Test/Review of Imren IMR18650 3000mAh (Yellow)
Official specifications:
  • Weight: 50g
  • Capacity: 3000mAh
  • Length : 65.05mm
  • Diameter: 18.51mm
  • Voltage: 3.7V
  • Excellent high-current discharge performance
  • Model: 18650
  • Material: Li-Mn
Imren has two different 3000mAh cells, both high current.
The discharge curves looks good, nearly constant capacity and very good tracking between the cells.
I had to stop early on the high current discharges to avoid melting my test station.
At 30A the temperature increases very fast, I terminated the discharge after 2 minutes and 30 seconds.
Conclusion
The cells looks good, but they cannot deliver 30A continious.
Notes and links
The battery was supplied by Imren for a review.
This test is run on my updated equipment and is not directly comparable to the other Imren 3000mAh test.
Compare to 18650 and other batteries
Thanks for the test!
Interesting, I thought the Imren purple 3000mAh were HG2s, but they compare badly to the efest 3000mAh purple 2016 (most likely HG2). This yellow Imren however does track nicely vs the efest although sightly inferior. The three-legged top is unique to the 30Q so I’m assuming this is based on the Samsung cell.
Sanyo GA’s have three legged tops as well, but i don’t think it’s them.
Thank you for the testing again HKJ!! I appreciate it!
