Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
17432 posts / 0 new
ToyKeeper
ToyKeeper's picture
Last seen: 7 hours 29 min ago
lexvegas wrote:
One thing to consider re: LVP with an e-switch:
Have you measured the power used by the Q8 driver during standby, or after LVP activates?
In stock form, with the button LED off, standby drain is about 0.02 or 0.03 mA. Or after reflashing it with different fuse values, it’s even lower. If I recall correctly, it was something like 0.00002 mA. And with four cells, divide all these values by four. This makes the standby power virtually indistinguishable from zero, because it’s lower than the cell’s self-discharge rate. With the right fuse values and with the button LED off, I’ve found that I can actually take the battery out for a few minutes without making the MCU shut down. And it can still wake up on button press.
Atmel calls this “picopower”. It makes standby mode use such a small amount of power that it’s not necessary to design in clever power-disconnect circuits.
lexvegas
Last seen: 10 months 3 weeks ago
Yeah, I’m not suggesting it’s necessary, just providing input. I think it might be more relevant given a driver that couln’t use the super-low modes on the MCU or for a non LiIon battery. (AA Emergency light, for example).
That’s a super neat anecdote on pulling the cells!
BTW, I’ve been studying the FSM code for a potential MCU port, well done on the organization! I’m still picking up C syntax, but overall it’s very readable for me.
I wonder if there is a market for protected cells that only have LVP rather than LVP and over-current.
JasonWW
JasonWW's picture
Last seen: 9 hours 28 min ago
pennzy wrote:
Yeah, sounds good to me. USB charging would be fine if not slow.
Oh yeah, it slipped my mind that USB is only 10 watt (2A@5v) at most. This would make it very slow if you were charging 3 or 4 batteries.
USB-C might be the better choice. A few flashlights already use this. It’s capable of 60W (3A@20v). So maybe the internal charge rates could be 1A to 1.5A per cell. That would greatly reduce charge time.
One problem I see with built in charging in general is that the Q8 can run on 1, 2, 3 or 4 cells. If the charging circuit delivers 4A@5v (1A for each of the 4 batteries) and you happen to be running only 1 battery in it, all 4A will go to the single cell and lead to disaster.
ToyKeeper
ToyKeeper's picture
lexvegas wrote:
BTW, I’ve been studying the FSM code for a potential MCU port…
Which MCU?
I’ve been considering porting it to tiny841 and tiny16something, to get more pins and potentially also more ROM. But I probably won’t for a while.
lexvegas
ToyKeeper wrote:
Which MCU?
The jankiest Ukrainian? MCU in existence that they used in the MF02s. If I can find the time, it will be less of a “port” and more of a controlled demolition onto a new chip. Basically it would involve taking any of the references to atmel libraries plus any of the assumptions about timers and subbing in a compatibility library or something. I’ve posted a few findings in maukka’s MF02s review thread. Ultimately I don’t have a lot of hope, but it would be nice to do, as the driver is a quad channel boost driver running the XHP70.2 at 12v.
Agro
Agro's picture
Last seen: 2 min 59 sec ago
Actually USB Power Delivery (which uses Type C connector) allows for 100W, 20V 5A.
There are laptops (and adapters) on the market already which do (from memory) 95W.
Type C without PD is 5V 3A.
JasonWW
JasonWW's picture
Yeah, but I’m talking about the more common USB-C. 20-30 watts seems the most a charger would need.
I still don’t see it working well on a multi cell flashlight unless you were to limit it to 5 watts total. That’s 0.25A to each of 4 cells and a very slow charge. I think that’s the real issue.
Has any parallel battery light had a charger circuit built in? If so, I wonder how they dealt with this issue.
teacher
teacher's picture
I think USB charging on a multi cell light is just a gimmick that is best avoided.
It adds unnecessary cost, is just something else to go wrong, & allows for water intrusion unless put in the threads…. protected by an o-ring.
ymmv….. Wink
Oh yeah, it would be slow…. Worthlessly slow. again ymmv
JasonWW
JasonWW's picture
I remember Haikelite did a charger cap that went on a battery tube of 4 cells. It acted as a charger, power bank and mini flashlight. I never got any details on how it worked, though.
ToyKeeper
ToyKeeper's picture
FWIW, there’s a cool white version coming:
http://budgetlightforum.com/node/62283
If I recall correctly, this might be of particular interest to JasonWW. Smile
teacher
teacher's picture
Yep… you “recall correctly” TK, JasonWW will be beside himself. Big Smile
mortuus
mortuus's picture
Last seen: 21 min 55 sec ago
cool eh?? the world needs more warmer tints, how about making it a 4000k or even 3000k edition ??
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
BlueSwordM
BlueSwordM's picture
Last seen: 2 weeks 16 hours ago
Yeah. How about they make an LH351D 90CRI version instead?
Especially since we know they are going to be using them in the Lantern project.
JasonWW
JasonWW's picture
Not really. It’s the stupid HI version instead of the HD. Angry
Oh well, I’ll wait and see. Maybe they will do a HD vesion as well. I need to read that new thread.
ToyKeeper
ToyKeeper's picture
FWIW, the HI version should give a more consistent tint without the usual Cree rainbow. And if you want it less throwy, DC-Fix is cheap. Together, they should make for a very nice-looking beam.
BlueSwordM
Offtopic, you have some nice nails Love
Back on topic, what light is this? For some reason, I thought you managed to put a triple reflector inside of a BLF Q8.
JasonWW
JasonWW's picture
I’m more interested in output levels. I’ll probably have the weakest output Q8 of anybody. 4000 lumen maybe. I want 6000, but no way with the HI version.
No biggie, I’ll wait and see what happens.
ToyKeeper
ToyKeeper's picture
BlueSwordM wrote:
what light is this? For some reason, I thought you managed to put a triple reflector inside of a BLF Q8 for some reasom
Nope. You know the big golden light in BLF’s front-page logo? It’s that light. An original Skyray King, modded with a BLF driver and some other things. Currently it has a prototype Q8 driver in it, and it’s what I used for part of FSM’s development.
http://budgetlightforum.com/node/32035
BlueSwordM
Oooh I had completely forgotten about the original inspiration of the BLF Q8.
Very nice light BTW. Also, very smart idea to combine multi-tint/CCT LEDs. Maybe I should do that for my bathroom with some high CRI LEDs lol. The fluorescent lamp currently in makes everything look green.
Because of this, I feel like I look much worse during the evening than during the morning when there’s abundant sunlight.
Have you ever experimented with multi-tint high CRI LED strips setup BTW? I don’t know if it’s a false memory or not, but I have seen you write about it on BLF. Maybe I’m just hallucinating or something.
ToyKeeper
ToyKeeper's picture
I’ve been meaning to, but the parts are pricey and I’ve been busy.
Alen
Last seen: 12 hours 57 min ago
!{width:70%} !
The hole on the center of Ledboard shel is bad to see
when manufactured make a flat surface area?
teacher
teacher's picture
That does look like a big hole. Wink
eas
eas's picture
Last seen: 9 months 6 days ago
With a big copper DTP MCPCB I doubt such a hole would make much difference. It’s what, 10-15% of the area? and its the furthest from the outer edge and the emitters.
Alen
but if they can fix it or smaller will be better
teacher
teacher's picture
Probably a good point eas. Thumbs Up
JasonWW
JasonWW's picture
I’m sure this was discussed way back in the design phase, before I followed the progress, and the best choice was made.
Maybe someone remembers the reason why they couldn’t shrink the hole another few millimeters.
Alen
The hole it’s too large,it can be smaller
ToyKeeper
ToyKeeper's picture
That hole doesn’t really have any significant effect on the light’s performance or heat-sinking capacity. There is a thick copper MCPCB over it with four emitters, and the purpose of the shelf is to wick heat from the copper to the outside of the light.
This was considered extensively during the design of the light, the team went with what they determined would work, and it does.
JasonWW
JasonWW's picture
Alen wrote:
The hole is too large, it can be smaller.
This was discussed 2 years ago. It’s too late now. 2 years too late. Thorfire is not interested.
Sofirn is making a Q8 with small changes, but I don’t think they will alter the led shelf. It’s too late for that.
Sofirn is planning to make a more radical version, v1.5, using a battery carrier. Maybe you can suggest changes to that model. It’s early enough that they can actually do it.
KawiBoy1428
KawiBoy1428's picture
Last seen: 12 hours 28 min ago
Easiest thing to change in a CNC Lathe, set smaller diameter drill length the same, depth won’t change, reset the speed and feed in the program, takes minutes, smaller drill, means higher rpm and a faster feed rate, shorter cycle time, a smaller diameter drill should be an easy quick change. It’s not like they are circle interpolating the hole.
KB1428 “Live Life WOT
