KD U2 5 mode drop in $10.98
5 posts / 0 new
E1320
E1320's picture
Last seen: 2 years 3 months ago
http://kaidomain.com/ProductDetails.aspx?ProductID=11254
It looks like the same driver DX is using in there $15 non U2 XML 5 mode. Direct drive on high should be very bright.
I am already visualizing the duct tape over your mouth.
Edited by: E1320 on 09/22/2011 - 22:46
VFMaddict
Last seen: 1 year 1 month ago
Which, "non XML 5 mode" ?     Q5, R2, XPG......?
"You are making progress if each mistake you make is a new one."
Remember - Most great discoveries start with maki
E1320
E1320's picture
Sorry I fixed it. This drop in used to be 1.4 amps max with an AK47 drive. DX went to this driver with the yellow ring on the back. I got the 1.4 amp one converted it to 3 mode ordered 2 more and got the yellow ring direct drive driver. I took it apart to try to convert it 3 mode like the AK it looked the same as the KD driver inside.
http://www.dealextreme.com/p/cree-xml-t6-5-mode-6700k-450-lumen-smooth-a...
df2dot
Last seen: 2 years 2 months ago
not bad, wonder how bad the PWM is compared to others.
i have a few torches with zero PWM viewable and will never get something that doesnt have a high quality driver.
a current njang brand(or whatever ) ak-47 driver i have is flawless also fenix e21, but i unknowingly got a couple with bad PWMed lights. no point in living with that. esp low mode at close range
also the high pitch squeals !!
E1320
E1320's picture
The Nanjg had no PWN but did squeal on medium which doesn't bother me.
That yellow back driver does have pretty bad PWN, but it blazes at almost 4 amps on high and the strobe is ridiculously bright and annoying.
