the plug in to a 12V source as 1:1 car adapter or diretly on a 12V solar panel
agent80
Last seen: 5 hours 40 min ago
Can this work with a 1× 18650?
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 3 hours 59 min ago
Of cause, why not.
It has the same battery-tube as the Q8 and it do not need many amps from the battery, because it should have a long runtime.
sbslider
sbslider's picture
Last seen: 20 hours 10 min ago
yes, just expect 1/4 the run time compared to 4×18650
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
Petroleum Lante...
Petroleum Lantern Guy's picture
Last seen: 1 month 1 day ago
I love all kinds of lights... storm lanterns, kosmos & matador lamps, gas lanterns, tallow lanterns, flashlights, lasers, tritium vials...
Lagittaja
Lagittaja's picture
Last seen: 2 weeks 4 days ago
Ooooh, I completely missed the part about the charging circuit.
So it accepts up to 15V. Is it the TP5100 BlueSwordM mentioned earlier or something like it?
That would mean there’s no QC or USB PD or anything fancy like that?
If I understood correctly you can plug it in to a 5V USB power and it will take that but if you hook it up to a 12V solar panel it will happily accept that as well?
Hmm.. How is the charging circuit integrated to the rest of the flashlight?
I’m just wondering if the lantern is moddable in that regard?
With previous talk about configurable charging rate my guess is it wouldn’t be?
DBSAR, regarding the cable. 12-15 feet is ~3.65-4.57m. Not that far off from 5m Innocent
24AWG is pretty standard with decent quality charging cables.
But 20AWG is certainly doable with Type C and legacy Type C cables. I think I’ve even seen 18AWG at some point.
These just won’t be cheap so I’m not sure it would be worth it.
As if I did the math correctly, there’s 2.5x more copper in 20AWG than there is in 24AWG.
That’s a bit of a jump in terms of cost. And copper is expensive these days.
I’ll just dump some voltage drop values here for 5 meter cables with one pair of copper conductors
20AWG and 5V1.0A = 6.66% drop or 4.67V at the end
20AWG and 5V1.5A = 9.99% drop or 4.5V at the end
24AWG and 5V1.0A = 16.84% drop or 4.16V at the end
24AWG and 5V1.5A = 25.27% drop or 3.74V at the end
Even if we drop the length down to 3.5 meters it would still perform rather poorly in my opinion with
24AWG and 5V1.0A = 11.79% drop or 4.41V at the end
24AWG and 5V1.5A = 17.69% drop or 4.12V at the end
I’d say a 2 meter cable would be a good compromise
24AWG and 5V1.0A = 6.74% drop or 4.66V at the end
24AWG and 5V1.5A = 10.11% drop or 4.49V at the end
Or 2.5m. Something in that ball park.
DBSAR
DBSAR's picture
Last seen: 5 hours 43 min ago
good points. maybe shorten a good HD cable to 8 or 10 feet then.
Jinx
Jinx's picture
Last seen: 2 hours 2 min ago
Please add me for another 1 please Thumbs Up
ToyKeeper
ToyKeeper's picture
Last seen: 2 hours 17 min ago
The LT1 is about the same size as a Q8 with a diffuser cap on top, but it looks a lot nicer and it doesn’t emit most of its light out the top like the Q8 does. Also, it lets me adjust the color temperature, but in this pic I have it set as warm as possible to try to match the Q8.
I think the lantern is going to be getting a lot of use here. I’ll probably retire the Q8 from lantern duty, add some DC-Fix to the lens, and use it only for photo fill lighting. Because the lantern is better at, er, being a lantern.
DBSAR
DBSAR's picture
Nice photo TK Thumbs Up i do notice the slightly thicker base due to the tripod mount hole. Just curious, how deep is that 1/4-20 threaded mount hole?
DavidEF
DavidEF's picture
Last seen: 5 days 20 hours ago
Wow, great comparison shot TK! I’m looking forward to getting mine when the time comes. If I can scrape up enough money at the time, I might go for a second one!
- The YKK Philosophy
ToyKeeper
ToyKeeper's picture
It’s hard to measure the depth of the hole precisely, but it looks like it’s about 5mm or 6mm deep.
DavidEF
DavidEF's picture
What? No calipers?
ToyKeeper
ToyKeeper's picture
DavidEF wrote:
What? No calipers?
I have some, but it doesn’t have the extruding stick on the bottom like your picture. So it’s tricky to measure the depth of a narrow hole.
DavidEF
DavidEF's picture
ToyKeeper wrote:
DavidEF wrote:
What? No calipers?
Ah, gotcha.
Lexel
Lexel's picture
My summary of the lantern will be in this post
I will start now with precise measurements on the BLF lantern
first was that I could see visible brightness changes when doing tint ramping
now also the measurement shows me clearly that ithere is less brightness when between the tints
so there is some work for toykeeper to adjust the tint ramping code,
this was to be expected that some fine tuning is needed
some sort of switch breathing?
current through switch LED shows “heartbeat” pulsing
Thermal test
Setup
room Temperature about 20°C
Maximum current with 7 AMCs
this is a 15min test in timelapse reduced to one minute
the upper part heated up to 41.6°C
30min thermal images
temperature stays on absolutely safe level
permanent LED trimmer added and changed to my 2×2 LKED board with WW LEDs
Things that need to be changed on hardware side
- Programming key viases 0.05mm smaller diameter
- electrical reverse polarity protection of charging circuit and/or mechanical
- switch with warm white LEDs
- added permanent LEDs to switch
- switch wire colors changed to logical colors
black GND (atm LED)
white switch (atm GND)
red Ind. LED (atm switch)
another color for the permanent LEDs
DBSAR
DBSAR's picture
5 millimeters is plenty of depth for most tripods and attachments i know of, sounds good.
ToyKeeper
ToyKeeper's picture
Yep, it’s on the todo list.
I saw the same thing with the early tests a few months ago, but that was using old XM-L emitters… and those are known to have a slow response curve. So I was waiting for the real prototype before I try to adjust it.
charwinger21
Last seen: 1 month 4 weeks ago
Interested
EricJ2190
Put me down for 2, please.
BillyBobJoe
Last seen: 6 days 8 hours ago
I do not want a breathing switch. Not too worried, though. I’m sure there will be a way to disable it.
ToyKeeper
ToyKeeper's picture
Lexel wrote:
result
This makes me happy. Smile
The stair-step pattern is the button’s blinking mode in standby. It loops through a 16-step pattern which looks a bit like a slow heartbeat.
FWIW, the button has 4 modes:
  • off
  • low
  • high
  • blinking
But what makes me happy is that there are no spikes in the flat zone in the middle of the graph. That means the power use is too low to show up on the scope. It wakes up 8 times per second, so it theoretically could have six spikes in that flat zone, but it doesn’t. So the cost of waking up is indistinguishable from zero.
What it actually does during those brief wakeups is send a “EV_sleep_tick” event through the UI code, which the UI can handle however it wants. In this case, it just updates the button brightness level. Then it goes back to sleep. But this could also be used to implement a timer for a sunrise or alarm clock mode, or to otherwise do things while it’s “off”.
NMJoe
Please put me on the list for two.
sbslider
sbslider's picture
7 clicks unless the firmware has been changed for some reason.
Tldd
Last seen: 1 week 1 day ago
Interested in one.
Lexel
Lexel's picture
Thermal test
Setup
DBSAR
DBSAR's picture
Lexel wrote:
Thermal test
good to hear. Thumbs Up Those are comparable temps i got from the V2 prototype before i resistored the driver back from 2.0 amps draw on maximum, mode after 15 minutes, i got a measured 58 degrees C at the top center of the lantern head with the four 4000K LH351C emitters, then at around 52 degrees with a amp load of 1.65 amps for same duration. ( though its likely this production sample will have better heat dissipation and tolerances for heat transfer from the LED MCPCB to the solid aluminum head.
