Test/Review of Samsung INR18650-35E 3500mAh (Pink)
22 posts / 0 new
HKJ
HKJ's picture
Last seen: 38 min 45 sec ago
DSC_3105
Official specifications:
  • Nominal capacity: 3500mAh
  • Minimum capacity: 3350mAh
  • Nominal voltage: 3,6V – 3,7V
  • Charging voltage: 4,2V
  • Discharge current: 8A
  • Maximum discharge current: 13A
  • Charge current: 0,6C 2000mA
  • Discharge end voltage: 2,65V
  • Pluspol: FlatTop
  • Chemistry: LiNiCoAlO2
  • Diameter: 18,55mm ± 0,1
  • Height: 65,25mm ± 0,15
  • Weight: 48g ± 1
Samsung%20INR18650-35E%203500mAh%20(Pink)-info
This is one of the new high capacity cells.
DSC_3104
DSC_3106 DSC_3107
DSC_3108
DSC_3109
Samsung%20INR18650-35E%203500mAh%20(Pink)-Capacity
The discharge curves has good tracking.
At 15A the B track stops just after 2.3Ah, this is because my battery holder melts (I hope this is fixed now).
Samsung%20INR18650-35E%203500mAh%20(Pink)-Temp-7.0
Samsung%20INR18650-35E%203500mAh%20(Pink)-Temp-10.0
Samsung%20INR18650-35E%203500mAh%20(Pink)-Temp-15.0
15A is definitly too high current for this cell. The cell temperature is above 75°C (25°C ambient + 50°C temperature raise). Logfile says 87°C for A cell.
Samsung%20INR18650-35E%203500mAh%20(Pink)-CapacityTimeHours
On this chart it is obvious how the heat improves the performance at 15A.
Samsung%20INR18650-35E%203500mAh%20(Pink)-Energy
Samsung%20INR18650-35E%203500mAh%20(Pink)-PowerLoadTime
Samsung%20INR18650-35E%203500mAh%20(Pink)-TripCurrent
Due to the melted battery holder I did only do this for one cell.
Samsung%20INR18650-35E%203500mAh%20(Pink)-Charge
Conclusion
The cell looks very good, it has lot of capacity and can handle some current, but I will not recommend it above 10A.
Notes and links
Compare to 18650 and other batteries
The Miller
The Miller's picture
Thanks for the review
You write:
“On this chart it is obvious how the heat improves the performance at 15A.”
You mean “is rising” or “is going up” instead of improves right?
Or are those bump in the charts actual improved preformance linked to heat?
HKJ
HKJ's picture
You write:
The bumps are improved performance due to heat, the chemical reactions goes faster when the cell is hot (This do also wear the cell down faster).
akhyar
akhyar's picture
Last seen: 1 year 2 weeks ago
Thanks for the review HKJ.
Seems like the latest high capacity cells, like this one, Sanyo GA and LG MJ1 are good for up to 10A
light-wolff
Last seen: 3 weeks 4 days ago
AFAIK the 35E are rated for 8A continuous. I stopped testing at 10A. Driving them to 15A is just battery (and cell holder) torturing – for the sake of science Wink
HarleyQuin
HarleyQuin's picture
Last seen: 1 year 1 month ago
Thanks for testing !
Oshpark Boards:
HQ ProgKey: Universal Driver Programming Key . Boost: HQ 15mm/17mm programmable boost driver with ATtiny13A
46mm Triple-Channel: BLF SRK FET v3 . 17mm Linear: HQ10D / HQ4D / HQ4S . Contact Boards: 22/24/26mm
bugsy
Last seen: 3 years 5 months ago
Been waiting for this one for a while. Now all we need are the 30Q, GA, HG2, and MJ1.
will34
will34's picture
Last seen: 23 hours 6 sec ago
Thanks very much for the test! I will put these in a power bank, according to the chart they are superior to the GA in all low discharge rates. But they seem to be out of stock everywhere?
I’m 90% sure HKJ has already tested the 30Q, GA, MJ1 and HG2, but in rewrapped versions.
This IS the GA
http://lygte-info.dk/review/batteries2012/Evva%2018650%203500mAh%20%28Bl...
I assume this is the 30Q
http://lygte-info.dk/review/batteries2012/Imren%20IMR18650%203000mAh%20%...
I assume this is the HG2
http://lygte-info.dk/review/batteries2012/Efest%20IMR18650%203000mAh%20%...
I think this is the MJ1
http://lygte-info.dk/review/batteries2012/Imren%20IMR18650%203500mAh%20%...
Althought, the curves for the Imren green and EVVA black are identical up to 5A, but the imren green top doesn’t match the GA 3-leg raised top.
MG
Thanks for another supremely useful test.
bugsy
will34 wrote:
This IS the GA
http://lygte-info.dk/review/batteries2012/Common18650IndividualTest%20UK...
Thanks, but the link you posted for HG2 seems to be wrong. The Imren 3500mah does not look like the MJ1 at all to me.
will34
will34's picture
Oops sorry, I meant to link this one
http://lygte-info.dk/review/batteries2012/Efest%20IMR18650%203000mAh%20%28Purple%29%202016%20UK.html
It's been said by many here that this the HG2, the performance at 5A+ is sightly better than the 30Q.
1dash1
1dash1's picture
Last seen: 9 months 2 weeks ago
This IS the GA
I researched the web and could confirm/partially confirm two of your assumptions.
Confirmed: Sanyo NCR18650GA 3500mAh = EVVA 18650 3500mAh (Black). [Reference RMM]
No information found: Imren IMR18650 3000mAh (Yellow) ~ Sanyo INR18650-30Q 3000mAh.
No information found: Efest IMR18650 3000mAh (Purple) ~ LG INR18650-HG2 3000mAh.
Note: The Efest IMR18650 3000mAh (Purple) may or may not be Samsung INR18650-30Q 3000mah. [Reference Mooch]
Mooch is the resident battery expert at E-Cigarette Forums, like HKJ is our expert. He says that there are multiple versions of the purple Efest cell. The three-pronged positive terminal version is probably a 30Q. He hasn’t tested the 4-pronged version. The picture of the one HKJ tested shows 4 prongs. So, my interpretation of this is that “maybe it is, maybe it isn’t” a 30Q.
Yes and No: Imren IMR18650 3500mAh (Green) = LG MJ1 18650 3500mAh. [Reference Mooch]
Note: Mooch states that there are two versions of the Imren battery. One is a Panasonic NCR18650GA 3300mAh, the other is an LG MJ1 3500mAh.
Unless there is further documentation, I’d suggest that HKJ has not already tested the 30Q or HG2 batteries in any form.
What do you say, HKJ? Innocent
Rule 1-1 as it applies to life, take it as it comes.
light-wolff
You could just look at my reviews of the mentioned cells posted here on BLF. The discharge curves are as good as HKJ’s.
will34
will34's picture
I often look for your charts here and on CPF but sometimes I can’t find a specific one that I’ve seen before, I think you could make index thread with all your reviewed batteries and put the link in your signature, that would be really helpful!
1dash1
1dash1's picture
I hope you weren’t responding to me. I merely attempted to confirm what HKJ said (or implied) about the Sanyo NCR18650GA, Sanyo INR18650-30Q, LG INR18650-HG2, and the LG MJ1 18650 batteries. I was not looking for what other people’s tests had found regarding these batteries.
If you were responding to Bugsy’s post #7, I found your tests of the GA, 30Q, and MJ1, as follows:
- http://budgetlightforum.com/node/42145
- http://budgetlightforum.com/node/42074
Can you point me to your test results for the HG2?
light-wolff
Could be that I haven’t posted these on BLF. Way OT, but here are the HG2 vs 30Q discharge curves:
1dash1
1dash1's picture
Thanks Light-wolff. Smile
SubLGT
Last seen: 1 day 4 hours ago
You can also see discharge curves at 2A, 3A, and 5A for these 4 cells at http://www.dampfakkus.de/akku_auswahl.php
will34
will34's picture
Anyone know where to get these 35E? I’ve been searching and everywhere is out of stock.
Hobo
Last seen: 7 hours 59 min ago
Banggood uses your graphs in their product description. Did they ask you? Shocked
INR18650-35E
8) Lube Threads Everyday 8)
chrisc
Last seen: 5 months 6 days ago
Hobo wrote:
Banggood uses your graphs in their product description. Did they ask you? Shocked INR18650-35E
It’s okay as they are watermarked “BANGGOOD” …. Shocked
how cheeky if they havent
HKJ
HKJ's picture
They have probably asked at some time, but not about that battery and they are not following the conditions I told:
I always say people are welcome to use chart and images from my website, as long as they include a link to my website or the actual review.
Generally I do not try to keep my data for myself. I do frequently get questions about access to the raw data for a few cells (Often students doing a project) and they always get them. Somebody asking for all my raw data got a no.
