Test/Review of Blitzwolf 2 port car charger BW-C4
6 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 hours 13 min ago
DSC_3350
Official specifications:
  • Input: DC 12-18V (Max)
  • Output: 5V/2.4A *2
  • Power: 24W
  • Size: 61*28*28mm
  • Brand: BlitzWolf®
I got it from Banggood
DSC_3347
Blitzwolf uses a brown cardboard box without much text on the outside.
DSC_3348
The box contained the charger and a note.
DSC_3351
DSC_3352
DSC_3353DSC_3355DSC_3354
There is a blue led behind the small hole.
Measurements
  • Power consumption when idle is 0.03 watt
  • The 2 usb outputs are in parallel.
  • The 2 usb outputs are auto coding with Apple 2.5A as maximum.
  • No individual port overload protection.
Load%20sweep%2011.6V
Load%20sweep%2014.6V
It do not have any individual port protection and can deliver up to 8A. Efficiency is very good in the rated range (Up to 4.8A).
Voltage%20sweep%204.8A%20input%20current
With 4.8A output it needs about 2.3A at 12V.
Output voltage is stable with changing input voltage.
No%20load%20voltage%20sweep
Idle current is about 2.5mA.
Load%20test%204.8A
A one hour test with 4.8A load was no problem.
The temperature photos below are taken between 30 minutes and 60 minutes into the one hour test.
Temp2892
M1: 37,3°C, M2: 36,5°C, M3: 38,6°C, HS1: 50,4°C
Temp2893
M1: 39,7°C, M2: 37,4°C, M3: 36,5°C, HS1: 45,6°C
Temp2894
M1: 43,9°C, HS1: 49,3°C
10ohm
At 0.5A with 12V input the noise is 21mV rms and 180mVpp.
5ohm
At 1A with 12V input the noise is 11mV rms and 130mVpp.
2ohm
At 2.5A with 12V input the noise is 12mV rms and 150mVpp.
1ohm
At 5A with 12V input the noise is 45mV rms and 168mVpp.
Tear down
DSC_3520
Cutting the front of the aluminium I could unscrew the circuit board and pull it out.
DSC_3521
The inductor has two wires in parallel to handle the current. The white part beside the spring looks like a fuse.
DSC_3522
The chip is a G5309 10A switcher, this explain why it can deliver about 8A.
DSC_3523
DSC_3524
DSC_3525 DSC_3526
The chip marked U1 handles the automatic coding of the usb outputs. A small white part can be seen beside one of the usb connectors, it is the led.
DSC_3527
DSC_3528
Here the auto coding chip is easier to see.
Being a 12V device there is no need to test with high voltages.
Conclusion
This car charger can deliver lots of power, in my opinion a bit to much for the usb cables, but it is still a good charger.
Notes
The usb charger was supplied by Banggood for a review.
Read more about how I test USB power supplies/charger
stonew508
Last seen: 1 year 3 months ago
I’ve checked all the reviews here and with Nathan k. And seems there’s no super safe car charger for my pixel phone. Did I miss any of yours that passed the gauntlet?
HKJ
HKJ's picture
If you mean a car charger with correct overload protection, you are probably correct.
stonew508
Thank you for responding and for your reviews
Nathan K
Nathan K's picture
HKJ, have you ever tested the Belkin F7U005bt04-BLK? It seemed “okay”. I’m curious how a “first rate” company builds their product.
It is actually fully compliant, per my testing. It just happens to have a hardware quirk that makes the Pixel phone in particular not work well. (Voltage drops below 4.95v exactly, so the Pixel phone will stop drawing current.) On the upside, it has $2,500 USD insurance if anything does go wrong!
http://www.belkin.com/us/p/P-F7U005/
Here’s the (meager) writeup I did. It lacks a lot of the details you check for, so please pardon that. Sad I do not have access to a variable DC load or PSU unfortunately.
https://plus.google.com/102612254593917101378/posts/dgqeFSM19bd
Here’s a picture of its overcurrent protection: it appears software-based.
And here’s a picture of the “4.95v bug” I was referring to: it should be charging at ~3a or so (+/-30%), per my previous tests.
PS: Actually, is there any way I can sponsor your tests? Is there an Amazon wishlist I can purchase the Belkin from and send it to you? I will move this thought over to your “request” thread.
HKJ
HKJ's picture
You can always check my website for review, but it do not look like I have tested a Belkin.
People can ship chargers for review (Preferable in original packing) or order directly to me.
