Reflector revised: ReyLight Pineapple Brass 14500/AA Flashlight, Nichia 219C 4000K
544 posts / 0 new
Phosphor22
Last seen: 3 weeks 1 day ago
Thank you Rey – I am in for a few drivers – sent PP
BazzH
Last seen: 2 days 21 hours ago
Love it!! When can we expect a Ti version Wink Or Stainless? Sorry, can’t afford the Damascus…
Edit: I actually like the design of the Damascus more. Now if you would that design in Ti or SS I would be hooked for another two Big Smile
I bought the Brass one because I like the concept. Execution wise I’d prefer the Damascus design in a material I can afford Wink
strongest2004
strongest2004's picture
Last seen: 2 months 1 day ago
Hi Rey.
The ones you still have with you, are they with the beefier/thicker clips?
Might get one from your personal stock if yes. ,
Low mode and long runtime lover…
mattlward
mattlward's picture
Last seen: 14 hours 3 min ago
Hey, just ordered direct from Rey. He has a stash to sell, they are priced right! Just send him a pm and tell him what you want! Looking forward to the driver as well.
EDC rotation:
Convoy S2+, 6*7135, XM-L2 3D, 10 degree TIR, PilotDog lighted tailcap.
Convoy S2+, H17F, XM-L2 4C, lighted tailcap
Zebralight SC52w-L2
Olight S1A
Olight S1R
WWEFANS
WWEFANS's picture
Last seen: 1 week 5 days ago
strongest2004 wrote:
Hi Rey.
Yes, they are all new clips.
Cliwilnew
Last seen: 2 weeks 1 day ago
Rey,
Any update on a discount code? $49 is acceptable but it would be cool to save a few dollars if possible.
Gunga
Gunga's picture
Last seen: 8 hours 43 min ago
1. ReyLight Brass Pineapple 219CT 9050 4Modes Mini EDC LED Flashlight AA/14500
Price: $39.99
Coupon Code: f48441
I saw a $36 special too but don’t know if that is just for tomorrow or something.
Cliwilnew
Thanks Gunga, that’s helpful!
WWEFANS
WWEFANS's picture
Sorry, I will update this code to the OP.
BTY, LED has arrived.
maukka
maukka's picture
Last seen: 18 min 12 sec ago
I measured 4080K with a CRI(Ra) of 91 and CRI(R9) 62. Tint is on the green side of neutral unlike a 219B, but at 4000K the deviation of 0.0039 it’s not very noticeable. I like the tint very much, even though there’s a bit of discoloration in the middle of the hotspot and a lighter ring in the midpoint of the spill.
There’s visible PWM on all modes except moonlight, but no audible whine. PWM is less visible on high than on the low and mid modes. Also some dirt under the lens in mine.
djozz
djozz's picture
Last seen: 1 hour 8 min ago
Thanks for the great data (again), maukka!
somnambulism
Last seen: 6 days 2 hours ago
Disappointed to hear about the PWM. Does using an AA vs 14500 make a difference in this regard?
maukka
maukka's picture
No difference. Also tried a lithium primary.
Now in a quieter environment I can hear whine on mid and high, but only ear next to the light. Same frequency so the output is adjusted by the duty cycle.
somnambulism
Oh well. Hopefully it’s not TOO visible.
maukka
maukka's picture
If there’s any specular highlight reflections and you move your eyes a bit, it’s very noticeable. On a flat surface, good enough, unless you try to photograph or take a video of it.
djozz
djozz's picture
I’m disappointed too about the visible low frequency PWM in the pineapple, did not expect that here (I bought 4 drivers from Rey), I thought we left that behind. And Rey should be very aware of our concerns about low freq. PWM, back in 2012 upon our request, he already arranged for his Trustfire Mini-01 group buy light that the PWM frequency went up from under 500Hz to about 1000Hz (I’m ok with anything above 1000Hz).
maukka, any idea what frequency the PWM is?
maukka
maukka's picture
2 kHz, but the problem is the low duty cycle (short burst of light, long period of darkness), which makes it very visible. On the highest mode the duty cycle is high, so it’s not very visible.
Possibly the capacitance in my leads makes the signal trailing edge slow. So ignore them, it’s just a photodiode directly connected to the scope.
djozz
djozz's picture
Ok, 2KHz is not too bad IMO, even in a low duty cycle situation. I was fearing we were back to 500Hz. Still a pity that this driver could not be done with over 5KHz PWM, or true current control in the lower modes.
So there is still a duty cycle going on on the highest mode? Sounds unneccesary.
maukka
maukka's picture
Here’s high.
Again, visually I’d say it does drop to zero signal very briefly, but the measurement doesn’t show it, too slow to react to signal changes.
WWEFANS
WWEFANS's picture
Sorry, I was told it was 2K Hz, thought it’s fine. Higher PWM might cause a worse runtime.
Will talk with them if there is any way to improve for the next batch.
Thanks for the test.
Edit: Still got a lot to learn. Thank you all.
maukka
maukka's picture
Also, I’m not sure if it has been said already but there’s no low voltage protection with 14500s. I just ran my Efest down to 1.2 volts.
WWEFANS
WWEFANS's picture
Voltage protection can’t happen on a AA/14500 light?
djozz
djozz's picture
Rey, 2kHz PWM is visible but I usually do not find it very disturbing, and I think most normal people are ok with it, but we are not normal over here Innocent
And I agree that maximising runtime is important too.
maukka
maukka's picture
I got wildly different output measurements compared to the specifications.
AA NiMH Eneloop
Moon: too low to measure in my 30cm sphere
Low: 2.6 lm
Mid: 22 lm
High: 74 lm
14500 Li-ion Efest
Moon: -
Low: 7.6 lm
Mid: 96 lm
High: 320 lm
All at 30 sec with batteries hot from the charger.
Runtime on high
26 minutes on a 650 mAh Efest IMR 14500, 115 lm*h
2 hours 37 minutes on an Eneloop XX, 137 lm*h
coftheconsumer
Last seen: 1 year 2 weeks ago
Those charts make me concerned. What’s your methodology for measuring lumens?
They also make me wonder how Reylight estimates light output. Are the numbers they gave emitter lumens instead of real world lumens?
DB Custom
DB Custom's picture
Last seen: 15 hours 27 min ago
Here’s what I got when I tested mine… 3 different cell types, Alkaline, Lithium Primary and LiIon
Testing showed the following results using a new Alkaline Copper Top 1.5V cell…
Level___Current___Lumens
1…………0.003A…….0.069
2…………0.047A…….4.002
3…………0.391A…..30.774
4………..1.325A……86.94
Energizer Lithium Primary 1.5V
1……….0.003A………0.00 on the meter
2……….0.044A………2.09
3……….0.389A…….33.496
4……….1.323A…..106.95
And with a freshly charged dark purple Efest 14500 650mAh cell…
1………..0.001A……..0.00345 (firefly, barely glowing)
2………..0.063A……10.212
3………..0.477A……96.945
4………..1.83A……362.25
Dale
maukka
maukka's picture
4………..1.83A……362.25
Thanks. These seem to correlate with mine quite well. I got lots of variation on high with the 14500.
BazzH
I like do the design of the Damascus one and would buy a Ti version of that if available. Polished, preferably Smile
lumiere
Last seen: 4 days 14 hours ago
Received mine. The LED isn’t quite centered and there’s a bit of side play in the switch, but other than that it’s fantastic. The threads are very smooth, probably the best of any of my flashlights.
Mrdrewbear
Last seen: 5 days 1 hour ago
mine arrived in the bay area last week but traveled up and down the peninsula for some reason. Hopefully it will be in my hands tonight when I get home
