Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
17431 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 3 hours 49 min ago
Bonham wrote:
Not measured the drain.
Not used often and find critical voltage when checked.
One 30Q did not recover anymore.
If you want to measure parasitic drain, you need a digital multi meter. You can basically do it like this:
Set your meter and test leads to milliamp. Then take a battery and touch the positive end to the driver ring, then attach the meter from the battery negative to the driver ground. You should be seeing about 0.12 milliamp with the side switch lights on.
If it’s way higher, then you have a problem with the driver or a short somewhere.
What do you mean by “one 30Q did not recover”?
fluke
Last seen: 13 min 4 sec ago
Guys could I buy the driver board and switch board and fit to a SRK Clone?
Might over drive the fake leds a bit.
JasonWW
JasonWW's picture
Are the driver diameters the same?
Make sure not to bypass the springs.
I would think heat would be the biggest issue since the clones don’t use a DTP mcpcb, plus the shelf are usually paper thin if it even has a shelf.
Check out this video David Sunshine did a while back. https://youtu.be/efl0R63-ik0 I think he piggybacked a new driver instead of swapping it. He has a lot of details.
shirnask
shirnask's picture
Last seen: 3 hours 7 min ago
Bonham wrote:
OK. I put new battery 30Q (first use) from BG after full load and measured about 3050-3100 mAh.
After about a week (now) its about 3.96 mAh V.
I’m happy with my Q8. I bought 3 of them.
Are you using button top or flat top batteries?
Bonham
Bonham's picture
Last seen: 2 hours 42 min ago
I’ve used a button top battery.
The chargers I have do not start charging this battery.
The voltage was just over 2 volts, as far as I remember.
Thanks Jason for the measurement instruction. Thumbs Up
JasonWW
JasonWW's picture
What I’m wondering is how the battery got down below 2.8v. This is the cutoff voltage. The driver should not draw any power below 2.8v. If it did, something seems wrong.
Does only one of your three Q8s drain the batteries fast? Maybe it has a defect in the driver? I don’t know.
Doing a drain test might give some answers.
Maybe the MCU is not going to sleep after 6 seconds like it should? I’ll ask ToyKeeper.
djozz
djozz's picture
Last seen: 4 hours 28 min ago
I think I remember that LVP detection does not work when parasitic drain is lowering the voltage very slowly. Tom would know that better though.
JasonWW
JasonWW's picture
Tom is barely around any more. Crying
So the lvp only works when the light is turned on? Well that is a bummer. I assumed it worked all the time.
I wonder what’s causing his drain, though.
maukka
maukka's picture
Last seen: 13 hours 15 min ago
AFAIK no LVP can prevent undervoltage by parasitic drain,
JasonWW
JasonWW's picture
Yeah, I guess that makes sense. You actually need to MCU to be operating and taking samples of the voltage in order to determine whether or not it’s above or below the threshold and that process is just going to create increased parasitic drain.
ToyKeeper
ToyKeeper's picture
Last seen: 14 hours 33 min ago
mortuus wrote:
All those that have the q8 for a long time now, does it still work like a charm, the button is not weared out etc ??
Mine was from the second batch (#501-1000), which had the first batch issues fixed. It has been working great since I got it, and it gets used quite a bit. In terms of sheer number of hours, it has probably been my most-used light over the past year, but I’m not sure if that counts since it’s a whole lot of candle mode.
Anyway, no issues at all. And the button LED has been on pretty much nonstop the whole time.
ToyKeeper
ToyKeeper's picture
Exactly.
The MCU also has BOD (brownout detection) enabled, but that doesn’t activate until 1.8V. So, if it gets that low, it’ll shut the MCU off even more than it normally can. Which probably won’t have a significant effect on the parasitic drain.
But LVP (which shuts off at 2.8V) only works when the light is actually on. And it sounds like whatever is draining happens when the light is off. So get out a DMM and start measuring things. It’s probably a hardware issue.
atbglenn
atbglenn's picture
Last seen: 10 months 4 weeks ago
I have one from the second batch. It’s been flawless in every way.
Boycott Nike
fluke
ToyKeeper wrote:
Mine was from the second batch (#501-1000), which had the first batch issues fixed. It has been working great since I got it, and it gets used quite a bit. In terms of sheer number of hours, it has probably been my most-used light over the past year, but I'm not sure if that counts since it's a whole lot of candle mode. Anyway, no issues at all. And the button LED has been on pretty much nonstop the whole time.
Are they marked with a number?
fluke
Are the driver diameters the same? Make sure not to bypass the springs. I would think heat would be the biggest issue since the clones don't use a DTP mcpcb, plus the shelf are usually paper thin if it even has a shelf. Check out this video David Sunshine did a while back. https://youtu.be/efl0R63-ik0 I think he piggybacked a new driver instead of swapping it. He has a lot of details.
Thanks, im using one of the MTN boards, silicone 18awg wire to leds and 4 30Qs spring bypass and brass screws.
Just over 13 amps to the emmiters.Gets hot PDQ.
Its only a super cheap SRK clone by Securitying
teacher
teacher's picture
Last seen: 9 months 3 weeks ago
/\… No, they are not marked with Batch or serial numbers.
fluke
Thank you.
Sofirn
Sofirn's picture
Last seen: 11 hours 21 min ago
How many people are interested in trying a new Q8 with XPL HI leds?
And how many people are interested in a light smaller than Q8, I mean with 3 * 18650 battery tube, but with the same driver and USB C charging port?
BlueSwordM
BlueSwordM's picture
Last seen: 9 min 52 sec ago
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 hour 56 min ago
I’d be more interested in a Triple XP-L HI V3 1A with the 3 Bigger Reflectors and 4 cells. Thumbs Up
KB1428 “Live Life WOT
Sillen
Sillen's picture
Last seen: 1 week 5 days ago
Larger rather than smaller. USB charging doesn’t add value for me.
Triple XP-L HI V3 1A with the 3 Bigger Reflectors and 4 cells +1
teacher
teacher's picture
I agree with Sillen….
……. USB Charging on a light such as this adds nothing of value. Smile
JasonWW
JasonWW's picture
I don’t have any interest in xpl hi or 3 × 18650. Built in charging might be good for people who are new to flashlights.
All I really want is a stock Q8, but in CW. Something which has yet to be offered by Thorfire.
led4power
led4power's picture
Last seen: 6 hours 5 min ago
Sofirn wrote:
How many people are interested in trying a new Q8 with XPL HI leds? And how many people are interested in a light smaller than Q8, I mean with 3 * 18650 battery tube, but with the same driver and USB C charging port?
Can you make OP reflectors for Q8 and C8F?
JasonWW
JasonWW's picture
What would be the advantage to that? It doesn’t seem to be necessary. I’m confused.
djozz
djozz's picture
It would make the Q8 suitable for the 3V Luxeon MZ leds (on the 4040 Q8 board): great CRI plus great power with an easy mod, as long as the reflectors are heavy OP to prevent the donut hole!
led4power
led4power's picture
Not just MZ, but there would be less beam color separation with most other LEDs too - OP reflectors always give smoother, more uniform beam which is important for high CRI builds.
PBWilson
Last seen: 1 hour 21 min ago
I am very interested in a 3×18650 light and mentioned it in an interest thread a long time ago. The smaller diameter and lighter weight will make it easier and more likely to be picked up and put in my pocket. The 3 cells will allow for very good runtimes and being larger than a single cell light, it should handle heat a bit better. People with smaller hands might prefer it as well.
There have been a few 3×18650 lights released and the Firefly seems to be a success, but it costs quite a bit more than the Q8 does. I don’t care about usb charging at all and would prefer to not have it because of waterproofness if the port is covered by a small rubber flap or plug. If its hidden by the threads, I might like it more. It would have to be a solid design and one that would not add too much weight or bulk or cost for it to interest me.
pennzy
pennzy's picture
Last seen: 7 min 23 sec ago
Yeah, sounds good to me. USB charging would be fine if not slow. 3 18650 would fit the hand better than 4.
lexvegas
One thing to consider re: LVP with an e-switch:
It’s possible to get a dpst swtich, so you have one pole that “bootstraps” the MCU by turning on a transistor, and then you have the other that is used purely for click detection. It may even be possible to do this on a spst switch with some electronics trickery. When the MCU detects i’s below X volts, it sets the pin holding the transistor to “off” and the whole thing goes totally dark. No power until the button is clicked again.
Hardware wise, it would be best to use a mosfet to minimize quiescent current, and make sure to use very high value resistors for the “on” signal to the mosfet. Given the relatively high capacitance of the mosfet gate, you might even be able to get away with putting a capacitor on the line to hold it high, and just give it a periodic pulse to maintain voltage when in sleep, if you desired to keep the MCU running.
