DQG Smallest Series AA/14500 Version--Smallest AA Light in the world UPCOMING!
A small peek first. Will update the pics and specs tomorrow.
Specs:
LED: CREE XP-E R4/R5 (XP-E R4/R5 if the XPE R5 be sourced back at last)
Material: 304 Stainless Steel
Battery: AA / 14500 Li-ion
Mode: Lo>Hi Start on Lo (twist on/off)
Optical Glass lens; No alu reflector
Current: Hi---500mA 0n 14500 ; 300mA on AA
Lo---10mA
Current Regulation
anti-reverse protection ; anti-discharge protection
Tailstand
Weight: 32 g
The one in the middle is DQG AA.
Left to Right: DQG II AAA ; DQG AA ; NiteCore EZ AA
Update: Heavy pics
Pics heavy:
I guess I need to get one :)
Me too, but I am waiting for two different AA/14500, I should not click on the paypal button, but my fingers are trying to do it haha.
Looks a bit bigger than I thought it would be, but I think I want one. :)
Is the one at the top right a "tank E07"??? OMG is smaller!!!
Its measures are similar to itp A2?
If pixel counts can be trusted, it should be about 70mm long and 18mm wide.
That's about 5mm shorter and about the same width.
I am waiting for the full specs and price
What is the tank lenght? I could resize it on autocad and get a quite accurate if you need it.
NOPE, the one on the right is Nitecore EZ AA.
Thanks
Ric
Nitecore size = 83mm lenght 16,6mm wide
Paypal
Button
Needed
+100
I can wait to I see the specs.
+1
To me, it looks small
Its about as small as is possible without attaching a led straight to a battery. Cant wait
I am in like Flynn!!
And I'm out...waiting for the BLF AA. The thinnest AA light in the world (maybe).
The design of the DQG II quite literally Does connect the LED (on a circuit board) directly to the battery!! (i.e. no heatsink) Thats where the 5-10mm advantage mostly comes from, the rest comes from the lack of a battery spring.
if those dimensions are correct, it should be very close to 70.06mm*16.7mm, you can check it in this picture I resized to verify the dimensions:
