Soo… right before bed last night, BOOM, my Q8s are now shipped! WooHoo! I was sad thinking I wouldn’t get one before Halloween. Now I will be able to blind all the punks in the park in one fell swoop…
“Facts don’t care about your feelings.”
~Ben Shapiro
Today I also finally received my Q8. It´s a great light so a BIG thanks to the development team. The little imperfections with mine are of centered LEDs, unequally bright Switch LEDs, the dirty contact ring and a fingerprint on the glass lens. Nevertheless, it is an awesome flashlight. Especially for this price it is a hell of a deal.
We regret to inform you that we can not ship your order to an address containing “P.O. Box”. Could you please send us your shipping address by filling in the fields listed here below?
Oh the humanity! More delay.
I don’t ever recall a “PO Box” issue before with BG or any other Asian shop. But it sounds like my Q8 is getting closer.
Got the emails from BG last night saying my two Pre Orders were Shipped…..
… Which means LABELCREATED(I’m sure for mine anyway PO’s in 1680’s & 1750’s).
Be interesting to see when they really do ship… before or after the upcoming Chinese Holiday. Either way is good. Glad to see how fast TF worked this out.
.................................. "Slow is Smooth, Smooth is Fast" ...................................
That is strange. Did you do some type expedited shipping?? Or the free that comes through FEDEX SmartPost. (in the case of the GB Q8’s anyway)
I have never had a problem with delivery to a PO Box with Smart Post.
Oh well…. who knows.
The Miller
I can’t find a way to remove reflector screw on my Q8.
It’s badly stripped and so tight I broke only screwdriver I have that can “fit”
Suggestions?
"With the first link, the chain is forged. The first speech censured...the first thought forbidden...the first freedom denied – chains us all, irrevocably."
My Q8 do also have that button LED thing going on, but really it dont bother me one bit, but if it do that one day i will just fix it and be done with it.
I am going to do a little modding on it to amp it up a little more, but i am in no hurry with that, first i will enjoy it as is
My Post office guy told me to use the physical address and put the PO number as a suite/apartment #. I would check with your post office first
~Ben Shapiro
Did you use a screwdriver or a driver with replaceable bits? Try a brand new bit which has sharp edges.
You can also try adding a rubber band to get extra grip. Apply heavy downward pressure and twist.
Can it be gripped by vice grips?
You may need to use a dremel or similar tool to cut a slot in the head, then use a flat blade screwdriver.
I tried both with no success. Both were new. Screwdriver tip broke when trying.
I don’t have vice grips like that, but will try to find them if I have to.
Will try dremel tomorrow, i give up today.
It’s dark now and I want to see the light
Please elaborate a bit on “that button LED thing”? Maybe a pic?
I see in the OP it mentions that lube may be required. Can anyone recommend lube suitable for the Q8’s threads, especially products available in Australia? Thanks.
Try applying the tip of a very hot soldering iron to the screw head for about one and a have minutes and then use the Miller’s rubber band technique.
They could have put glue on the threads.
stephenk, I can’t help with Aussie products, but I use a DOW silicone grease that works fine, I think it was The Miller who suggested SuperLube. It’s not the Space Shuttle where it can’t be done wrong or else.
My 3rd and final Q8 (gift for my son) arrived yesterday. After a quick strip-down, clean, lube & reassembly I can report that everything is perfect except for the switch LED's, it has the uneven brightness "problem". I have a feeling he'll want them changing to either blue or white like I'll be doing mine so a non-issue really.
On a side note, I gave my daughter's BF my 2nd Q8, 4 button-top 30q's & a Lii-500 earlier today for his birthday and he was chuffed to bits, he's really impressed.
It really does make for a fantastic gift, many thanks again for all involved in making this concept a reality!
I don’t know that this is available in Australia Sil-Glyde , but you can find it in any auto parts store, here in the US. I read a flashlight article a few years ago, where this was mentioned. I just happened to have some in my toolbox. I haven’t used anything since.
Try a local Ford dealer parts department. This XG-12 electrical grease is supposedly Nyogel 760G repackaged for Ford. 3oz tube was $15 dollars at my local dealer.
I ordered my Q8 on the 12th. According to the numbers a few pages back, I think it should have been in the “third” set of 500 lights. I just checked my account, and it’s marked as shipped, but the note says “Shipment information sent to FedEx”. So, I dunno. That’s kinda weird. Maybe they’re just pre-printing all the labels?
- The YKK Philosophy
UPDATE: since i received my other two Q8s (second pair came day after the first pair, but got my hands on it only from Monday)
Out of 4:
First came non-lubed, uneven beacon LEDs, beacon LEDs stopped working next morning, has switch contact issue rarely
Second came well lubed, even beacon LEDs, beacon LEDs do work, has very ofter switch contact issue
Third came OK lubed, uneven beacon LEDs, beacon LEDs do work, no switch contact issues yet after 3 days
Fourth came non-lubed, even beacon LEDs, beacon LEDs do work, no switch contact issues yet after 3 days
switch contact issue video (FLASH) → http://tinypic.com/r/2rpqid5/9 you can hear clicks but it won’t turn off at random positions of flashlight
Light Own: Convoy S2+ 4C FET, BLF X6v2, BLF Q8, BLF LT1, WildTrail D80v2, Convoy L6 TA Narsil, BLF GT, BLF-348, Convoy S2+ 18350 Nichia 219BT, Astrolux A01, Olight I3E tan Gifted Away: Convoy C8+ Sand 4C FET, Pelican 2350, BLF D80 (due to flicker), BLF A6 (due to green tint), BLF X5 Built/Modded: EE X6 FET SST-40 N4 6500K dedomed, Two EE X6 FET XP-L HI V2 3A, Two Convoy C8+ Sand 4C + FET
Mr.Poppy: according to previous posts about the light not turning off with a single click, it seems it is a matter of timing: the click must be very short – 1/4s. Can you check if a faster/lighter click makes a difference on those two lights?
as you may see it’s a matter of angle, at some angles it just won’t turn off… and when i rotate the angle just a bit it will turn off, and turn on
This won’t happen on the last 2 flashlights that i got, so I’m sure it’s not timing
great list LRu !
link to djozz tests
Added this to the OP:
Thanks!
And removed the part about production being halted, since it it resumed
It is done when it is done
How my BLF Specials generally work, please read before asking Qs
The Q8, Exciting a groupbuy for a Premium BLF special high lumens soda can light!
The GT, A BLF special GIGA thrower
The FW3A, a TLF BLF special small, elegant, powerful triple
Lithium Ion safety 101 important read
Sorry grammarlovers, I am a real King Typo.
~Ben Shapiro
You can call me a Q8 man now
NICE!
I received an email from Janny at Banggood:
… Which means LABEL CREATED (I’m sure for mine anyway PO’s in 1680’s & 1750’s).
Texas Lumens Flashlights / M4D M4X Deals : sign up - save $$$$
Rudeness Level _ mΩ _ {width:70%} _ LightWiki _ LED Tint Chart
Xlamp size chart _ BatteryU _ Flashaholic? Need Professional Help??? TheOriginal _ TAB _ LightSearch _ BatterySearch _ 14500's _ DiCal
The Miller
Suggestions?
My reviews:
Sofirn SF36 /// Thorfire VG10S /// Sofirn C8F /// Zanflare F1
We got NASA in today - they want to see the Q8.
I hope it's not because of complaints from the space station or somethin.
Texas Ace Lumen Tube calibrated with Maukka lights
Click this to go to signature links.
As in http://www.q8.com ?
~Ben Shapiro
My reviews:
Added to list in OP, check modding topic, there are several things to try
Starting here
http://budgetlightforum.com/comment/1194404#comment-1194404
I would sacrifice an old bit and attach it with JBweld to have a nice grip.
Recent Reviews:
XTAR DRAGON VP4 Plus Zanflare S2
Klarus XT2CR BLF Q8 Convoy S2+ DT
Nitecore P10GT Klarus XT11GT
Nitecore NU25 Nitecore HC65 Nitecore P26
Yongnuo YN360 Convoy C8+ Klarus FX10
Nitecore MT22C Folomov 18650S
FW3A Strobes
Brian
Out of 4:
Two assembly lines?
Maybe more. I’d love to get a shop tour and see the lights in action being built.
Anyway, my two are being shipped and I’m really excited about it.
That is an interesting find RobertB, How did you find out that XG-12 = Nyogel 760g?
It tried looking up the MSDS for XG-12 but doesn’t appear to disclose what is it,
Here is the MSDS of XG-12
https://www.fcsdchemicalsandlubricants.com/main/msds/us184665us.pdf
The only reference to it being Nyogel comes from this thread
http://budgetlightforum.com/node/13394
