Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
17431 posts / 0 new
justanotherguy
Last seen: 12 hours 39 min ago
Thanks for clearing up my memory. I’ll blob them then. Not worth the hassle of returning
anyone in NE ILLinois into get togethers?
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 6 hours 1 min ago
Lazy-R-us wrote:
Flintrock wrote:
And a tail cover with lanyard holes Wink  TF might make double on these if they play it right.
If we are looking for an aftermarket tail cover, I’d like to see one with enough room inside for a charging board. I’m fine with taking the tail cover off to plug in a USB cable. Some minor mods to the tail PCB and a TP4056 board and we would be well on our way to onboard charging.
RapidLux wrote:
Better make a tail cover that supports magnetic charging instead, that would make charging much easier since there will be no need to unscrew the cover to plug it in.
You will need a front cover instead of the head to charge the battery. So an option would be a talcap with lanyard hole and a removable front cap with charging-Circuit.
Otherwise you wont get contact to the battery+ side.
Lazy-R-us
Last seen: 1 month 4 days ago
There is no denying that it would be simpler to do on the front side, but there is quite a lot of room right down the middle of the tube for a spring loaded connection to the positive end. Enough room that I have printed my Joechina cheat sheet larger than he intended (75mm IIRC) and rolled it up to store in that space.
Having said that, it is an interesting thought that you could have a spare battery tube with tail PCB and cap, loaded with batteries and on charge. When it is time to load a fully charged set of cells, you unscrew the head and this ‘charge cap’ then simply swap them.
Lazy-R-us
fixed it
alternety wrote:
Has anyone found a heat conducting material that also lubricates for the threads between the head and cylinder? It could get a bit more heat out of the hot part.
I thought of heat sink transfer goo. But nothing that says it won’t dry out or turn liquid. Drying out could be a bad thing. Liquid metal bad on the not drying out side.
I think most of those are designed to dry out. They’re meant to be very liquid when you apply them so they spread everywhere evenly. Then they dry for slightly increased performance. At least that’s what I remember reading a long time ago, back when CPU cooling was more critical.
ToyKeeper
ToyKeeper's picture
Last seen: 2 hours 46 min ago
The Miller wrote:
DavidEF wrote:
shirnask wrote:
I got an email from ThorFire:
Dear Customer,
Great News! ! BLF Q8 flashlight will be available on amazon USA soon. If you would like to order more, we have limited quantity promo codes(49% off)and the price would be the same as Group Buy: $40.
And If it is convenient for you, could you please spare a few minutes and help to share an honest review of BLF Q8 light on amazon? Here is the product link.
BLF Q8: https://www.amazon.com/dp/B0773Q46D3
If any question, please feel free to contact.
Best Regards
ThorFire
Crown Thumbs Up
NICE!
Thanks for the reminder. Some of the marketing seems a bit less than accurate, so I put up a comment to give a bit more info about it. Kind of disorganized, but hopefully it’ll help.
hank
hank's picture
Last seen: 8 hours 53 min ago
Marked TK’s comment at Amazon as helpful. Definitely.
(Do we even know the light is anodized, rather than painted?)
MtnDon
MtnDon's picture
Last seen: 6 hours 15 min ago
DavidEF
DavidEF's picture
Last seen: 4 days 8 hours ago
Seen this one? https://www.amazon.com/Professional-Multiple-Operation-Procedure-Flashli...
$128.99 and FREE shipping! Wink
It claims to be in stock, just one. But it may arrive after Christmas. Facepalm
- The YKK Philosophy
ToyKeeper
ToyKeeper's picture
Of course it’s anodized. We’ve all seen the one Tom baked, right? It’s his avatar pic. It has to be anodized to do that.
Is someone spreading FUD about the Q8 being painted?
Agro
Agro's picture
Last seen: 2 hours 40 min ago
Here’s my Q8 optic:
You can see that the LEDs are not centred perfectly. Is it OK or is it not?
JasonWW
JasonWW's picture
Last seen: 2 hours 21 min ago
Agro wrote:
Here’s my Q8 optic:
Only you can answer that. Is the beam acceptable when you use the light?
Click this to go to signature links.
djozz
djozz's picture
Last seen: 41 min 34 sec ago
^ They are not dead-centered, and this amount of error was in the prototypes too and appeared to be too difficult for Thorfire to improve. Since it did not seem to affect the beam at all as far as we could see, we gave this imperfection a go.
So officially, according to the Q8 team, it is ok. But from an OCD point of view it is annoying of course.
Flashy Mike
Flashy Mike's picture
Last seen: 32 min 59 sec ago
In none of the 3 Q8 I’ve currently here the LEDs are better centered, and I don’t care at all. No impact on the beam.
Tom E
Tom E's picture
Last seen: 17 min 29 sec ago
They look "ok" to me, slightly off. What I'd do would be pop out the bezel/lens/o-ring, pop out the driver, loosen up the 3 screws (assuming you got a rev 2), and re-tighten. I usually go with tightening the center one first, then the outer ones. Might help a little with the LED centering. At least by doing this, you can see it happening, so might help how to re-tighten and get the best centering.
I'd only be concerned if the LED centering rings don't appear to be fitting in the reflector holes properly - that's usually easily fixed by loosening and re-tightening.
For what you got, sometimes the LED's aren't perfectly centered from soldering, and if so, that can be corrected, but requires further dismantling - taking out the MCPCB, cleaning it up, and using a torch applying the heat underneath carefully, and reset the LED's positioning by melting the solder and either letting them seat on their own, or give them a little nudge.
Generally I've found rev 2's better centered than rev 1's.
hank
hank's picture
No FUD, and no, I didn’t recall seeing Tom’s baked flashlight, which now that you mention it, I agree proves it’s anodizing.
I’m not paying that close attention given the volume of comments. Glad someone is.
I wondered because I often can’t tell the difference between type 2 anodizing and paint, on flashlights generally; both coatings seem fairly easily chipped.
Tom E
Tom E's picture
First Q8 proto, pre logo, etc:
blinker
FUD? What is FUD (if it safe to say)?
Not a flashlight guru, but like them just the same.
Misspellers of the world UNTIE!!!
raccoon city
raccoon city's picture
Last seen: 2 hours 26 min ago
cat_fud
DavidEF
DavidEF's picture
Fear. Unbelief. Doubt.
blinker
O K. Thanks.
Agro
Agro's picture
Thanks for the answers. Smile
manithree
Last seen: 1 day 8 hours ago
Actually, I believe that’s, Fear, Uncertainty, and Doubt.
WalkIntoTheLight
Last seen: 3 weeks 5 days ago
The Q8 isn’t intended to be a thrower, so don’t worry about it.
DavidEF
DavidEF's picture
OOPS! You’re right. I didn’t look it up. I was trying to go from memory. Facepalm
Agro
Agro's picture
Actually I’d like it to be more throwy….somewhat akin’ to DT35. It won’t work this way, but a set of dedomed SST-40s will bring it closer. Smile
Gj
Gj's picture
Spreading FUD about the meaning of FUD. Thumbs Up
Gj
Gj's picture
Lazy-R-us wrote:
My first thought was that this is a genius idea. Around the house and even in the car it would be a quick way to charge it up and would definitely be quicker and cause less wear. My second thought was that battery banks have USB, but not inductive ports. Which means that you would need to carry a wireless charger as well if you were taking this camping for instance. My third thought is that the obvious answer to this is a product that I have not seen – a USB battery pack with a built in inductive charge pad.
Which I think has now become my next project.
Qi charge pad (currently out of stock).
USB Power bank
switch, batteries and a housing…
[edit]annnnd like most of my ‘brilliant’ ideas someone else has already had it, done it, and posted a video on how to do it. Still going to work on it.[/edit]
It seems much faster and easier to just carry a spare set of cells. Less bulk to carry, and you can’t use the light while charging the cells in the field. Are there any advantages at all?
MtnDon
MtnDon's picture
There’s the coolness factor, that means more to some than others. Spare cells in a plastic box is so mundane. Wink s
askj
Last seen: 1 year 3 months ago
The idea is from the MF02 thread, will the Neodymium Magnets be ok to use for contact in the Q8 using non-button batteries instead of soldering the blob?
JasonWW
JasonWW's picture
No, you can’t use magnets on this type of light.
