LiitoKala 26650-50A 5000mah 26650 - great first impressions
283 posts / 0 new
L4M4
L4M4's picture
Last seen: 10 hours 19 min ago
The more current, the better Wink
anotherhammer
Last seen: 1 year 6 months ago
bella-headlight wrote:
My other pair of cells from the other supplier have just arrived Smile Checked the voltage & both showed 3.79v, exactly the same as the first pair Thumbs Up I have just started a charge cycle & will report back with charge & discharge results when finished Wink
Thanks for all the info! What sellers have you bought them from? The first and second pair?
myhken
myhken's picture
Last seen: 1 week 3 days ago
Has to follow this thread. Got 4 from the Ali seller and 4 from Gearbest. Will take weeks before I have them I’m sure off.
Kenneth Myhre
will34
will34's picture
Last seen: 6 hours 1 min ago
Can these be used in series or they are full flat tops?
Mitko
Mitko's picture
Last seen: 1 day 16 hours ago
They can but be advised all: those batteries are kinda not exacly 26mm but like an idea thicker, they barely fit into S70 for instance
As IMR/INR they dont perform well in series with buck drivers- i would reccoment Efest 5200 or Soshine 5500 in this case
bella-headlight
Last seen: 6 hours 54 min ago
First pair were from Aliexpress, second pair from GearBest.
Gearbest“s were much better packed Wink
They are on discharge now Smile
Ian
will34
will34's picture
Now this is something I didn’t know… Can you explain it further? Is it because of less voltage sag?
warzi1975
Last seen: 8 hours 50 min ago
They are full flat tops. Can`t use them in series. I have 4 from GB and they came in good condition at each 3,82 Volts. My discharge test on opus-bt at 1Ah shows 5445mAh, 5367mAh, 5289mAh and 5398mAh in the first cycle. Internal resistance test with opus-bt all four under 30.
Robert
bella-headlight
Mine make contact fine in series Smile
Ian
bella-headlight
Mine fit in my S70 fine diameter wise, you can even rattle them slightly so they are not a tight fit at all ?
Ian
Barkuti
Barkuti's picture
Last seen: 3 hours 30 min ago
Could you please elaborate on that?
To me, what you said there just does not make sense at all. I am to get a couple of batteries for an XHP70 custom build, powered by a buck driver I am going to optimize. As I see it, a couple of these seems wonderfully adequate: at 4'8A maximum driving current, the Vdrop caused by an in-series couple of these will always be, at most, 0'3V, which allows the driver I am going to use (unmodded) to stay in regulation down to 7'2V or about 7'5V no load; my “optimizations” (much bigger & very low ESR inductor) should allow me to enjoy a driver overhead reduction of around 0'2V.
Cheers Party
bella-headlight
Results are in from my second pair of Liitokala 26650“s Smile
Cell 1, IR during charge 20, IR during discharge 21, capacity 5104 ma
Cell 2, IR during charge 17, IR during discharge 19, capacity 5211 ma Thumbs Up
Good figures all round again & well matched, very very close to my first pair Smile
First pair were from Aliexpress & second pair were from GearBest.
Ian
JakeDjanitor
Last seen: 3 days 1 hour ago
Do these “sag” under 5a load?
Barkuti
Barkuti's picture
JakeDjanitor wrote:
Do these "sag" under 5a load?
Vsag = I × Rbatt
Since people is reporting low IR values (20 - 30ish mΩ), sag complaints are unlikely to arise.
Seem to be awesome cells, yet I'll refrain from ringing the bells too early, at least until I can see some properly obtained IR figures, HKJ or other reputable techie test them, and or I can make some tests on them (not soon).
Cheers Party
JPLight
Last seen: 1 week 4 days ago
tekwyzrd
tekwyzrd's picture
Last seen: 6 hours 51 min ago
Received the first two batteries and Lii-500 charger today and have them on the charger running a nor test at 1A.
IR for cell 1 is 23 and cell 2 is 21 during the charge and discharge phases. Cell 1 5011mAh and cell 2 5098mAh. Since the Lii-500 terminates discharge at 2.8v but typically cell specs state 2.5v the actual capacity is well above the listed 5000mAh.
I decided to order two more yesterday and using my points again the total for all four cells I’ve ordered from gearbest was $20.50 including tracking.
tekwyzrd
tekwyzrd's picture
gauss163 wrote:
Anyone know why they call it a “nor” test? Is it derived from a non-English word?
I suspect it’s an abbreviation for ‘normal’ since there’s also a fast test.
Abbreviations for ‘normal’
JPLight
Whatever “nor test” is meant to be, the charger does a normal test when set to “nor”. Wink
Mitko
Mitko's picture
My second order was “scanned by X ray and returned”….well.. i do hope at least GB one to arrive, it seems that declaring those as kitchen goods dont work always .
X ray FTW
finges
Last seen: 2 hours 49 min ago
I also received a pair from gearbest. For 10$ it is a steal!
Both cells measure 5600mAh in my charger and power a FET driven XHP70 light with 8A at start!
Better then my keeppower 5200 cells!
myhken
myhken's picture
My first 4 is in from Aliexpress, and the result on Opus 2.2 is around 5200mAh on each. So very good. Do see that others gets even higher numbers, but I did only do one test @1A
Kenneth Myhre
tekwyzrd
tekwyzrd's picture
My second pair should be here in a few days since the package was processed through isc chicago three days ago. The first pair is working fine in my Convoy L5 (LD-29 driver) after swapping in a xm-l2 u3 2c, bypassing springs, foil wrapping the pill, and fabricating a copper insert to deal with tailcap contact and switch centering. Time to order some resistors to boost output current. The batteries are making + to – contact just fine in a 2s without a magnet. Fit is a bit snug but they slide in with no effort.
mattlward
mattlward's picture
Last seen: 3 days 17 hours ago
Got mine in today… Charged in the Liitokala Lii-100, rested 30 minutes and wow! I pulled 6.45A in my favorite pocket rocket. It is an Uniquefire UF-2200 with all springs bypassed, XM-L2 4C and a very strong driver! I am liking these batteries, my KK 26650’s could not sustain that much.
EDC rotation:
Convoy S2+, 6*7135, XM-L2 3D, 10 degree TIR, PilotDog lighted tailcap.
Convoy S2+, H17F, XM-L2 4C, lighted tailcap
Zebralight SC52w-L2
Olight S1A
Olight S1R
Mitko
Mitko's picture
Yes m8, i allready got 8 of those and i can cleary call those the best all arround 26650 batteries in existance so far- lets hope they dont “ nuke” them as it usualy happenes
tekwyzrd
tekwyzrd's picture
Received second pair and they’re currently in the charger under test. Ir 18 and 21 milliohms. I consider the $5/5000+mAh a real bargain. @Mitko – thanks for pointing them out. They were a nice addition to my LiIon supply.
Hunter
Last seen: 12 hours 39 min ago
5$?
It shows 9.20$ for me!
akhyar
akhyar's picture
Last seen: 2 months 2 days ago
Hunter wrote:
5$? It shows 9.20$ for me!
Gearbest still selling it @ $5.36/pc.
I got mine from them 2 weeks ago. Good deal
$9.xx will get you a Keeppower Black Big Smile
tekwyzrd
tekwyzrd's picture
That’s $5 each. I got 4 cells total for a bit over $20 including 2x mandatory $1.99 tracking (two separate purchases) after discounts for gearbest points.
Hunter
Thanks for the info, I was looking on aliexpress Smile
I see they have discount: 4 pcs = $19.99, I am tempted!
finges
You can get a pair of these at gearbest for around $10 http://www.gearbest.com/batteries/pp_360841.html
