P-Rocket from Shiningbeam
Reviewer's Overall Rating: ★★★★★
Summary:
Battery: | 18650 |
Switch: | Reverse with 2nd (Forward) supplied |
Modes: | 3 Lo-Med-Hi |
LED Type: | XM-L T5 Neutral white |
Lens: | Glass |
Tailstands: | Yes |
Price Payed: | $44 |
From: | http://www.shiningbeam.com/servlet/the-97/**NEW**--P-dsh-Rocket-XM-dsh-L/Detail |
Date Ordered: | 3-day delivery to USA |
Pros:
-Neutral white beam bordering on warm. Shiningbeam says it is an XM-L T5, 4B bin.
-Quit bright, more than I expected; 2.6A (H) .75A(M) .1A (l) Low is pretty bright, about like an incandescent Maglite. With Rev Jim's 18650's On a red Ultrafire 3000mAh 18650, I got 2.81 (H ), .81( M) and .13(L) Darn close to the advertised claim of "* Current output: 140mA on low, 1000 mA on medium and 2800 mA on high"
-Regulated current
-No blinky modes!
-Very smooth beam (VLOP reflector, almost smooth), emitter perfectly centered, huge hotspot with very bright spill.
-Nice HA III finish, not high gloss, more of a smooth satin finish.
-Double O-rings in front, single O-ring at tailpiece
-Comes with extra switch (forward clicky) and O-rings, lanyard and nice belt holster.
-Clean, square, and well-lubed threads
-Excellent fit and finish,nice knurling, tailstands perfectly.
-Works with 18650 as well as 2xCR123 batteries
-Good memory function
-Thick and nicely heatsinked
-Ships fast from USA
-Did I mention bright and wonderfully smooth beam with a nice color to it?
Cons:
-Need deliberate soft-press to change modes (could be a pro as well, you can't 'skip' past modes by accident)
-Expensive
-For the money, has a generic look to it, and "P-Rocket" ranks just barely above FandyFire in terms of flashlight names, IMO.
-Front bezel is OK, but I would have preferred a smooth stainless steel bezel
-Not easily dismantled, I didn't pursue it, seems to be glued. But I can't see any reason to mod it so that's OK with me. Might be a simple 3-piece that needs to have the pill removed after removing the cover around the emitter.
Here is the "flip" side of the P-Rocket. Knight Rider? Doesn't that logo look like one we were discussing a couple months ago? So I'm not sure if P-Rocket is the model and Knight Rider is the mfg, who knows? Palight logo?
The Very Light Orange Peel (VLOP) reflector
I posted a thread awhile ago asking if anyone else here has this light, and I got zero responses. Since I enjoyed my last Shiningbeam purchase so much (S-mini) I decided to order this one and try it on for size. It is also in keeping with my current "buy one $40-50 light instead of two $20-25 lights" philosophy.
Build Quality ★★★★★
No issues with build or quality of the host, switch or emitter. Emitter is nicely centered, has 'anti-roll' feature, switch is easy to use. Note; the switch takes just a bit more of a deliberate press then some of the hosts I'm used to. It makes it a little easier when changing modes to not skip a mode, because you have to give it more of a push than most of the lights I have. Once you are used to it, it works nicely.
You can shake it hard and hear the battery inside, at least with Rev Jims's 18650's. On an Ultrafire 3000mAh protected cell, you can't hear a thing when you shake it; nice and tight fit.
Features / Value: ★★★★★
Solid light, no function issues, works like it is supposed to.
Battery Life:
Unknown, didn't do runtime test. I would expect about 40 minutes on Hi
Light Output: ★★★★★
The warmer tint makes the light seem brighter than it is. Although Shiningbeam's website says it is 810 lumens, I'm guessing it is more like 675L. But the tint brings out more detail and color compared to a cooler bin. Also, the hotspot on this light is big, and just sort of blends into the spill, which is also bright.
Check out this mouseover. Our old friend, the Manafont Ultrafire XM-L is the one you get when you mouseover the image. My aim was a little different than the original MF XM-L, sorry. But you can still get a good comparison.
Summary: ★★★★★
It is hard not to like just about everything on this light except the price, at least compared to other budget lights.
Bottom line, its not a low-budget light, but it also isn't in the $75+ range either. At $47.75 less a CPF discount of 6%, its close to the AA Xeno that a lot of folks here own (OK, i'ts about $10 more). But it is a lot of flashlight for the money, and I'm glad I got it. Neutral white beams have a certain appeal the more I play with them. They don't have the WOW factor that bright cool beams have, but they are easier to look at and bring out more detail and natural colors in what you shine them at.
