Review: Astrolux S1 3D Flashlight
123 posts / 0 new
vresto
vresto's picture
Last seen: 1 day 7 hours ago
how do i memory to ON? its still OFFSmile
EDC-Amutorch X9 XHP50 nw,Sofirn If-25A cw
Headlamp-Thrunite TH30 nw
JPLight
Last seen: 2 days 14 hours ago
Rolz wrote:
Hi JPL, Sorry to read your issues. As you have done please contact Banggood and discuss the issues. I’ve not personally heard of the problems you describe, possibly someone else has who can assist with the query re the UI. I’d also recommend checking the thread on the BLF A6 troubleshooting http://budgetlightforum.com/node/41726. It may include a similar experience. I’ll do some checking too, and advise if I find a similar issue and answer.
Thank you Rolz for checking as well. I did read the BLF A6 troubleshooting thread, but could not find anything matching my problem yet.
Rolz
Last seen: 7 hours 40 sec ago
I’ve done some searching and not found any mention. Possibly PM Toykeeper for opinion
Rolz
You need to turn the flashlight on. Then tap/half click the tailcap switch 15+ times. You’ll then enter config mode as per the image below. Once ini config mode you’ll see 2 blinks in one lot and then a second time. After the second lot of 2 blinks turn off the flashlight. On restarting you should have activated memory mode.
JPLight
Wasn’t it 16+ short clicks/tabs ?
Rolz
Thanks for pointing this out. Just checked Toykeepers details on the firmware and it’s described as per below. So probably yes to 16 taps. I’ll update the post to suggest 15+
- Short tap rapidly a bunch of times (15+ taps, or until the light stops turning on) to enter soft config mode.
hatman
Last seen: 1 week 2 days ago
Is there a way to get it to turn on each time to turbo with just one click?
gigbyt
gigbyt's picture
Last seen: 10 months 2 weeks ago
Yes, put it in mode memory = ON mode.
turn it on and put it in TURBO mode.
shut it off
when you turn it back on it should come on in the last memorized mode, which would be TURBO.
TURBO gets hot real quick so be careful.
Take care,
john.
I GOT NOTHING
gigbyt
gigbyt's picture
I just recvd mine yesterday after a 37 day wait from banggood.
played with it last nite, really nice flood beam.
I really like that you can go backwards in output modes with a long press of the switch.
I did get the short tube for the other battery type, it was in a separate bubblewrap container,
not in the box with the torch.
for the programming modes I short pressed the switch 16 times
the torch will then blink twice and pause then blink twice again.
after the FIRST SET of 2-blinks shut off the torch to choose between mode
GROUP-1 which is,
moon
low
med1
med2
high1
high2
turbo.
(mine came delivered in mode group 1)
or mode GROUP-2 which is,
low
med
high
turbo.
after the SECOND SET of 2 blinks, shut off the torch to choose between,
MODE MEMORY OFF (mine came delivered in memory off mode) or
MODE MEMORY ON.
I had to re-enter mode programming(re-do the 16 short presses).
after changing each mode.
Hope this helps someone.
I GOT NOTHING
Grieflar
Grieflar's picture
Last seen: 11 months 2 weeks ago
It helped me! Thanks a lot. I have blinded myself sooooo many times trying to change the modes. Got it today and the number of blinds are >20 already.
This thing is bright. On Turbo it so bright and warm that it burns the skin from 5 cm when held for about 10 seconds. Awesome!
Can’t get it working with the short tube though Sad
Gotta love the Swedish postal service – $9 added to every package from China…
mikemalone
Last seen: 4 years 5 months ago
it in in flash sale at the moment for 25
altonx
Last seen: 2 years 1 month ago
Rolz, as you have both A6 and S1 – could you please check if the tubes are interchangeable or the threads are different in both lights? I’ve read conflicting reports but many people were sent 18350 tubes with wrong threads so this may account for the mess.
Grieflar
Grieflar's picture
Sooo, any hints on making the short tube work? Maybe contact BG for a working one?
EyeballFryer
Last seen: 1 year 2 weeks ago
One thing to try is to reverse the short tube. I learned the hard way that the knurling on the body tube must face towards the HEAD of the flashlight. This is true for both the 18350 and 18650 tubes.
Rolz
Hi Altonx. I just tried the S1 18350 tube on the A6 and it fits well, no thread issues. Testing with a battery it operates as expected.
acolyte
Last seen: 2 years 7 months ago
Received my Astrolux S1 a few days ago and am impressed despite driver issues.
Using a brand new, freshly charged Samsung 30Q the first three modes are identical. Seems they are all Med1, so no Moonlight or Low. Med2 through Turbo seem fine (or “scary”, depending on how you look at it).
Reversing through the UI gives same incorrect modes, in reverse.
Two more anomalies:
- Hidden modes work apart from Batt Check which does not flash despite cheap DMM showing 30Q at 4.17V
- I can’t get into Config Mode despite numerous attempts at 15+ taps, although somewhere along the way I seem to have enabled Mode Memory without any blinking sign that I’d entered Config Mode. User incompetence or broken driver?
The BLF A6 troubleshooting thread reveals a few others with somewhat similar issues so I’m assuming it’s a badly soldered or defective 7135. I’m reluctant to try to open it up and fix this myself so I’m waiting to hear if Banggood will send a new head.
If further confusion were needed it arrives in the form of a $4.95 partial refund BG issued prior to shipping to compensate for an odd error that pushed up the price by that amount after I added it to the shopping cart during a recent flash sale. The order details under My Account show it as simply “Refunded” so I may have an extra hurdle there.
A long time lurker I followed the BLF A6 development from the very beginning, signed up for the GB but held back for QA issues to settle. Finally pulling the trigger has taken me long enough to disqualify me as any kind of serious flashlight enthusiast, no matter what friends may think Wink
Wait a while longer, fingers crossed.
Update 7th June: Banggood CS responds but suggests that it could be faulty switch. I waste a minute testing with knife blade and reply that it is most definitely a faulty driver.
Update 8th June: Banggood CS agrees to send a new head Smile
kamote1half
Last seen: 3 years 5 months ago
Just got mine yesterday and I am pretty impressed with this light. Only thing that i think is missing from this is the Moonlight mode on the 4 mode option, both 7 and 4 modes should have a Moon included. But i’m good, it’s not really a complaint.
Ready. Set. Light.
kamote1half
I have a question about the output of the S1, what are the lumen for the 4 mode config?
Low ?? lumens
Med ?? lumens
High ?? lumens
Turbo ?? lumens
I’m using Olight 3400mAh battery.
Ready. Set. Light.
bugsy36
bugsy36's picture
You will probably have to search the original thread for that answer but the output does change from battery to battery whixh means there arMoonlight however is only available when using 7 modes.
It's the simple things that we take for granted that cost us the most
Ευκαιρία λέει πιάσε με από το μέτωπο γιατί μόλις έχω περάσει δεν θα με πιάσειs
Theodore41
Hi.
I have a Astrolux S1 and I have put in it a “20mm 15 Degree Cree XM-L LED Lens” turning it to a more throw capable light.
So I ask if there is a more narrow beam optic for the same light.
bugsy
Last seen: 4 years 2 months ago
Lens (TIR optic) will have less throw than reflector.
kamote1half
Ready. Set. Light.
kamote1half
Ready. Set. Light.
Rolz
kamote1half wrote:
Are these rubber caps the same fit as the S1? http://www.banggood.com/LED-Flashlight-luminous-Silicon-Button-Switches-...
At work at the moment but will remind myself to check the dimensions of the cap tonight and respond.
Rolz
Checking the spare switch cap supplied with the S1, the dimensions are approximately
14mm(cap diamater)x 18mm(Brim diameter)x 7mm(cap height) x 8mm(total height)
giorgoskok
giorgoskok's picture
Last seen: 2 weeks 6 days ago
This is the right size :
http://kaidomain.com/Product/Details.S024982
Order them , they are very nice …
kamote1half
Thanks a lot for the help guys. I appreciate it.
Ready. Set. Light.
igeigeige
I am having a hard time switching from turbo to strobe, i am still not used to its UI. Sad
wattstar
Last seen: 2 years 2 months ago
I received my second Astrolux S1 today which I was buying as a present, oddly enough it came in a brown box instead a black box like my first one. I thought I would test it and to my disappointment it does not fit the protected cells I have. It appears the wall on the tube is thicker in the newer one, it also had a slightly more matt finish.
This really annoys me as I had originally ordered the Astrolux S2 based on my satisfaction of the S1 and S3 only to find it did not fit protected cells and now it appears the same has happened to the S1.
I do have a couple Keeppower that fit but most of my cells are protected Panasonics. Has anyone else ran into the problem of cells not fitting?
T18
Can you tell me what is wrong with this picture? .. BG says this is not possible.
I am such a trickster I’ll tell ya, now how could I have made a BLF part thread onto a Astro S1, simple really.
Please send video, or picture and sorry for your inconvenience, geez if I ever hear that again I think I’ll crook.
Big time quality control issues, and one nicely blown up light with one click of the switch.
What it should look like:
