SK68 clone + XM-L EZW: gnarly enough?
1 post / 0 new
Barkuti
Barkuti's picture
Last seen: 1 min 13 sec ago
Well, I've refrained from an “alu-nano” baseplate I had ordered at FagTech exactly 2 weeks ago (still on back order at least until the 18th), I just had enough. Anyway, I was thinking how could I spend those ¢s and…
Cree XM-L EZW T6-7C 860-Lumen 3000-3200K LED Emitter w/ 16mm Aluminum Base
Old design, EZ900 dies? 80+CRI, I like that!
I like the idea of trying to put this inside an SK68 clone powered by a high-drain li-ion; since it uses a boost driver, I was wondering if it would be capable of outputting the required voltage to drive such an emitter. Sounds a tad crazy, doesn't it?
Cheers Party
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
Edited by: Barkuti on 07/29/2016 - 13:12
