Review: Klarus G30 3x18650 MT-G2 2450 lumens
6 posts / 0 new
Budda
Budda's picture
Last seen: 2 months 6 days ago
I got the G30 from GearBest the review.
The light comes in a cardboard box with the specs of the light.
The light is in a plastic box with a spare o-ring, lanyard and instruction.
The light is compact: 47×135mm.
The big MTG2 emitter in the OP reflector, good for close range illumination. The glass has AR treatment and is tempered.
The body of the light, with the space for the 3×18650 batteries. I don’t like separate battery carrier: more parts, more weight, bigger size.
IPX8 waterproof with o.rings.
Anodized threads, so if you untwist the tailcap you have physical lockout and avoid parasitic drain.
Switch at the head, covered with hard plastic.
The switch at the head has a colored led under it, it shows the level of the batteries: green 70-100%, orange 30-70%, red <30%, flashing red <10%.
There is a second switch, with a rubber cover at the tailcap. The switch protrudes a bit, and the light can tailstand.
The switch are the same for what I can tell. They have good feedback for my taste (short travel, not too stiff, hearable click).
The tint is between a NW and a CW. I strongly suggest to check the measurement thread of Maukka about this light. It’s full of detailed info.
Runtime
For the runtime test I used 3 18650 Keeppower 3200mAh.
There’s not much to say. The G30 has a very good regulation. I have not tested the runtime at low levels.
I tried, once the stepdowns kick in, to make the G30 return to Turbo. This is a “macro” of what happened.
The temperature sensor kicks in and regulates the output in a very precise way. You can see that after the pick of the “second turbo”, the output decreases even more for a while. This is because the light will need time to dissipate the additional heat, and so the light will lower a bit the output until the temperature reaches the precedent plateau level, and so it brings the output hi a bit.
My thoughts
The G30 is the perfect light for who wants to try the MT-G2 on a budget (at the moment is less than 50€).
It is very well regulated (first time I see a PID so precise) and well built.
It has 2 switches (for people who like it at the head and for people who like it at the bottom).
Usually I find more easy to use the switches near the head, but on this light the one at the tailcap is easyer to find: it protrudes and has a more grippy texture.
The battery level indicator is clear and simple, but I’d prefere the indicator to be always on during use.
I prefere to change level in an ascending order (low-medium-high-turbo-low…), so if I need to increase the output a bit, I won’t have to pass all the other levels. Maybe one of the 2 switches could pass the level in an ascending order, and the other in a decreasing order.
The dimentions are the same of the ET SX25L3, that many have, but the UI is different: ET is twisty, G30 clicky.
There is no sheath or other accessories, but the price is rather low (less than half) and Klarus didn’t save on the quality of the ight.
Thanks for reading.
Thanks to AntoLed for lending me the luxmeter.
More test will follow.
All my reviews, in italian and english, here: Lumenreviews.com
Edited by: Budda on 04/06/2016 - 09:14
The Miller
The Miller's picture
Last seen: 11 months 3 days ago
nice review.
beautiful light (I am a sucker for coda/soup can lights)
the series configuration is killing it for me. having to reserver 3 cells for 1 light, not ideal.
Budda
Budda's picture
I used to agree with you, The Miller, when 18650 cost 10-15€ each.
Now if you go to nkon or wait an asiatic promotion, you can get home 3-4 18650 for around 10-15€.
And then you can keep those 3 cells, without splitting them, for all the 3 × 18650 lights.
The Miller
yeah, the odd number is annoying.
I have two times 2 cells kept for series lights (the Thorfires) that is nice, even feels better then odd, but surely I am odd Wink
and look at that emitter in the review
makes you want to order right, yammie!
cembar
Last seen: 4 years 1 week ago
Dear Budda, Do You know reflector dimension (HxD)? thanks.
Budda
Budda's picture
No, sorry, I don’t know and I don’t have the light anymore.
