Lumintop Tool AAA review + discount code
Gearbest lumintop link:
http://bit.ly/2oJJ3eR
Lumintop Tool AAA - flashlight review
our website: http://www.lumintop.com/
Amazon store: http://amzn.to/2421r4t
Here’s the special discount for your fans in Amazon:TRF6-9KPYAH-PAFYQB
20% discount on flashlights!
be sure to purchase via the “fullfilled by amazon” and make sure you are in the lumintop direct store
First the specs:
Bulb: Cree XP-G2 R5 LED
Output / runtime:
5 lumens (36 Hours)
32 lumens (4 Hours)
110 lumens (30 Minutes)
Max Beam Intensity: 553cd
Max Beam Distance: 47 Meters
Modes: 3 Modes(Mid(Default)-Low-High)
Size:
Length: 3.2” (81.5mm)
Head Diameter: 0.57” (14.5mm)
Body Diameter: 0.57”(14.5mm)
N.W: 0.53oz(15g)
Working Voltage: 0.9v-1.5v
Battery Type: 1 X AAA (10440 Not Supported)
Water Resistant: IPX-8 (2 meters)
Impact Resistant: 1.5 meters
Accessories: O-ring, Keychain
Performance:
As you can see from these 2 graphs the Tool AAA has pretty good mode spacing. The lux is measured using a ceiling bounce that I calibrated as close to rated lumens as I could.
Runtimes were decent. My only disappointment with the light is the NIMH runtime. Although I got 8 minutes more than Lumintop advertises in their specs, I would like to see this be a bit more competitive with the Ti5. Although I didn’t make a graph, this light has awesome performance with energizer lithium batteries.
Runtimes:
NIMH - 38 minutes @ .91V
Alkaline - 40 minutes (only bright for about 20)
Construction:
The light is well built. Good threads, good contact points with the batteries, with no rattle. The reflector is OP and a glass lens. the pocket clip is probably the best of any of my AAA lights. It fits pretty comfortably in a thick pair of work jeans. I can’t say the same for most AAA lights. The o rights were all in good shape and the light did have some light lube on the threads.
size comparison:
Beam Shots:
Med mode:
High Mode:
Lumintop Tool Vs Thrunite Ti5
Final Thoughts:
What a nice little light at a nice price. I really like what Lumintop is doing with their amazon store. They offer the light in several different options, and also make it easy to get replacement pocket clips. The only negative I have to report is that runtime with NIMH is a little on the short side for my liking. The construction seems great, and the performance is nice. I took this guy backpacking and the pocket clip is plenty strong and the light is definitely water proof!
:frowning:
Amazon has a version with both clicky and magnetic tail caps for those who want to try both. I ended up using the magnetic tail cap (so now its a standard twisty) cause it shorter and personally works better for me for the way I hold the keys and light. The clicky tail cap works good when the light is detached from my keychain.
I’ll check on the code
Lumintop is working on fixing the discount code. Hoping to have it taken care of by tomorrow.
Update:
working and tested code:
TRF6-9KPYAH-PAFYQB
when you purchase make sure you are buying from
the “fullfilled by amazon” option.
thanks for your patience.
Just tried code - no go.
I just double checked it. Its good.
Use the Amazon link in the original post. It will get you to the lumintop direct store.
It won’t work for other venders selling lumintop flashlights
The only Tool listed on the amazon page linked in the first post is the Ti version.
Still doesn’t work for me using the Amazon link in the original post…
Yes, in the ti tool there is the option for the press and magnet version
Love the lumitop tool …
hate Amazon with a passion
The promotional code you entered is not valid.
Yet again, does not work!
Discount code:X68CP5MZ
Hello,every one.
This is Alvia from Lumintop.
Sorry to keep you waiting such a long time.
We are working hard to fixed the code problem.
Tested many time and different way to make sure the code is working.
Any problem ,please E-mail me:assistant@lumintop.com
There are some instuctions below for you guys :
Step 1:
Click the Official Link of LUMINTOP Amazon: http://amzn.to/2421r4t
(Please make sure you are in the lumintop direct store, It won’t work for other venders selling lumintop flashlights.)
Step 2:
Choose the products you like to purchase
And if there is option ‘2 new from…’
Please choose ‘Fulfillment by Amazon
OR
If there is no option in the end of description, add to chart directly.
Step 3:
Process to check out and Review your order, put the discount code into ‘Gift cads&promotional codes’ X68CP5MZ
Products included:
1X18650 Bat-FBA
2X18650 Bat-FBA
Brass Worm Cree-FBA
Brass Worm Nichia-FBA
Copper Tool AAA Cree-FBA
Copper Tool AAA Nichia-FBA
Copper Worm Cree-FBA
Copper Worm Nichia-FBA
Prince Brass-FBA
Prince Copper-FBA
Prince SS-FBA
SD Mini XM-L2 U2-FBA
SD Mini XP-L HI-FBA
SD4A XM-L2 U2-FBA
SD75+4X18650 Bat-FBA
Stainless Steal Worm Cree-FBA
Stainless Steal Worm Nichia-FBA
TD16 Cree XM-L2-FBA
TD16 Cree XP-L-FBA
Tool AAA Magnet-FBA
Tool AAA Press+Magnet-FBA
Tool AAA Press-FBA
Tool Ti AAA Cree-FBA
Tool Ti AAA Nichia-FBA
Banggood $9.99
Is this the best price ever?
Better than MadMax?
I get “Invalid Coupon Code” when I try to use X68CP5MZ for a Bangood Copper Tool with Nichia
Today the code “Lumintop” works to drop it to $27.96.
I chatted with bangood and they said wait till tomorrow for the $25 starting price, then use code Lumintop for 30% off to get it down to $17.50
I just got this deal….$17.50
Sweeeeet Deal!!!
Congrats!
fwiw, the head of the Copper Tool (both the ReyLight and Lumintop versions) swaps with the head of the Maratac (the NoPWM version made after Oct 2015 that has the ring around the LED) and both legos work!
in the next pic is the old version of the Tool and Maratac with PWM on left, then the new version with NoPWM and the ring around the LED on right
the latest version of the Tool, now on Sale is the NoPWM version
the NoPWM Tool and NoPWM Maratac heads are interchangeable (older models with PWM had 1 less threads and may not Lego with the new NoPWM models)
and fwiw, the head of the NoPWM Copper Worm w Nichia works on the NoPWM Maratac body too, but the Maratac head wont work on the Worm body, because the Worm has 2.5 less threads than the Maratac:
lastly the NoPWM Copper Worm w Nichia head works on the Thrunite Ti3 series (both stainless and Titanium)
Oh man. You guys are brutal! I had to get one for $17.5 since I can’t resist…
Dang!got it for the $17
Also ended up with the jet-u and a few of the $5 nitecore tubes.
Worked out good with codes and points
