FS: Copper "BIG RET" S2+ triple heatsinks [IN STOCK NOW. LAST RUN EVER.]
485 posts / 0 new
Hoop
Hoop's picture
Last seen: 2 days 12 hours ago
Dear BLF,
I make heatsinks.
To order, send me a PM.
Prices are in USD. Payments made via Paypal.
Add $3 to the total for USA shipping. Add $13.50 for Canada and International shipping.
Please pay as “goods and services” and include your BLF handle and what you are ordering in the Paypal note.
Copper “BIG RET” S2+ heatsinks:
This heatsink features a large retaining ring and works with drivers that have components on one or both sides.
Notes:
-DOES NOT FIT the “litnit” branded copper s2+. Might not fit other copper s2+s either. If it doesn’t thread in easily it is not going to work. Don’t try to force it.
-The pill threads will not come greased. I recommend applying a small amount of grease to the OD threads of the pill to prevent galling/binding of the bare metals, and to additionally help with thermal transfer.
-Has a 7.1mm deep driver pocket to accommodate tall inductors.
-Use external retaining ring pliers with small tips. Recommended tip: 1.2mm [.047”]
-The retaining ring is used to drive the heatsink into the light.
-The retaining ring will also unscrew the heatsink from the light. The retaining ring is designed to flex outward from moderate plier force, effectively locking it into the heatsink. If the ret ring starts to come out before the pill, just grip your pliers harder.
-Includes a brass contact button: 5mm diameter x 2mm height
Single Emitter Heatsink: [16mm star, 17mm driver.] | $15 each SOLD OUT
Triple Emitter Heatsink: [20mm star, 17mm driver.] | $15 each
Edited by: Hoop on 11/15/2019 - 22:55
Hoop
Hoop's picture
Reserved.
Rufusbduck
Rufusbduck's picture
Last seen: 10 months 2 weeks ago
You can put me down for an S2+
Scott
unknown00101
Beautiful piece of copper!
I don’t have a need for the others, but a copper D mag sink sounds awesome.
troisanh
Last seen: 4 months 4 weeks ago
Put me down for 1 s2+ cu-sink, thanks.
Rob_K
Last seen: 2 years 1 month ago
Can you make one for Small Sun ZY-T08 and Courui D01 before you make C8 ones ? Wink
WillyD
Last seen: 2 weeks 4 days ago
Those look wonderful. Does the copper offer better heat sinking than the stock bras pill?
Rufusbduck
Copper is a better conductor of heat than brass so the temperature of an led on copper will generally be lower than one on brass. The highest temp is at the diode junction but improving thermal conductivity shunts the heat farther and faster.
Scott
WillyD
Thank you. In that case, put me down for 1 please.
Hoop
Hoop's picture
unknown00101 wrote:
Beautiful piece of copper! I don’t have a need for the others, but a copper D mag sink sounds awesome.
Blushing Good to hear! I hope to impress everyone with my mag heatsink.
I am currently making the C8’s and have the copper for D01’s. I will look into the ZY-T08 though!
Yep, like Rufus mentioned, copper’s superior thermal conductivity should offer lower LED junction temperatures, which is pretty important when you are substantially overdriving an LED. Brass isn’t as good of a conductor of heat as either aluminum or copper. Their thermal conductivities are:
C110 Copper: 388 W/(m K)
6061 Aluminum: 167 W/(m K)
C360 Brass: 115 W/(m K)
kiriba-ru
kiriba-ru's picture
Last seen: 11 min 16 sec ago
Brilliant job, but why threads are so square? All convoys except of mid-C8 have standart metric 60 degrees threads.
Hoop
Hoop's picture
Thanks. The Convoy’s do have 60 degree triangular threads, but they are not a standard profile; they are truncated, which is to say the tips are cut off. I measured the pitch, pitch diameter, and the OD of the stock heatsink’s thread and reproduced it, after which point I increased the pitch diameter until the slop went away. Because I did not also increase the outside diameter of the heatsink, the result of increasing just the pitch diameter is a wider crest.
There really is a lot of play in the stock threads, and I got rid of it. Now I need to see if they will be too tight for anyone. This is why I am doing a small batch at first.
kiriba-ru
kiriba-ru's picture
Not sure that this is best solution
imagebam.com
Hoop
Hoop's picture
You’ll just have to trust that I know how to make threads, and that I made the only adjustment possible in order to remove most of the slop, which is increasing the pitch diameter.
On my S2+‘s (3 of them) these heatsinks install smoothly. They do not bind up or anything.
kiriba-ru
kiriba-ru's picture
Ok, what is OD of this pills?
Hoop
Hoop's picture
.855” ( 21.72mm )
kiriba-ru
kiriba-ru's picture
I`ll take some from the next run.
Gunga
Gunga's picture
Last seen: 4 hours 10 min ago
Are you making a triple pill?
Hoop
Hoop's picture
No plans for triples at the moment. I figure the guys with manual lathes can handle that. I’ll focus on the tricky stuff. Feel free to propose something though and I’ll consider it.
Another note regarding the heatsink threads and how they fit: there was quite a bit of dirt and crap in the threads of the heads of my S2+‘s…. I cleaned them all out with a small brush before determining fitment.
kiriba-ru
kiriba-ru's picture
Maybe you can make SS bezels for good price?
Many people would like to have them but they are out of our abilities.
Hoop
Hoop's picture
Hmm, that might be fun. I do intend to make them for Mags at least. If made from 416SS they can be hardened to better than 36 rockwell C. I would need to get a vibratory polishing bowl and some polishing media to give them a proper finish. Wouldn’t want to see any tooling marks on a bezel.
Charga
Charga's picture
Last seen: 1 day 22 hours ago
Put me down for one, please!
How much is the shipping to germany!?
' Lumen est omen '
Hope is no option!
Lilien
Last seen: 10 months 1 week ago
First of all, they look very nicely made! I would really like to see also a tripple version. A shame the International shipping is so high in your country. Sad
But with the recent steady development of the driver firmware (great work there), I have no good feeling about permanently solder a driver to the pill.
Why not use the retaining ring approach of the original pill? It should be even possible to reuse the threaded retaining ring of the original brass pill.
KawiBoy1428
KawiBoy1428's picture
Last seen: 9 hours 15 min ago
Maybe a internal snap ring could be used to retain the driver, I have done this on my X6 copper pressed in pill, retaining a 26mm Mtn FETDD driver. It was easier cutting a internal ring groove, then making a threaded retaining ring and threading the pill? Just a thought?
KB1428 “Live Life WOT
tristanxoxo
Last seen: 6 months 3 weeks ago
Could the shelf of the pill perhaps be thicker. I think since a lot of us will be using FET drivers, I don’t think the extra space for the driver is necessary. It would be nice to have even more copper in the pill.
BTW, these are absolutely gorgeous!
kiriba-ru
kiriba-ru's picture
I can share its drawing with you if this would make evaluating faster.
sp5it
sp5it's picture
Last seen: 6 hours 25 min ago
International ship to Poland First-Class Mail® International Large Envelope** costs 9.20 only.
Mike
Think of how stupid the average person is, and realize half of them are stupider than that. George Carlin
 Anyone offended by my signature please fill Complaint Form. Thank you.
flashination
Last seen: 1 year 1 month ago
You can put me down for an S2+ also.
'I pledge not to get drawn into cpf/blf arguments, & just understand that both places have their own merits'.
will34
will34's picture
Last seen: 4 days 20 hours ago
This pill looks beautifully done, but I already ordered some with spacer from kiriba.
Do you have any plans on making a heatsink/spacer for the Cu X5?
hank
hank's picture
Last seen: 7 min 28 sec ago
> D-mag
Does it make a difference which version? Some have “D” as the first character in the serial number; others don’t, sizes differ a bit internally
MG
I am up for one S2+ Cu-sink.
And thanks for the terrific job on the emitter rings just received.
