Test/Review of Charger Efest LUC Blu6 OLED
5 posts / 0 new
HKJ
HKJ's picture
Last seen: 7 hours 44 min ago
DSC_2837
DSC_2838 DSC_2839
This is a 6 slot LiIon charger with 3 charge current from 0.5A to 2A (Only for two cells).
DSC_2809 DSC_2810 DSC_2811 DSC_2812
DSC_2813
The charger comes in a cardboard box without much information on, but it has a comic on the back. I got the mains lead in a separate box.
DSC_2840
The power input socket is universal voltage (100-240VAC 47-63Hz).
DSC_2830
The charger included the charger, a mains lead, a user manual and a warranty card.
DSC_2931
Welcome message on the display.
DSC_2928
Bluetooth id, this is only needed if you have multiple chargers and want to get the correct one connected to the phone.
DSC_2927 DSC_2932
Usual the display will change between the six slots, showing the status.
DSC_2843
The charger has 7 buttons, one for each slot and one for general functions (Like changing current for selected slot, turning the display off and showing the Bluetooth id). The other six buttons are used to select a slot. The button interface is a bit fiddly, because the charger can be a bit slow to response.
While charging the buttons are flashing blue, this will change to steady blue when the battery is full.
DSC_2845 DSC_2846
The charger uses the usual slider construction and support from 32.6mm to 71.6mm, this means even long protected cells are supported.
supportedBatteryTypes
supportedBatterySizes DSC_2911
DSC_2912 DSC_2913
The low current setting is a bit high for 10440. The charger can handle above 71mm long cells, with both flat and button tops cells.
Phone interface
The charger can be linked to a smart phone, I have tested with a HTC One A7.
Efest6 Efest7 Efest1
While starting the phone shows a percent count, then it goes to the slot view, the one shown here is when no charger is selected.
Press the icon on the top line to select a charger, the phone will automatic search for available Bluetooth devices.
Efest8 Efest4 Efest9
Here the slot view is shown while charging, tapping on any of the slots will show a status for that slot, where it is possible to select charge current. Charge current can be changed at any time during charging. It looks like the charge curve is stored in the charge, the app do not need to run during charge to get the full curve.
The “OLED OFF” text can be tapped to turn the display on the charger off or on again.
Measurements
  • Only slot #1 and #6 supports 2A
  • Any four slots can charge with 1A
  • All slots can charge with 0.5A
  • Total charge current is 4A
  • A battery is recognized at about 1.9 volt.
  • Will pulse charge current from 0 volt.
  • Voltmeter is within 0.03 volt
  • Voltmeter display freezes when charging stops.
  • Current is show in 0.1A steps.
  • Discharged with 1.7mA when power is off.
  • Discharges with 1.4mA when connected to power.
  • Charger will not restart if battery voltage drops.
  • Charger will restart charging after power loss, or battery insertion.
  • Power consumption when idle is 0.6 watt
Efest%20LUC%20Blu6%201A%20(PA18650-31)%20%231
Charge current is not very stable, but that is not important. Generally it is a good CC/CV charge curve, but I would have like the termination current a bit lower.
Efest%20LUC%20Blu6%201A%20(PA18650-31)%20%232
Efest%20LUC%20Blu6%201A%20(PA18650-31)%20%233
Efest%20LUC%20Blu6%201A%20(PA18650-31)%20%234
Efest%20LUC%20Blu6%201A%20(PA18650-31)%20%235
Efest%20LUC%20Blu6%201A%20(PA18650-31)%20%236
All slots looks about the same.
Efest%20LUC%20Blu6%200.5A%20(PA18650-31)%20%231
The termination current is not reduced when charging at 0.5A.
Efest%20LUC%20Blu6%201A%20(SA18650-26)%20%231
No problems with the 2600mAh cell.
Efest%20LUC%20Blu6%201A%20(BE18650-26)%20%231
The older cell shows more noise, but the average is still fine.
Efest%20LUC%20Blu6%200.5A%20(AW18350-IMR)%20%231
Efest%20LUC%20Blu6%200.5A%20(KP14500-08)%20%231
The two small cells are charged, but due to the high termination current they are missing a few percent in a full charge.
Efest%20LUC%20Blu6%200.5A%20(6xPA18650-31)
With 6 cells in the charger it can only charge at 0.5A (Two cells can be charged at 1A). The termination looks a bit premature.
Efest%20LUC%20Blu6%202A%20(2xAWT18650-30)
The 2A charge looks fairly good.
Temp2805
M1: 46,5°C, M2: 42,4°C, M3: 44,9°C, M4: 47,0°C, M5: 45,2°C, HS1: 58,5°C
It is no surprise that a 2A charge generates some heat.
Temp2806
M1: 75,0°C, M2: 38,3°C, M3: 46,2°C, HS1: 88,0°C
And some parts inside the charger gets rather hot.
PowerOn
This charger has a lot of internal functions to initialize, this means it takes about 10 seconds to power on.
CurrentChange
Charge current can be changed at any time.
Testing with 2500 volt and 5000 volt between mains and low volt side, did not show any safety problems.
Conclusion
This charger can charge most sizes of LiIon cells and up to 6 at a time, the charge curve may look at bit noise, but it works fine.
The user interface on the charger works, but not perfectly. The interface on my smart phone works very well.
It would have been nice with more charge current available, but looking at the temperature photos the 4A limit is probably a good idea.
All in all a fairly good charger if you have many LiIon cells to charge.
Notes
will34
will34's picture
Last seen: 1 week 6 days ago
Excellent review as usual, thanks!
In the other forum people have been expecting this charger to compete with the MC3000, I see that will never happen, this one seem to read only voltage and nothing else.
HKJ
HKJ's picture
Yes, this is not an analyzing charger and it only supports LiIon.
wight
Last seen: 2 months 4 weeks ago
Wow, that comic…
Anyway thanks for doing the hard work for us HKJ.
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
djozz
djozz's picture
Last seen: 9 hours 3 min ago
Thanks for the review!
