Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
17140 posts / 0 new
Tom E
Tom E's picture
Last seen: 2 days 5 hours ago
jamaya wrote:
hi can i buy one of these blf q8 flashlights?
Yes, you can get added to the list.
Not much comm. from Thorfire on details, but definitely, actually being assembled in quantity now. They told us 2 weeks, but assuming no issues, delays, etc...
cccpull
cccpull's picture
Last seen: 4 months 4 weeks ago
How many lights in the batch?
Giraffelight
Giraffelight's picture
Last seen: 8 months 3 weeks ago
I’ve put off getting in on one of these group buys for so long, but this light will be the one to drag me into the fold. Put me down for one please
Tom E
Tom E's picture
Thought 1st batch is 500, not totally sure though.
The Miller
The Miller's picture
Yes it is my understanding 500
Will update list, thanks for the kind words and trust!
feralcomprehension
  Would love to know any information about the timing 'between' batches; both my spots are in batch 3 if they're done in lots of 500.
DB Custom
DB Custom's picture
Last seen: 1 hour 42 min ago
Sorry so late to reply… I had the copper buttons from buying Old-Lumens modding stock. I think he bought an assortment from someplace on ebay. I don’t know for sure where he got them.
1/4” brass bar stock works great to make these, even by cutting off a short piece and sticking it in a drill then useing a cut off wheel on a dremel or even a hacksaw to cut off buttons of whatever depth (thickness) you require. Wink
Dale
cdjaney
cdjaney's picture
Last seen: 3 days 6 hours ago
Texas_Ace wrote:
The IR tests in most chargers is inconsistent and not comparable between different models due to different methods of calculating the IR.
That said the cells should be reading fairly close if tested in the same way, on the same charger, at the same starting voltage.
36 to 96 is an extreme range. I would retest and if it is the same results then you might have fake cells. Where did you get them?
I hesitated to say “where” because I don’t want any rumors spreading from my inexperienced info. I will say the place I got them from has been vouched for by several members here and is U.S. based. I got them because they were on a bit of a sale at $5 each (down from a usual $6.50 each) and decided on them because of what appeared to be the minimal benefit gained with the button top 30Q’s (and of course longer runtimes with the GA’s).
To your point of “inconsistent” tests….I’ve read that several times here and hesitated to post because of it….and to DRIVE THAT POINT HOME…..upon putting the batteries back on the charger to FAST TEST again (after they had rested for several hours) and NONE of them read over 42mr. In fact, the one that DID read 96mr earlier, is now reading 17mr. SO….in consistent? I’d say.
The good news is (to me at least), they did all read in the low to mid 3400mah range….so at least that part seems true. Smile
John 1:5 "The Light shines in the darkness, and the darkness did not comprehend it."
spinynorman
Last seen: 5 hours 8 min ago
I would imagine they squeeze in production of the Q8 in between production of their regular product line. Might be difficult to predict wait time between batches.
winspiration
Can I be put on the list? Thanks.
JasonWW
JasonWW's picture
Last seen: 1 hour 8 min ago
DBSAR wrote:
Any predicted date/time when they are ready to order?
From a few posts earlier.
My Convoy L6 thread with XHP70.2, Texas Avenger FET driver, Narsil v1.2 ramping firmware, lighted side switch and cut down SMO reflector. Lots of amp draws on stock driver as well.
My Supfire L5-S thread with XHP70, Texas Avenger FET driver, NarsilM v1.0 ramping firmware and lighted side switch. My mini L6!
9 NarsilM user videos including GT
Texas_Ace BLF Calibrated Lumen tube
Couchmaster
Last seen: 3 days 18 hours ago
Tom E wrote:
Not much comm. from Thorfire on details, but definitely, actually being assembled in quantity now. They told us 2 weeks, but assuming no issues, delays, etc…
Appropo nothing, but speaking only for myself, I’d rather they come in at the end of September perfect than they come in at the end of August with issues. Lets give Thorfire time to make them right the first time through.
BrianK
Last seen: 3 weeks 5 days ago
Absolutely! No hurry, get it right first, and not first to get it wrong.
tigris99
Last seen: 9 months 6 days ago
Wow really happy to see this is coming to reality. Glad i Posted early on to make sure i hit first batch, thanks for all the hardwork guys!!!
4everAwake
4everAwake's picture
Last seen: 4 months 2 days ago
How much will the Q8 weigh (without batteries)? I did a search, but I couldn’t find anything regarding this.
The Miller
Yes will update list later.
Weight is not mentioned? I remember Tom posting it but next time I grab the Q8 I will put it on a scale.
cdjaney, I break contact by sliding cells away from the +contact a few times and go with the lowest I see in say 5 times IR showing.
When normal charging I don’t pay much attention to the IR measurements unless it shows 80 or higher, then I check it a few times for that particular cell.
Agro
Last seen: 7 min 12 sec ago
After playing with D4 for a couple of days I get thoughts “Do I really want Q8 too?…”.
djozz
djozz's picture
Last seen: 11 min 58 sec ago
I have both, and I love the D4, but the Q8 gets different use: my D4 does 10 second 2800 lumen bursts on turbo (new high CRI leds), the Q8 does over 6000 for 3 minutes (=18 times longer), the D4 can run contuously tailstanding at 300/400 lumen, the Q8 at 2000.
But I agree that the D4 is something special!
link to djozz tests
“I used to think that top environmental problems were biodiversity loss, ecosystem collapse and climate change. I thought that thirty years of good science could address these problems. I was wrong. The top environmental problems are selfishness, greed and apathy, and to deal with these we need a cultural and spiritual transformation. And we scientists don’t know how to do that.”   (Gus Speth)
whitecitadel
Last seen: 3 months 5 days ago
niktak11 wrote:
I thought it was ~10x the power output needed to appear twice as bright. Same as how apparent loudness works
JasonWW wrote:
Also, light and sound do not double the same.
Some bed time reading if you really want to know about the Inverse Square Law:
https://en.wikipedia.org/wiki/Inverse-square_law
Sound is same principle but not the same rule (explained on wikipedia), in case you wondered SmileGrad
You can always ask a photographer, as flash photography requires a good understanding of when to move lights closer, and how much power you will need if you move them further away…
whitecitadel
Tom E wrote:
1st production batch is being made.
Great deal on 30Q BT’s from freeme in the OP here: http://budgetlightforum.com/node/55113. It’s publicly posted so I’d say it’s fair game.
But be warned: this is a one time use coupon code!! But $17.75 for 4 30Q BT’s shipped is outstanding. I ordered 2 sets of 4 with this coupon code and got the 15% off of both sets.
I believe from my battery tests, VTC5A’s solder tops did the best slightly, at first, but VTC6 solder tops don’t drop as quick. Again, VTC6’s are just slightly better than 30Q’s relatively. GA’s aren’t bad, better runtimes because max amps is lower and capacity is higher.
Also another thread with a deal is: http://budgetlightforum.com/node/54513
JasonWW
JasonWW's picture
We were not talking about the inverse square law. We were talking about how the eyes, ears and brain perceive a doubling of either light or sound. It’s more of a psychological thing and not so much a mathematical equation.
whitecitadel
Laws of physics still apply, not matter what your brain thinks…
In terms of Q8, max output is still insane if measured or perceived Wink
JasonWW
JasonWW's picture
True, but that’s still not the subject we were talking about.
Dimking
Last seen: 6 days 2 hours ago
The Miller
You said you have the actual production videos. Can you upload them for us?
djozz
djozz's picture
In biology, laws of physics do apply, but it is a disordered interaction of so many physics equations that no result can ever be calculated. Biologists need a complete different tool set than the clear Newton’s equations, the ‘laws’ that biologists use are an extract of real life measurements that may or may not be applied to new situations. (see also ‘fuzzy logic’ Smile )
In case of the sensitivity of the human eye you may look for a measured light level/human perception curve and that will certainly not be lineair or simple logarithmic.
link to djozz tests
The Miller
Dimking wrote:
The Miller
Oh cr@p being a bit sick with a mild fever and busy so no time to rest made me forget this
Will try to do it today
djozz
djozz's picture
Not nearly a production video, a few fragments of some first machining steps. Still nice to see though. Smile
link to djozz tests
sparkyDK
Last seen: 5 hours 50 min ago
“Laws of physics still apply, not matter what your brain thinks… “
Yes.
But.
https://en.wikipedia.org/wiki/Model-dependent_realism
teacher
teacher's picture
Last seen: 2 min 33 sec ago
cdjaney wrote:
Question….feel free to tell me to post elsewhere. Smile
I got some Sanyo 3500 GA’s..button top…in preparation for this light.
My question….
I did a FAST TEST on my Lii500 just because and the internal resistances ranged from 38 to 96.
Should this concern me for performance? In looking at the battery comparator, the GA’s tested there were listed at 35 I think.
Thanks for any input.
The IR test function of the Lii 500 is unreliable. I have a couple & love the chargers but just be aware the IR test results are not very reliable.
Check out HKJ’s review for more info.
      You never know how a horse will pull until you hook him up to a heavy load. / Paul "Bear" Bryant ~/~\~ "Slow is Smooth, Smooth is Fast"
       Texas Lumens Flashlights  <>   M4D M4X Deals : sign up - save $$$$    ||||
         Rudeness Level /\ mΩ /\ {width:70%} /\ LightWiki /\ LED Tint Chart /\ LED Tint Picture /\ Xlamp size chart /\ BatteryU                   Flashaholic? Need Professional Help???   wink   /\ TheOriginal /\ TAB /\ LightSearch /\ BatterySearch /\ 14500's /\ DiCal
The Miller
And here are the videos and pictures combined!
