*BLF LT1 Lantern Project* (codes going out for more LT1s, second batch shipping!)
10593 posts / 0 new
ToyKeeper
ToyKeeper's picture
Last seen: 7 hours 7 min ago
It looks nice so far. I hope we can do the two-tint idea though, with ~3000K and ~5000K emitters and 4×7135 or 5×7135 per channel. It’d be cool to be able to change the temperature.
angerdan
angerdan's picture
Last seen: 1 day 14 hours ago
Thanks to DBSAR for the updates and BlueSwordM for the LEDs!
BlueSwordM wrote:
I hope Thorfire will pick 3500-4000k LH351Ds. Then we will have a winner, and the best lantern to have ever existed.
Since about two years, warm white (2700-3300K) color temperature is the goal of this project. Which in my opinion suits the use.
Maybe there will be two versions? Neutral white (3300-5300K) in addition to warm white. It’s also specified in DIN EN 12665:
https://gossen-photo.de/wp-content/uploads/DL/LMT/Kompendium_der_Lichtme...
Having a winner means also that there are some left behind.
DBSAR wrote:
The best tint range for lantern use i found to be between the 2700K to 3500K warmer white range, (Warmer whites are much less “glarey” on the eyes, have much better CRI than the cold whites, and as tested by independent university lab studies warmer colored light to amber light can reduce eye fatigue, & oddly reduce stress & hypertension during longer exposures (as lanterns run continuously as the main ambient light.)
face it, as humans we lived for thousands of years lit by warm, amber colored fire, lamps, and the sun, not by blueish light from fluorescent or cold white LEDs. (as in the fact that the blueish, gloomy, gray light from cloudy days, & mercury vapor glarey street lighting can be depressing, while the warmer light from the sun does the opposite.
I will start with a XM-L 6C tint, (3500K warm white) and may switch it over to a 7D4 tint later for testing, (close to 2700K incandescent) Others may prefer neutral tints, & i do have some lanterns with 4000K & 4500K tints, but from experience the most preferred tint range from people that seen my lanterns in use at night seem to prefer the warmer tints.
I’m sharing what DBSAR wrote.
https://www.licht.de/fileadmin/Publications/licht-wissen/1409_LW19_E_Imp...
BlueSwordM
BlueSwordM's picture
Last seen: 4 hours 57 min ago
I would prefer 3000k emitters, but I haven’t found a supplier for them to actually test a 3000k LH351D 90CRI.
The only lead we have are the 3000k LH351B 90CRI, but they aren’t nearly as efficient as 351Ds.
angerdan
angerdan's picture
In my opinion 85CRI isn’t bad. But 90CRI would be more nice.
candor
Last seen: 1 week 5 days ago
Hot damn, two more please! ~3000K would be awesome. Two-tint would be even better. But the way this is shaping up, it’s gonna be unbelievable no matter what. I can’t wait to use them and to gift them. A thousand thanks!
sbslider
sbslider's picture
Last seen: 2 hours 10 min ago
Your next two lights are interest numbers 797 and 798 for 6 total.
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
R10500
Sign me up for it! Thanks for another wonderful BLF product
DBSAR
DBSAR's picture
Last seen: 3 min 38 sec ago
Same thought too. Would be a great option to have changeable tint, (from 2700K up to 4000K maybe) Though right now its out of my abilities to design a driver & modes to work with that set up, will need your expertise to help develop that Smile
DBSAR
DBSAR's picture
We are looking to see if Thorfire can offer the lantern in at least two tint ranges, ( 3000K & 4000K) or develop the dual tint set up as Toykeeper as mentioned above.
sbslider
sbslider's picture
done, you are number 799 on the interest list
interest list sorted by entry number
interest list sorted by user names
ToyKeeper
ToyKeeper's picture
It’s pretty easy, really a trivial change compared to the Q8 driver. Instead of 3+1 chips, it’s 4+4. And I think I can add support to the firmware relatively easily too.
It’d be fine to use 2700K on the warm end, or maybe even 2200K if you can get it… but I’d suggest making the cool end 5000K instead of 4000K, because even 4000K is warmer than some of us want. With the ability to blend to whatever temperature the user wants, I doubt there’s much reason to make the range narrow. They can set their light to 2700K, or 3000K, or 3500/4000/4500/5000K, as desired.
cu42
Last seen: 6 hours 39 min ago
The shots in camp look great. I am excited for 3000K and 90CRI. I hope these make the cut.
My order of priority: ( I know, my opinion matters 0.0001% and we all know I will buy this thing even if everything is the opposite of this list.)
1. High CRI
2. High CRI Smile
3. 3000K perfect. 4000K OK
4. Shield/Reflector – adjustable or removable
5. USB charging/Power bank
6. Efficiency
7. Dual tint – solves #3, but warm is simply my goal.
I would only be using this on high for minutes at a time and medium to low settings mostly. Efficiency of the LED to me is a far lower priority than high CRI. I would rather carry spare batteries that I probably still wouldn’t need in trade for the pleasantness of 90+CRI lighting. It only takes 20 seconds to swap 4 batteries. I cant swap LED’s easily and I certainly can’t replace the missing color from memories and photos I plan to gain over years while using this lantern..
My brother in law used to yawn when I would tell him about high CRI while shining them around the back yard. Then it happened. We were cooking steaks over the fire and he was using his cool white and probably very low CRI light he loved sooo much. Even on the highest setting while blinding us all, he couldn’t even tell if his steak was seared on the outside let alone see if it was red, pink or other in the middle. I busted out the 219C and he was instantly enlightened. On any setting, our meals went from grey and lifeless to colorful and appetizing with the click of a switch. He wanted to know where to buy the flashlight. Having perfectly seared medium rare ribeyes instead of burnt hockey pucks was a nice side effect as well!
Using low CRI light to find an item in the dark for a few minutes is one thing. Hanging with friends, taking photos, cooking and eating under it all night long is another.
klrman
klrman's picture
Last seen: 2 hours 33 min ago
Interested.  Light is starting to look really good now.
djozz
djozz's picture
Last seen: 28 min 26 sec ago
It would be pretty neat if with a dual tint set-up the colour temperature is changed during ramping, according to Kruithof’s theory, but of course it will be more versatile and very easy to operate if at any brightness setting the tint can simply be adjusted (a tint ramp?). I’m really liking this and it will make the lantern even more unique!
Edit: I think a tint ramp is so suiting for this BLF lantern that it may even deserve a dedicated button.
Aleister
Aleister's picture
Last seen: 2 weeks 6 min ago
I am interested
Let a flooder be my wife and a thrower be my mistress
sbslider
sbslider's picture
Added at #800
Aleister wrote:
I am interested
Added at #801
angerdan
angerdan's picture
Like with the Convoy S2+, a tint range to choose one tint at order could be a great choice to offer anybody the prefered color temperature (CCT).
AgentWhiteBread
Last seen: 3 weeks 4 days ago
I know I’m going to regret it if I only buy one. Can you put me down for another one please?
Thank you! The pictures from the campsite look incredible.
DBSAR
DBSAR's picture
Good points Smile
DBSAR
DBSAR's picture
1. High CRI
2. High CRI Smile
6. Efficiency
I am thinking i may mod the V1 to use four 3000K to compare the 3000K to the 4000K LH351 emitters side by side so we can see the tints and color renderings directly.
DBSAR
DBSAR's picture
very true. am liking this ramp idea to more lately Smile
chinooker
chinooker's picture
Last seen: 3 hours 44 min ago
I am 256 chinooker on the list.
Please add 1 more for me.
O26Rcr
Last seen: 5 days 20 hours ago
Please add two more for me as well. Thanks!
ToyKeeper
ToyKeeper's picture
djozz wrote:
a tint ramp?
I was thinking it would use a regular brightness ramp, but there would be an additional factor to set the tint blend. Probably an 8-bit blend value, so 256 steps of color control. If the brightness was set to, perhaps, PWM=100/255, the tint value would determine how much of that 100 goes on the warm channel vs how much goes on the cool channel. So, for example…
  • Tint=0 would be entirely warm (100/0), 3000K.
  • Tint=255 would be entirely cool (0/100), 5000K.
  • Tint=128 would be 50/50, 4000K.
  • Tint=83 would be 68/32, ~3640K.
It would take perhaps 4 seconds to change tint from one end to the other.
The easiest way to add it would be to map tint change to “click, click, hold” since that’s not really used yet, so it would work during pretty much any mode — anything except “off”, lockout, and momentary, IIRC. And perhaps it could also have an automatic mode where tint is determined by brightness, like maybe if tint=0, it would be automatic.
The lantern’s design unfortunately makes thermal regulation not work, since the sensor (tiny85 built-in) is thermally isolated from the emitters. However, this should provide extra room to add other features… like tint ramping.
BlueSwordM
I think Tint=255 should equal 4000k, and not 5000k.
I would personally a ramp between 3000k to 4000k.
djozz
djozz's picture
If the tint goes from 2700K to 5000K, more people and more situations will have their favorite tint, with 254 tints in between there are also more than enough tints between 3000 and 4000K.
FBsLights
Last seen: 1 month 1 week ago
This looks too good to pass up!
Please put me on the list for two.
I’d prefer something in the 3000k to 4000k.
Two LH351D 3000k 90CRI emitters and two LH351D 4000k 90CRI emitters with tint adjust/ramping seems perfect to me!
FB
djozz
djozz's picture
^ that would be a nice implementation, TK!
sbslider
sbslider's picture
I agree, that’s why I currently am in for 3. Added you at #802 on interest list
Added second light at #803 on interest list
4 total for you, numbers 665, 666, 804, 805 on interest list.
you are in with numbers 806 and 807 on the interest list.
There is a definite correlation between posting updated prototype pictures and people expressing a desire for this lantern. Party
DavidEF
DavidEF's picture
Last seen: 4 hours 44 sec ago
I would really like for the tint to ramp between 2700k and 5000k in the way TK described. Some of you guys need to remember that there are others in this world besides yourself and 5000k is still considered Neutral White and is going to be preferable for a huge percentage of people. Not only that, but as djozz said, 4000k is still possible, so you’re not losing anything by it.
- The YKK Philosophy
