Efest IMR18650 2500mAh (Purple) 2016
Official specifications:
Typical Capacity: 2500 mAh
Nominal Voltage: 3.7V
Discharge End Voltage: 3.0V
Standard Charging Current: 1.5A
Charging Voltage: 4.20+–0.05V
Max Pulse Discharging Current: 35A
Dimensions: 65.11mm (L) x 18.44 mm (D)
Weight: 46g
A 2500mAh battery with a fairly high current rating.
The discharge curves look very good, they tracks perfectly and capacity is nearly constant.
The battery got warm at the higher current and I had to stop.
I stopped this discharge a bit early due to temperature.
For now I am running with a fairly low maximum temperature (This trace here melted one battery holder).
Remember the traces are temperature increase, i.e. the actual battery temperature is 25-30°C higher.
Only B battery is valid, the holder for A is melted.
Conclusion
The battery has good performance, but gets warm at 30A (Not a big surprise).
Notes and links
Compare to 18650 and other batteries
