portable LED work light 3x18650
15 posts / 0 new
bionictony
Last seen: 3 months 1 day ago
this doesn’t mention anything about type of leds used. heatsinks look huge. who uses a worklight and what brand?
http://www.aliexpress.com/item/Portable-IP65-24LED-30W-LED-Flood-Light-W...
DavidEF
DavidEF's picture
Last seen: 17 hours 28 min ago
Quote:
24 LED 30W
That tells me all I need to know about the LEDs. Facepalm
However, if the light is generally well made (I don’t know), then the LEDs could be replaced, and it could be great for a portable wide-area flood light.
Reason is not automatic. Those who deny it cannot be conquered by it. Do not count on them. Leave them alone.
-Ayn Rand
snakebite
snakebite's picture
Last seen: 5 hours 47 min ago
DavidEF wrote:
Quote:
24 LED 30W
i think they mean 3.0w
alphazeta
alphazeta's picture
Last seen: 4 hours 15 min ago
snakebite wrote:
DavidEF wrote:
Quote:
24 LED 30W
actually I think that they did mean 30W in total.
30W/24leds = 1.25Watt each? (maybe that’s what they meant?)
I dunno, it just looks like some inefficient generic SMD LEDs were used anyway (I could be wrong though)
snakebite
snakebite's picture
push those at 1.25w/led a while and let us know how they hold up….
alphazeta
alphazeta's picture
exactly. Any over & under predictions? I say under 1,000 hours…
will34
will34's picture
Last seen: 27 min 44 sec ago
I use a nitefighter BT70 mounted on a small camera tripod as a work light, it works well and it’s powered by a 4×18650 battery carrier. The BT70 head only was $25 when I bought it last year, not sure if the coupon still works.
Easily detachable and I can mount it on a gopro short monopod and use it as a handheld light.
snakebite
snakebite's picture
I give it a few hours of angry blue light fading fast.those are good for 50ma ea on a good day.there are a few types of 5630, ect that are speced for 100ma.
Still nowhere close to the claim.
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 1 day 18 min ago
Has anyone tried these yet?
WarHawk-AVG
How about this one…with an actual 10W emitter?
10W Portable Spotlights Rechargeable Led FloodLight Lamp
will34
will34's picture
I got a CAT copycat from Lighting Ever, rated 20W, 3×18650 6,000mAh total, charges via micro USB and has powerbank function
https://www.amazon.com/dp/B074KDF6S7?ref=yo_pop_ma_swf
I’m planning to do a multi worklight/lantern review but here’s some quick thoughts:
Pros:
-Excellent build quality
-3× 18650 actually 2,000mAh each with manufacture date of just 4 months ago
-Well spaced modes
-Never gets hot because the front plate is cast aluminum and the emitter sits on top
-Emergency red flash is useful.
-Tint is nice at 5500K, not too cool and not greenish.
-Easy to open up and mod, already replaced with LG F1 in my unit
Cons
-Steps down after a couple minutes to 50% on turbo, DISAPPOINTING because it can easily handle the heat, they just decided to program it like a flashlight.
-Not quite 20W, it feels like 1,000 lumens.
-Too heavy to be used as a camping light, and useless as a worklight due to step down.
Probably good as emergency light…?
WarHawk-AVG
Ilmatic
Ilmatic's picture
Last seen: 8 min 47 sec ago
Looking for something similar…..so reserved.
BLF GT, BLF Q8, Astrolux MF-01, Haikelite SC01, Convoy L6, Utorch UT02, KDLITKER C8.2, Astrolux S1, (2) BLF A6, Astrolux S42, Inova T4R
contigo
Last seen: 1 day 10 hours ago
WarHawk-AVG wrote:
Just stumbled across this
https://www.harborfreight.com/rotating-magnetic-led-worklight-63422.html
would be sweet if this took 18650s Smile
Seemingly nice light for $8!
WarHawk-AVG
I picked up one today…
ok, here are the internals
Very very simple
star/aluminum board where the led’s are mounted
another image, simple wiring, simple push button passthru for current
AA battery area
The back part where the magnet and stand is a twist on/off
Without doing a massive amount of hacking out the AA slots and possibly shoehorning in 3-18650 it might be doable…would probably be better for some of those flat pack old cell phone batteries and maybe modding it to have a 1A TP4057 charger module hot glued down inside
It’s a very neat little light…I had a coupon for one for $7.99, magnet is decently strong and will hold quite well, decent enough light for it’s size (no 1000 watt barn burner) for for basic shade tree mechanic’n it will be more than enough.
Now I don’t know how much current you can push and with a LiIon vs 3-AA it might push it hard and cause issues…who knows…I have a few cheapo older cell phone batteries that will fit easily if I just dremel out the 3-AA slot and wire straight in…then just twist the end cap back on
