Test/Review of Sanyo/Panasonic NCR18650GA 3500mAh (Red)
25 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 55 min ago
DSC_3678
Official specifications:
  • Rated capacity: 3300mAh
  • Minimum capacity: 3350mAh
  • Typical capacity: 3450mAh
  • Nominal voltage: 3.6V
  • Discharge end voltage: 2.5V
  • Charging current (Std.): 1.675A
  • Charging voltage: 4.20 +/-0.03V
  • Charging time (Std): 4.0 hours
  • Continuous discharge current (Max.): 10A
  • Internal resistance (AC 1kHz):
  • Cycle life: 300 cycles to 70%
  • Weight:
  • Operating temperature: Charge: +10 ~ +45°C, Discharge: -20 ~ +60°C
  • Storage conditions: less than 1 month: -20 ~ +50°C, less than 3 months: -20 ~ +40°C, less than 1 year: -20 ~ +20°C (80% capacity left)
Sanyo%20NCR18650GA%203500mAh%20(Red)-info
A high capacity cell from one of the largest LiIon manufacturer.
DSC_3677
DSC_3679 DSC_3680
DSC_3681
DSC_3682
Sanyo%20NCR18650GA%203500mAh%20(Red)-Capacity
As expected these discharge curve is tracking nearly perfectly. The cells are high capacity cell, but can deliver some current.
Because I cut the discharge at 2.8 volt, I do not get the full capacity from the cell.
Sanyo%20NCR18650GA%203500mAh%20(Red)-Temp-7.0
Sanyo%20NCR18650GA%203500mAh%20(Red)-Temp-10.0
Sanyo%20NCR18650GA%203500mAh%20(Red)-Temp-15.0
The cells are rated for 10A and at 15A discharge the batteries gets very hot, on the first cell I terminated discharge at 75°C and the second cell I terminated at 85°C (The maximum allowed cell temperature is 70°C).
Sanyo%20NCR18650GA%203500mAh%20(Red)-CapacityTimeHours
Sanyo%20NCR18650GA%203500mAh%20(Red)-Energy
Sanyo%20NCR18650GA%203500mAh%20(Red)-PowerLoadTime
Sanyo%20NCR18650GA%203500mAh%20(Red)-TripCurrent
Sanyo%20NCR18650GA%203500mAh%20(Red)-Charge
Conclusion
These cell has very good capacity and can also handle current, this makes it one of the current top cells for that.
Being from Panasonic there is no doubt that it is good cells.
Notes and links
Compare to 18650 and other batteries
Edited by: HKJ on 04/08/2016 - 11:50
chadvone
chadvone's picture
Last seen: 1 month 2 days ago
Thanks. I have been wondering about this cell.
vex_zg
Quote: “Rated capacity: 3300mAh”
Perhaps it’s a typo – isn’t it 3500mAh?
Thanks for the review!
HKJ
HKJ's picture
Maybe, but it is not mine. From the datasheet:
will34
will34's picture
Last seen: 1 week 3 days ago
Thanks! A most awaited review…
I have 12x GAs and they all track nicely, capacity ranging from 3320-3380mAh.
Bort
Bort's picture
Last seen: 4 days 4 hours ago
Thanks for reviewing these, they are my next planned battery purchase (unless they release a higher capacity model by then)
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
pilotdog68
pilotdog68's picture
Last seen: 3 months 4 days ago
I have a few I use in lights I want longer run-times (“wow” lights get 30Q’s). The cheapest source I have found is kaidomain. I have bought two there, well-packed and genuine cells. I’m not sure what shipping is like with the new regulations though.
myhken
myhken's picture
Last seen: 2 years 1 week ago
Finally, I have been pretty sure that this battery is a good battery, and have 16x of them. Also think LG MJ1 is a good cell, have you tested it yet?
Kenneth Myhre
akhyar
akhyar's picture
Last seen: 1 year 1 month ago
Thanks again for th excellent review HKJ.
Waiting for your review of LG MJ1 too, since these 2 cells are easier to find tha the Samsung 3500mAh that you’ve tested before
myhken
myhken's picture
akhyar wrote:
Thanks again for th excellent review HKJ. Waiting for your review of LG MJ1 too, since these 2 cells are easier to find tha the Samsung 3500mAh that you’ve tested before
http://budgetlightforum.com/node/45838
Kenneth Myhre
pilotdog68
lol few people saw it in september apparently.
Very similar performance from the two, I say buy whichever is cheaper
akhyar
akhyar's picture
I stand corrected.
Missed out on the earlier MJ1 test.
So all three 3500mAh cells have been tested.
The MJ1 tends to be cheaper but I haven’t come across the Samsung yet
will34
will34's picture
According to all the reviews I have read so far, out of the 3:
The GA is best for 1A+, but at more than 5A you might consider high-drains.
The 35E is best for low current, 1A and below. Perfect for power banks and low powered lights.
The MJ1 performs about the same as the GA for low currents, but falls short when above 3A.
So it’s safe to say the GA is the best high capacity cell for flashlights.
Correct me if I’m wrong!
pilotdog68
Well compare the GA and MJ1 on HKJ’s comparator. Almost no difference.
Hoop
Hoop's picture
Last seen: 2 hours 10 min ago
The MJ1’s seem to run hotter, but are rated for 400 cycles to 80% instead of 300 cycles to 70% like the GA.
1dash1
1dash1's picture
Last seen: 10 months 2 weeks ago
Thanks HKJ!
The GA looks much better than my Panny B’s.
I still like my 30Q’s, but I usually recharge them well before they hit 50% of their capacities. If I needed more run time, I’d certainly consider the GA’s.
Rule 1-1 as it applies to life, take it as it comes.
Llwyn
Last seen: 3 years 2 months ago
These are being sold by Gearbest now, 4 pieces for 17.39 USD.
Seems like a really good price.
hIKARInoob
hIKARInoob's picture
Last seen: 52 min 40 sec ago
Llwyn wrote:
These are being sold by Gearbest now, 4 pieces for 17.39 USD. Seems like a really good price.
8 pieces for $31.59 with code NC11. You might need to move to another country to avoid high shipping costs though…
Llwyn
Luckily I still have free shipping to my country.
Thanks for the code though, ordering 8 is tempting but at that price customs might start bothering me.
Is Gearbest honest with their declaration or do they mark everything with a random low value?
qandeel
Last seen: 43 min 21 sec ago
That’s what I noticed with all my orders. They are always marked way down.
 عُمَانْ
khas
Last seen: 6 days 19 min ago
Does anyone know what the letter printed on the battery means ?, some sort of grading ?. The one in the picture here has the letter “C” printed on it, the ones I have are marked “B” and “C”
toobadorz
toobadorz's picture
Last seen: 2 months 1 day ago
That letter is the cell grade. It is not clear how Panasonic/Sanyo grade the cell, but they do state in the specification that cells must be of the same grade when they are used in series.
khas
Thanks for the reply, and welcome to BLF Wink
SKV89
Last seen: 4 min 18 sec ago
Here are the discharge capacity measured with my Xtar Dragon VP4 Plus. The current batch from Illumn.com is the best batch I’ve seen.
Bought from Liionwholesale.com in January 2017
3375, 3557, 3479, 3391 mah
Bought from Vacell directly in November 2018
3480, 3552, 3502, 3467 mah
Bought from Illumn.com in August 2019
3570, 3584, 3631, 3549, 3561, 3600, 3611, 3540 mah
Samsung 36G for comparison
3454, 3385, 3427, 3463, 3328 mah
texas shooter
Last seen: 2 hours 29 sec ago
Still my favorite do anything cell.
