*BLF LT1 Lantern Project* (codes going out for more LT1s, second batch shipping!)
10593 posts / 0 new
Agro
Agro's picture
Last seen: 1 min 35 sec ago
In for 1.
prepro
prepro's picture
Last seen: 5 days 1 hour ago
Sure.
goshdogit
goshdogit's picture
Last seen: 1 hour 8 min ago
DBSAR wrote:
Work is underway on the new Version-2.0 prototype, now based from the BLF Q8 body, using the Q8 illuminated switch.
Nice! Thanks for the update.
Enjoy your canoe trip!
ToyKeeper
ToyKeeper's picture
Last seen: 7 hours 34 min ago
DavidEF wrote:
You know what would be REALLY cool AND totally outside the scope of this project? Add four RGB LEDs around the main LEDand make the “candle” mode full color flicker (mostly red/orange/yellow) with the main white LED on at a dim constant for a little bit of real light. I would love that as a “middle of night” mode. If the lighting level could be ramped up (or multi-mode) then it could also serve as a “fuel” torch/lantern and even all the way up to “campfire” if the light is capable of getting bright enough.
I have something like that in my lightsaber firmware, actually. The modes there are a sum of two oscillators in a HSV-like color space (hue and “intensity”, which is a combination of saturation and value). One oscillator ramps between two arbitrary points, while the other oscillator adds to the intensity. It would be fairly simple to map the candle mode ramp onto a line through color space, like from a dark red to a bright yellow.
djozz
djozz's picture
Last seen: 55 min 47 sec ago
I think it is essential that you need to decide at this point what the maximum output of the lantern will be, before do any further designing or building more prototypes. If the maximum output is to be indeed only 500 or so lumen it makes sense to skip a lot of material (making the lantern cheaper to build and more portable without sacrifying any of the performance). The thick chunk of aluminium at the top can be reduced to 1/4 the size, with a few fins added, and all the thick aluminium that is above the battery tube in the ‘Q8’ prototype can be reduced to a thin aluminium shell. Also at 500 lumen there is no reason to use more than one led. Compared to one XP-L or LH351D led run at 500 lumen, triple or quad leds will hardly be more efficient and they complicate the design.
Agro
Agro's picture
DavidEF wrote:
Stittville Ed wrote:
DBSAR,
Your new Prototype V2.0 looks GREAT!!!!!!!!!!!
Thank You and all the others involved in this project for all of the work it will take to make this light available to everyone.
I think that the Candle and Sunset Modes are very cooooooooooool Smile
Does it really need RGB? Maybe NW+WW or WW+NW+red would work adequately?
DBSAR
DBSAR's picture
Last seen: 30 min 59 sec ago
bmengineer wrote:
Looks great DBSAR! Is the plan for the globe to be plastic or glass? Whichever you choose, I’m hoping it’s sturdy enough to toss into a pack without having to wrap it up in a sock or something. Keep up the awesome work! The top of the lantern looks pretty heavy in the current prototype – maybe a few fins would help reduce weight and add surface area?
Will be plastic, probably a polycarbonate lens type so it will be very durable. I was thinking of cutting fins in the head, but my 2mm channeling carbide cutter for the lathe is chipped & can;t do it without a replacement. The one for the manufacturer CAD design may likely have fins in the head to help dissipate heat & reduce weight.
DBSAR
DBSAR's picture
The V1 prototype uses 1 LED, and is roughly 470 ~ 520 lumens on high. With two LEDs i may test the new Q8 based version to 700 ~ 800 lumens, and monitor heat levels. The new design with the center bolt/post will be stronger & simpler than the V1, and wil require the use of 2 LEDs at least, ( one on each side of the center bolt) to avoid a shadow from the bolt. Very true on the Q8 mid section, the fins & some of the metal below the side switch can be reduced & thinned down to shave more weight, as that part will no longer be subject to the heat of the LEDs.
sbslider
sbslider's picture
Last seen: 2 hours 37 min ago
Andyman wrote:
I haven’t been too involved here recently… But just wanted to check back in and say I’m still very excited about this! Thanks for working on it as your time allows, DBSAR!
x2!!
Also, just curious. This is about 2 yrs in, and what looks like a close to (but not yet) final prototype is being built. Is having the final unit available through Thorfire likely 6 months away, 2 years away, or still too early to know?
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
XXX-Man
XXX-Man's picture
Last seen: 1 hour 42 min ago
I am interested in one when available.
Put me on list Smile
"With the first link, the chain is forged. The first speech censured...the first thought forbidden...the first freedom denied – chains us all, irrevocably."
My reviews:
Sofirn SF36 /// Thorfire VG10S /// Sofirn C8F /// Zanflare F1
DBSAR
DBSAR's picture
sbslider wrote:
x2!!
The project was on hold for some time over the4 last year as life’s disasters got in the way. I hope we can get a pre-production model rolling by this late spring or summer or as soon as we can. I will have the final prototype completed before the end of May, and hopefully the others who have the driver expertise, and we can get a team rolling with someone to provide a final CAD for Thorfire to work on once i get the specs worked out form the prototype testing.
cyrex
Last seen: 1 month 1 day ago
interested when available
BT100
Last seen: 6 hours 30 min ago
Please put me on the list for a second and third one, thanks
voltron88
Please add me to the interested list.
sbslider
sbslider's picture
Thanks for the feedback. I have not followed one of these projects before and just did not know what it takes to really make something like this happen in your “free” time. Sorry to hear about your disasters, hope they are behind you for now.
Kulumatic
Last seen: 2 days 22 hours ago
I am also interested. Thanks
RaVeN
Thanks alot for your work on this, just read the latest post. Great news about using the Q8 in this.
Will definitely be buying the final lantern, as I’m pretty sure it’s going to kick ass!
derfyled
derfyled's picture
Last seen: 20 hours 34 min ago
This is getting very interesting. I was no. 377 on the list, please add another one for me (total 2).
Thanks for the hard work!
syracuse
syracuse's picture
Last seen: 1 day 1 hour ago
Please put me on the list for 1.
MichielSanders
MichielSanders's picture
Last seen: 2 weeks 3 days ago
It looks great DBSAR Thumbs Up Crown
Olight: M3XS-UT, S Mini CU, R50 CU, R50 Pro LE, M2R, I3T Cu, S30R III, Marauder X6, X7R, X9R - BLF: Q8, A6, GT, GT mini - Emisar: D1s, D4Ti - Reylight: Tripple Dawn, Ti Lan
Nitecore: TM26GT, SRT9, EC11, T5s, P05Pink, LA10, HC33, HC70 - Fenix: TK75Vn FiatLux, TK76, CL05, CL09 -  Lumintop: Tool Ti, IYP365Ti - Astrolux: MF01 Lexel driver - FourSevens: Maelstrom MMU-X3
cncyana
Last seen: 8 months 1 week ago
Sorry to hear about your hard times and hope things get better. Totally understand if you have to put things on hold for a while. There is more to life than lights after all.
Just thankful for the project and that it is still intact and moving forward.
Life’s Questions/Answers here: http://www.answersingenesis.org/home/area/qa.asp “So then, each of us will give an account of himself to God.” Romans 14:12
JakeDjanitor
Last seen: 5 hours 15 min ago
Not sure if this had been covered yet, but is it possible to install a USB type c plug?
DBSAR
DBSAR's picture
It has been discussed several times through the topic chat, but unsure of cost atm.
JakeDjanitor
Thank you. I recently bought a phone with the type c, it seems superior. I was thinking about it as a long term reliable piece. Maybe there is a way to convert micro USB to type c down the road.
Kratomas33
Last seen: 1 year 8 months ago
Im interested in one!
SIGShooter
SIGShooter's picture
Last seen: 1 hour 36 min ago
My opinion is that the micro usb option is the way to go since it’s almost certainly cheaper and also doesn’t require those of us not using type C at the moment to have to purchase new cables.
9mm/40cal/45cal bullets and large/small pistol primers available for sale in San Francisco Bay area
Persechini
Persechini's picture
On the type of plug, type C is becoming the standard for a lot of devices already, and as it does, the availability and commonality of the plug will have products that only use usb for charging also migrate. A flashlight is an item that will last us for a long time, so I’d rather have it use the plug that is becoming standard in the near future than the one that is slowly but surely being phased out, even if it ads a little to the price. But at this point in the transition, micro USB oriented arguments still have a very strong foothold, just not my personal preference, specially since for charging purposes cheap adapters can be used instead of renewing one’s entire cable collection.
In my Tree
My collectionEmisar: D4 / D1 / D4 (broken) ― Convoy: C8 Clear / S2+ Clear / S2+ / S2+ UV / S6 ― Nitecore: Tube / Thumb / Concept 1 / HC30 / HC33 / TIP / TIP CRI / TINI ― Lumintop: Tool AAA / Tool AA / HLAAA / EDC05 ― Sofirn: SF10 / SF12 / SF12 / SF14 / SF14 / SF14 / SP10A / SP10A (gifted) ― Jaxman: E3 ― UTorch: UT01 ― Trustfire: Z2 ― Skyfire: SF-065 (trashed)
Madtoffel
Last seen: 10 hours 12 min ago
I would also buy one. Please put me on the list.
JakeDjanitor
Long term the type c will be the standard. Right now micro is still so abundant. We all have many micro not as many type c
jdunlap27284
Last seen: 12 hours 33 min ago
I’m interested in one, already posted at #1192 but not on the list, must have been missed. thanks
