Tecxus AAA 1100mAh (Silver-Maroon)
Official specifications:
Nominal voltage: 1.20V
Open circuit voltage: >1.40 volt after 16h/0.1C charge
Nominal capacity: 1100mAh 02C discharge to 1V after 16h/0.1C charge
Weight: 14g +/-3g
Internal resistance: <35mOhm at 1kHz
Fast charge: 2.8h at 0.5C (550mA)
Cycle life: >500 cycles
Maximum temperature raise at different discharge currents: 1A:+1,8°C, 2A:+4,4°C, 3A:+7,1°C, 5A:+11,3°C
This is high capacity AAA cells.
The discharge curves looks fairly good and with lot of capacity.
Conclusion
This looks to be good high capacity cells and they are also fairly good at delivering current.
Notes and links
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
