New product- Brinyte DIV20 double head led canister diving light on selling now.
Features of Brinyte DIV20:
Two heads are detachable to meet your DIY requirements.
You may select from among combinations of a single light , double lights , the main light and video lights, depending on your diving demand ,and adjust any time.
Maximum output for each lamp head is 2000 lumens , 5 hours long run time
Head side-push on/off magnetic switch operate conveniently underwater.
Direct recharging design for offering the convenient charging operation.
Hi,Vattern.The charge port is glued inside, so it is waterproof without the silicone cap. The silicone cap is hard to accidently open in fact, but we may forget to cove the cap sometimes.
Brinyte DIV20 utilize the head side-push on/off magnetic switch, and have high-middle-low three modes output. To produce a bright and long run time light, Brinyte’s engineers design the single head only max output 2000 lumens, which can arrive 5 hours runtime.
The third port is for direct charging, no need to take them out. For the excellent waterproof design, the charging port won’t have problem though water in. But you’d better clean it as soon as possible to avoid seawater corrosion.
There is no knurl on the surface of the battery canister, and type III military hard-anodized finish. These design is not only convenient to clean light after diving, but also minimize the harm of the seawater corrosion. The standard 38mm diameter hole in the tail-cap bezel is easy to assemble the battery canister of the flashlight.
Brinyte DIV20 is powered by 8*18650 batteries, which can’t take out directly. The new generation Panasonic 18650 rechargeable lithium battery has over charge, over discharge, short circuit and over heating protections, one battery can be recharged for more then 500 times. Those multiple protection ensure the safety and good performance of the battery. The batteries could be purchased individually as spare batteries when no place to charge.
Brinyte DIV20 Double Head LED Canister Diving Light have been to the market. Bright your underwater adventures, taking your primary dive light to a new level.
Hello The Miller, blitzwing ,Vattern , andies and RobertB. Thanks for your interests. Would you guys read the relevant thread and give us the suggestions?Thanks.
