Low-cost copper pills, spacers, optics, drop-ins. Custom parts.
1675 posts / 0 new
redhawk
redhawk's picture
Received my 2nd order today, thanks kiriba-ru! Everything was nicely packaged and arrived in good condition. Can’t wait to put the x7 triple together : ), just waiting for some other parts from elsewhere. Also looking forward to seeing how your q8 12 led mod develops!
kiriba-ru
kiriba-ru's picture
Last seen: 2 days 20 hours ago
2018_01_28_19_26_02
Tail+medium boards for 2S2P or 4S mod (both are oversized (47mm) so you need dremel to sand them down)
4 x brass buttons
4 x springs
8 x M2.5×6 hex screws
$1 set without wrench
$2 set with usa-made 1.5mm hex L-wrench
kiriba-ru
kiriba-ru's picture
kiriba-ru wrote:
preview
One respectable seller forget to ship out some parts for this project, so it is delayed Tired
steel_1024
steel_1024's picture
Last seen: 6 days 6 hours ago
kiriba-ru wrote:
Tail+medium boards for 2S2P or 4S mod (both are oversized (47mm) so you need dremel to sand them down) 4 x brass buttons 4 x springs 8 x M2.5×6 hex screws $1 set without wrench $2 set with usa-made 1.5mm hex L-wrench
Can I order it?
Sorry for my poor english.
kiriba-ru
kiriba-ru's picture
Sure.
If you know what to do with them.
I will have some more suitable rings (existing positive q8 rings a too thick to use a pair of them in such config) soon, if you need them you can wait about a week.
kiriba-ru
kiriba-ru's picture
BTW, if Im not mistaken I have contacted you with PM about solid brass tail boards. Still would like to know your opinion.
steel_1024
I can not express my correct meaning in English.
SG3
SG3's picture
Last seen: 9 months 5 hours ago
I’m sorry if I missed this in a prior post but, P60 solid Cu 18350 neck+S2+ Cu pill inside $25 155 g…what is this?
"Yes, I'm a custom knife maker who is afraid of the dark..."
-Me
kiriba-ru
kiriba-ru's picture
This is drop-in substitute. You can build full head and change them “on the way”.
Upd.
This set was made for quad build. But if you have shorter pill you can use single led with some optics or reflector.
http://budgetlightforum.com/comment/1033063#comment-1033063
Kenjii
Kenjii's picture
Last seen: 1 year 1 month ago
Hi,
one of one Crown Jaxman Mini C8 Quad. 4x Nichia D280, FET Driver and some GITD. Nice work!
Regards
Kenjii
contactcr
Last seen: 10 hours 35 min ago
Damn i’ve missed all the good quad spacer runs
I want an M8 quad!
kiriba-ru
kiriba-ru's picture
Kenjii got full height pill for M8, not simple spacer.
contactcr
Sure that works too. Take my money
kiriba-ru
kiriba-ru's picture
I wouldnt make more of such pills. I can think about spacers, but not sure that M8 (with brass pill) is suitable host for this.
contactcr
Is the full pill too difficult to make or too expensive to sell? I know the M1 had the expensive optics and machining but people seem to like the quad kits dont they?
kiriba-ru
kiriba-ru's picture
It is too difficult to make by small quantities. I cant get calibration tool for threads when they are not standart size, so pill should be machined and test fit and then again machined etc. until it fits.
I dont feel M1 or M8 host suitable for 24mm carclo optics when M2 is available. It is smaller, available as bare host, and imo looks great, specially with gitd o-ring. I think M2 kit was 3 times more popular then M1.
alberto7
Last seen: 2 weeks 9 hours ago
So, convoy m2 actually looks like the perfect host for small quad.
kiriba-ru
kiriba-ru's picture
Will make them if will get enough requests.
crz6662
crz6662's picture
Last seen: 2 months 3 days ago
kiriba-ru wrote:
It is too difficult to make by small quantities. I cant get calibration tool for threads when they are not standart size, so pill should be machined and test fit and then again machined etc. until it fits. I dont feel M1 or M8 host suitable for 24mm carclo optics when M2 is available. It is smaller, available as bare host, and imo looks great, specially with gitd o-ring. I think M2 kit was 3 times more popular then M1.
I have a 24mm carclo optics in my M1 that I built a quad XPL-Hi. The optics is a bit on the small side though. Could be possibly 2mm-3mm larger and then It would cover the edge of the home made copper heatsink I made, but it works fine.
kiriba-ru
kiriba-ru's picture
Thinking about more M2 kits (does liner ring requires changes or no).
Can anyone else confirm same problems?
http://budgetlightforum.com/comment/1220708#comment-1220708
Note 1: In my suppose stock thin o-ring was placed between bezel and glass lenses. I recommend to save this in quad mod.
Note 2: More recent version have already had thicker GITD o-ring
steel_1024
Yes
M2 is the situation
kiriba-ru
kiriba-ru's picture
Can you put stock o-ring between glass and bezel?
steel_1024
kiriba-ru
kiriba-ru's picture
Yes I know. I have already made improved version with bigger o-ring groove and gitd o-ring.
I mean can you fix stock o-ring between glass and bezel? (Is it proper size or no).
steel_1024
No
O-ring is smaller, not thick enough too.
kiriba-ru
kiriba-ru's picture
Got it, will check original drawings and make changes.
Pulsar
Pulsar's picture
Last seen: 4 months 1 week ago
Can you do a dropin for a c cell mag?
kiriba-ru
kiriba-ru's picture
I dont feel Mag sets popular, but I can try to make any parts by custom drawing.
kiriba-ru
kiriba-ru's picture
steel_1024 wrote:
Yes
M2 is the situation
!https://i.imgur.com/RewzNwS.png!
Any ideas how does same o-ring work with reflector?
Icarus
Icarus's picture
Last seen: 1 day 4 hours ago
kiriba-ru wrote:
I will have one special option for C8 soon….
I’m really curious what this will be. Any hints? Smile
