*BLF Ultimate Lantern Project*~updates:Sofirn working on design, to produce prototype!
3554 posts / 0 new
WaylonJennings
Last seen: 10 months 2 weeks ago
I am really excited to see the prototype for this lantern. I am curious to see how the downward mounted led is incorporated. The flicker and lightning modes sound great!
jaynick
Last seen: 3 weeks 13 hours ago
Im interested if cheap. Wish it were a little brighter tho. 40w incandescent isnt that bright but the runtimes sound good.
jigsaw
Last seen: 16 hours 35 min ago
Hopefully there’s some sort of update soon. I’m getting anxious.
theadlee
Last seen: 4 months 1 day ago
Very Interested
Couchmaster
Last seen: 11 hours 11 min ago
Please add me to the list of those interested.
Thanks
DBSAR
DBSAR's picture
Last seen: 11 hours 40 min ago
ToyKeeper wrote:
This isn’t really new any more, but it occurred to me that I hadn’t mentioned it here…
Although I don’t have BLF Lantern hardware yet, I added some lantern-related features on my BLF Q8. One thing it has is a sunset mode, where it’ll start at a low level then get dimmer for an hour until it shuts itself off. It also has some more atmospheric modes which I think would work well on a lantern…
3 minutes of lightning storm mode:
3 minutes of candle flicker mode:
Play both videos at the same time if you want to simulate taking shelter by a fire while a storm goes by. ;P
Nice idea! Smile
DBSAR
DBSAR's picture
I have the prototype (from the OP) taken apart and re-working the head design for 2 LED emitters and a center post bolt ( to make it simpler & stronger, plus adding a frosted main lens to eliminate the inner globe to lower costs & make it simpler in design. I hope to get photos of it soon and post an updated blueprint. – DB
ToyKeeper
ToyKeeper's picture
Last seen: 11 hours 20 min ago
I don’t mind the relatively low output, but I can definitely understand how it’d seem underwhelming compared to the BLF Q8. It’s designed for a totally different style of use though, where turbo isn’t very relevant… and the lower brightness should help keep the cost down a bit.
It’ll make the lightning storm mode less impressive, but that’s kind of just icing anyway.
raccoon city
raccoon city's picture
Last seen: 13 hours 9 min ago
Post #1000!
(at the moment)
Stittville Ed
Stittville Ed's picture
Last seen: 2 days 20 hours ago
Please leave the Lightning Storm Mode as it is, to cooooooool to change Smile
jigsaw
The point she is making, is the lightning storm won’t be nearly as dramatic from the lantern because it doesn’t produce the lumens of the Q8.
BlueSwordM
BlueSwordM's picture
Last seen: 2 min 19 sec ago
I’m interested too, only one of course.
A lantern would be quite useful. Do you think it could also fit 20700/21700 cells?
Would like to know.
My very own high current Beryllium Copper springs: http://budgetlightforum.com/node/64047
derfyled
derfyled's picture
Last seen: 23 hours 12 min ago
Would like to know.
This is a great idea. 4 × 21700 could give 16000 to 18000 mAh. A little plastic sleeve could easily convert it for 18650.
BlueSwordM
Oh yes, that would be awesome. Downsize compatibility is a must. 21700s to 18650 adapters would be excellent.
koyotee
koyotee's picture
Last seen: 3 weeks 1 day ago
Put me down for one please.
Finaly, proud owner of a Powerex Maha mh c-9000 for my Eneloops:)
toxiccoccyx
Last seen: 23 hours 7 min ago
Interested – 1
boostedsubie
Last seen: 1 week 6 days ago
Interested in 1
mattej
One for me too.
And I am not frightened of dying. Any time will do, I don’t mind. Why should I be frightened of dying? There’s no reason for it – you’ve got to go sometime.
Nicolaas
Last seen: 23 hours 36 min ago
Also interested in on (1) light.
I like where this is going so far, especially when there is a true WW option.
Camping light = warm light.
At least to me that is…
Grtz
Nico
derfyled
derfyled's picture
Grtz
Nico
Same here, I never understood folks that spend their evening outside with a cool white neon Coleman lantern. Sick
Tender
I’m in!
Had a situation where this light would have been the perfect solution
"Keep On Luxing" © and "May The Lumin Be With You" © (by my very self)
smed1275
Last seen: 2 weeks 11 hours ago
Please add me to the list for 1, this souds too good to pass up.
nonsuch
nonsuch's picture
Last seen: 5 days 16 hours ago
Interested in one.
Thanks.
WaylonJennings
I read on another thread that the lantern project is going for about 500 lumens on max. Is this true? I would imagine that this might be about the highest output that I would need much of time, but it sure would be nice to have access to a higher turbo level for those times where more light is needed.
lovetheguitar
Really nice project!
Please add me for one.
Thanks. Smile
ToyKeeper
ToyKeeper's picture
As far as I’m aware, yes.
The driver is using true current regulation, not a FET+7135 design, and all MCU pins are already being used… so increasing maximum output is not very feasible without significant design changes.
It’s designed by someone who uses lanterns frequently for long periods, to be practical rather than flashy. Ideally, charge-able each day with a small solar panel, with enough runtime to last the entire evening, for long-term off-grid use.
RobertB
RobertB's picture
Last seen: 12 hours 4 min ago
I have a 650lm Fenix CL30R. I never use it on high, its just too bright for around the campsite.
rangerhd
Last seen: 11 months 4 weeks ago
I will take one as well.
osb40000
Last seen: 6 days 15 hours ago
Grtz
Nico
Agreed on warm light.
osb40000
I sure hope it’s a lot more than 500 lumens, that isn’t much for times where you’re trying to light up a decent sized camp. That said, when it’s pitch black out, your eyes adjust pretty well to lower light levels.
