*BLF LT1 Lantern Project) (updated June,02,2020)
11172 posts / 0 new
Bucknkd313
You've come a long way from the Alpha mule
DBSAR
DBSAR's picture
Last seen: 21 hours 22 min ago
Bucknkd313 wrote:
You’ve come a long way from the Alpha mule
Big Smile Thumbs Up
Compulov
Last seen: 3 weeks 5 days ago
Thanks for confirming something I was curious about (being able to run on less cells). I had two other questions (and some searches of this very large thread haven’t turned up answers).
First, would the LT1 be able to run off only the USB input (with no cells at all)? As someone who plays several location-based games, I’m in possession of several large USB power banks and being able to run the light off one of those would be a huge benefit.
As a follow up, would it also be possible to not only run the lamp on the USB input, but actually be able to charge (even if it’s just a trickle) the batteries in the flashlight while doing so? Some non-scientific math would suggest it should be possible. If it draws 1.4A off nominal 3.6V cells, then it requires about 5W of power to drive the lamp. The USB connection is said to draw 1.5A, which at 5V, is 7.5W, so it sounds like the power is there to do it. I just wasn’t sure if the circuitry is capable of it.
Oh, one more question I just thought of.. Does the charging circuit have its own protection circuitry, or should I still be aiming for cells with built in protection circuitry?
SIGShooter
SIGShooter's picture
Last seen: 8 hours 13 min ago
maxacarp wrote:
Yup, that’s what I figured. Thanks for clarifying the questions. Looking forward to the final product!
I’m trying to keep it to two lights as I really won’t use them all that frequently, but we’ll see how that goes…
Little do you know how BLF will consume and warp your mind. You will have the overwhelming urge to buy the latest and greatest flashlight, knowing that it will be the last one ever. Then you will read another post about a new awesome flashlight, and the cycle will repeat it self all over again…..and again…..and again. Cash Cash Cash
9mm/40cal/45cal bullets and large/small pistol primers available for sale in San Francisco Bay area
DBSAR
DBSAR's picture
Compulov wrote:
Thanks for confirming something I was curious about (being able to run on less cells). I had two other questions (and some searches of this very large thread haven’t turned up answers). First, would the LT1 be able to run off only the USB input (with no cells at all)? As someone who plays several location-based games, I’m in possession of several large USB power banks and being able to run the light off one of those would be a huge benefit. As a follow up, would it also be possible to not only run the lamp on the USB input, but actually be able to charge (even if it’s just a trickle) the batteries in the flashlight while doing so? Some non-scientific math would suggest it should be possible. If it draws 1.4A off nominal 3.6V cells, then it requires about 5W of power to drive the lamp. The USB connection is said to draw 1.5A, which at 5V, is 7.5W, so it sounds like the power is there to do it. I just wasn’t sure if the circuitry is capable of it. Oh, one more question I just thought of.. Does the charging circuit have its own protection circuitry, or should I still be aiming for cells with built in protection circuitry?
Yep, yep and yep to a point. Silly I already tested all those abilities, and it does. i ran the LT1 test sample on a 2-amp Samsung phone charger on all modes with no problems with the battery section removed. (also did the same from a power bank) *see photo below with the LT1 first test unit running perfectly on the USB power with the entire battery section removed.
Also it will “trickle charge” the cells when the lantern is running on the lower modes, ( the modes that pull less amps than the TP 5100 can output, so it powers the lantern and the remaining charge amps go into the cells, but i do have a concern about doing that at the same time as the lantern running, as it can likely trick the TP5100 charger into continuously charging the cells after they already fully charged as the lantern amp-load tells the charger to keep producing charge output possibly. )
PBNinja
Last seen: 4 months 3 hours ago
That’s just awesome actually…..
dragunbayne
This thing should be call the BLF EABABLE1 (End All Be All Bestest Lantern Ever 1)! Seriously I cannot believe no one has made a lantern close to this good. The only one I ever found that really peaked my interest were the Fenix ones and I was never able to bring myself to hit the buy button. This lantern however gives me no doubts.
MascaratumB
MascaratumB's picture
Last seen: 17 min ago
WOW, just WOW!!!
Damn, I guess I never needed a lantern, and Im not sure I will use it often, but this real nice!!! I guess I will use it outside as hell when I get it Big Smile
Good work! Took its time but will be a great light!
Thanks to all involved Wink
BTW, and just to confirm, 18650 flat top cells will do the job, right? I saw it was mentioned the Samsung 35E (3500mAh) flat top would work! Is it correct?
I will order some batteries soon, for this and other lights and would like to buy them together!
Again, thank you Wink
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro // ROVYVON: A2 + A5R / E300S / A8 // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 // XTAR: PB2 Charger // Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
BlueSwordM
BlueSwordM's picture
Last seen: 2 days 21 hours ago
Sorry, but you need button top cells.
MascaratumB
Oops, misunderstood it or misread it Oops
Thanks for clarifying BlueSwordM Wink
Not I can spend my money in a informed way Big Smile Cash
I’ll be a good buyer Innocent
teacher
teacher's picture
Last seen: 11 months 1 week ago
Please add 2 more for me.
Thank you.
ferthur
Last seen: 3 weeks 1 day ago
I’ve been waffling about if I want a second one or not… Why the heck not.
Put me down for a second one.
#463 in the list.
Compulov
Okay, so it sounds like just to be on the safe side, it would be a good idea to stick with protected cells (and maybe just charge with an external charger if I want to charge while the lamp is running — I’ve got a USB 18650 charger so that’s not a big deal).
BlueSwordM
Protected cells wouldn’t do anything at all in this case.
It’s not actually dangerous. Just bad for cycle life for the cells.
Unprotected vs protected does not matter at all.
Helios azimuth
Last seen: 12 hours 17 min ago
Bad for cycle life due to the low drain? I planned to use four protected 2600mAh 26F’s and some unprotected 30Q’s, but not together of course. Is that a bad idea?
patmurris
patmurris's picture
Last seen: 1 day 13 hours ago
If as suspected the internal charger keeps charging the cells forever when the lantern is on, running off USB, the cells protection circuit would be a safeguard?
SvenWalker
Last seen: 10 months 2 weeks ago
Will the upgraded (V2) version of the lantern begin development when the V1 lanterns finish shipping or have both versions been developed side to side?
DBSAR
DBSAR's picture
As i do not know if the TP5100 charger chip would actually do that, i think either Toykeeper or Lexel would be more qualified & knowledgeable in that category than i am.
patmurris
patmurris's picture
DBSAR wrote:
…see photo below with the LT1 first test unit running perfectly on the USB power with the entire battery section removed.
The lantern running without batteries, off a USB power source, opens up quite a few options i was not aware of! It could even be turned into a home appliance… The battery tube could also be replaced by any thread compatible foot design you want. Adding remote control should not be too complicated either (at least on/off)… This LT1 project is exceeding initial expectations in many ways! Thumbs Up
DBSAR
DBSAR's picture
I have ran it for hours during testing just plugged into one of the USB power ports in my RV trailer using a 10 foot long USB-C cable with no batteries in the lantern, proving the LT1 can be a multi-powered by almost any 5 volt power source that can supply at least 1.5 amps.
DavidEF
DavidEF's picture
Last seen: 11 hours 37 min ago
It’s bad for the cycle life of any Li-Ion cell to keep it charged at 100% and even worse to keep charging it once it has passed 100% charge capacity. For “float” charging set-ups, you are better off using lead acid batteries. Perhaps, if the terminal voltage of the charger were set below the max charge voltage of the Li-Ion cell, some of its life can be spared. But I don’t know that. I’m just guessing it might be possible. Best is to not overcharge, not over-discharge and not overheat the cell ever.
- The YKK Philosophy
SIGShooter
Just for grins I ran some stats to see what the breakdown of lantern interest are as of this minute:
1,221 users have signed up for a total of 1,848 lanterns as follows:
  • 1 lantern – 801
  • 2 lanterns – 297
  • 3 lanterns – 74
  • 4 lanterns – 33
  • 5 lanterns – 7
  • 6 lanterns – 4
  • 7 lanterns – 2
  • 8 lanterns – 2
  • 10 lanterns – 1
Still time to get your addition lanterns on the list Smile
DavidEF
DavidEF's picture
I’m on the list for one. I’ve long been “interested” in more, but my wallet disagrees, so I stay at one. If I come up with some more money, I’ll certainly be looking to add a couple more lanterns for gifting. Cash
Bardo219
Last seen: 1 month 1 week ago
Please add me to list to purchase one
ferthur
I don’t know if I missed it or not, but will the USB port on the lantern work with USB PD? Most lights that I’ve heard about, or have experience with, that use a type C port won’t charge with PD, you must use an A to C cable.
DBSAR
DBSAR's picture
yes, it will likely work with the USB power delivery (PB) type chargers. the TP5100 charging chip can accept and regulate any input from most power sources i have tested.
leftdisconnected
Last seen: 1 week 8 hours ago
It appears that protected cells use IC’s like this one, which provides over-discharge, over-current, and over-charge protection.
However, the over-charge cut-off is triggered at a specific voltage. Thus, the protection circuit will only shut off current after the voltage reaches that trigger, which it may never do if the over-charge trigger is above the output voltage of the LT1 charging board.
It seems likely that the cells would just sit and “soak” at ~4.2V for as long as the light were kept running. Cell charging current would drop quite low and nothing dangerous would happen, but li-ions are not meant to remain in constant-voltage mode indefinitely, which is effectively what happens with the light running and the cells charging at the same time.
So, the answer is probably that protected cells will not be a safeguard.
Please correct me if I’m wrong here as I don’t want to misinform anyone.
RobAllen
djozz
djozz's picture
Last seen: 16 hours 8 min ago
My collegue wants one. I’m in for one atm, please add one for a total of 2 Smile
Smiley_666
Last seen: 2 months 1 day ago
Put me down for one please
Illumenated
Last seen: 3 days 20 hours ago
Hey everyone my mom got sick and I’ve been offline for a few months… I live in the US….can you guys tell me what batteries you recommend for this one? Should I just get more like I have for the Q8 (Samsung 30Q) or does it need something different for output/longetivity?
Thanks and sorry if someone else has already posted this…
