LiitoKala 26650-50A 5000mah 26650 - great first impressions
283 posts / 0 new
Battery Man not...
Last seen: 1 year 6 months ago
100% same resource
18650 battery is the best
Battery Man not...
Tom E wrote:
Got in my GearBest battery order: 4 LK’s, 4 SONY VTC5’s, and 2 GA’s – total of $47 is simply outstanding. Could have spent that on the VTC5’s alone from some other sources.
I did a capacity test on my Opus of 2 of the LK’s (LiitoKala) and got:
  • 5420 mAh
  • 5428 mAh
So seems right in line with what others are getting/have posted. Quick test in my FET+1 (ATtiny25/SIR800DP/dedomed XM-L2 U4 1C) based Convoy L2, and got the following measured at the tail on a clamp meter:
  • LK 4.22v:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;5.43A</li> <li>BASEN 4.22v:  5.42A
So for internal resistance, seems right in line with the BASEN cells, and also the EFEST 4200’s I’ve measured in the past on the L2. This a somewhat limited test though without testing actual lumens output over time, comparing the cells, so not sure how much it’s worth.
Bottom line is having a 5000+ mAh cell with performance at, or around, the best performance on any cell available is pretty amazing. I’ll be ordering more…
Thanks Mitko!!
Edit: Has anyone confirmed these sold at FT under the Soshine brand name are the same thing? https://www.fasttech.com/product/3486100
They sure look exactly the same, accept for the cheap name brand printing…
100% same resource
unknown00101
Last seen: 4 hours 36 min ago
Hmm.
My Opus 2.2 is showing 54 and 50 on the IR quick test with 5130mAh and 5205mAh on the two LiitoKala cells I acquired.
Barkuti
Barkuti's picture
Last seen: 38 min 57 sec ago
unknown00101 wrote:
Hmm.
As if I were to trust those cheap electronic devices with regards to precise DC internal resistante readings… Facepalm
Get a decent multimeter capable of at least reading to mV, and a load with precisely known sufficiently low ohmic resistance to induce a noticeable reading delta on the meter. Do your math then (promediating both initial and final no-load voltage readings in order to dismiss any potential inherent variation in it due to the own discharge process).
Cheers Party
The Miller
The Miller's picture
Now this is interesting, used Heters in the S70 and Liitokala in the L6
The L6 got much warmer and was brighter.
Since the Heters have buttons I have to remember which one was placed head side and swap each charging.
The Liitokala have no button so I use a magnet. Before charging I put the magnet on the other one so the swapping is easy and requires no remembering.
Decided to do the same after checking the ano of the inside of the S70 and seeing it is good.
And now the S70 is brighter then the L6 and not just a tad but really obvious brighter. It also gets warmer then before
These Liitokala cellsist provide more power, nice!
Battery Man not...
unknown00101 wrote:
Hmm.
OPUS test result for IR is not accurate
bella-headlight
Last seen: 6 hours 19 min ago
Battery Man not Batman wrote:
unknown00101 wrote:
Hmm.
Agreed, it has been stated on here several times that the OPUS gives higher than true readings.
However as long as you always use that same charger for analysing you can still get get an idea of how your cells are.
Ian
Mitko
Mitko's picture
Last seen: 3 days 7 hours ago
I already got like 16 of those, they all have the same good quality: a bit better than Efest 4200
For me its the best high amp 26650 battery atm: and overall the best too, the price is lovely also
P.S
A tip: orther them from GB – they somehow manage to ship them safely to EU- all my orders came very fast so far, declared as kitchen goods, “ srom stuff”( dunno what that means , a quote) or just el. components
sidecross
sidecross's picture
Last seen: 11 months 3 days ago
P.S
Thank you again for updating information on this battery. I have ordered 8 of them from GB too, but they still are on route.
They seem to be a good battery and very much like my favorite Vappower 4200mAh, but at much lower price
“You must have a plan, if you don’t have a plan, you will become part of someone else’s plan.” Terence McKenna
Mitko
Mitko's picture
P.S
I also got several Vappower 4200mAh before, they perform lesser than Efest 4200, they are like Keeppower 4200 actualy, good battery but nothing like Li 26650, the last one realy shines with out BLF fet DD drivers
sidecross
sidecross's picture
This is good news the Vappower 4200mAh are older and very hard to find in the U.S.; I have used the Keeppower and the Shockli 4200mAh’s and found them to be good too.
The Li is a bargain. Smile
SubLGT
Last seen: 9 hours 6 min ago
There appears to be a new 26650 champ in the 4200mAh category. Tested by Mooch at the ecig forums:
https://www.e-cigarette-forum.com/forum/threads/ijoy-40a-4200mah-26650-b...
Excerpt from his test report:
“…This is the first 26650 I’ve tested that acts like an 18650. Its internal resistance is lower than many of the good 18650’s and it held its voltage well. At 30A/100W pulsed it ran approximately 75% longer, and 0.15V-0.20V higher, than the Basen and Brillipower 4500mAh cells down to 3.2V. It doesn’t match the appearance of any other 26650 I have so I don’t know where this cell came from…”
snakebite
snakebite's picture
Last seen: 6 days 11 hours ago
the construction resembles the bak cells.
likely made by bak.
sidecross
sidecross's picture
Here are the specifications for this battery (I did not find them in the original comment).
http://www.ijoycig.com/product/item-294.html
Barkuti
Barkuti's picture
That $22'99 (Ouch!) I-Joy 40A 4200mAh is just another niche product for preppies with horrible price/performance ratio. Meh…
Cheers Party
bella-headlight
Is that $22.99 per cell Shocked
If so that is about the price of 4 Liitokala 26650“s.
Ian
teacher
teacher's picture
Last seen: 19 min 7 sec ago
Yep, in fact it is $3.40 higher than the last 4 I just bought & received. I got 4 for $19.59 at GB. Smile
      You never know how a horse will pull until you hook him up to a heavy load. / Paul "Bear" Bryant ~/~\~ "Slow is Smooth, Smooth is Fast"
       Texas Lumens Flashlights  <>   M4D M4X Deals : sign up - save $$$$    ||||
         Rudeness Level /\ mΩ /\ {width:70%} /\ LightWiki /\ LED Tint Chart /\ LED Tint Picture /\ Xlamp size chart /\ BatteryU                   Flashaholic? Need Professional Help???   wink   /\ TheOriginal /\ TAB /\ LightSearch /\ BatterySearch /\ 14500's /\ DiCal
Barkuti
Barkuti's picture
Hello!
Excerpt of a report about my findings on internal resistance for these batteries, published last wednesday 2016/09/07 here (e-cigarette-forum):
0K. Just to let you know I've done some smartass battery IR testing on the sixpack. With a LiitoKala Lii-100 charger (pumping close to 1'05A, maybe ≈1'047A, no lab equipment sorry), my standard multimeter and this mV accurate voltmeter:
Well, the voltmeter drains 10+mA (I think the eBay ad claimed 11mA).
All the cells have shown 23ish mV load/no load deltas (measured with the wires under the flat top button, it shouldn't have any significant impact at this current though). The numbers look pretty good, 22-23mΩ of resistance for these cells. Clearly 20A continuous 26650 cells, with 5+Ah of capacity.
Just remembered…
Cheers Party
snakebite
snakebite's picture
matches with my findings.dick smith esr reads .02
unbeatable price/performance on these cells!
esr
best thing is you get to build it.
w1ckd
Last seen: 1 year 8 months ago
Sorry for bumping this thread, but i had ordered the same liitokala 26650 from aliexpress to use in a flashlight.
The thing is that i need to put 4×26650 bateries in serie.
After the fact of ordering and receiving these batteries i read i cannot put them into series?
Or can i with the help of something like?: Assuming a coin wont work? Smile
Mitko
Mitko's picture
I nice blob of a silver based solder will do better m8, ways ways better
mattjk
mattjk's picture
Doesnt need to be silver based solder its not stainless, 60/40 is mustard. Just use some extra flux or scrape the top a bit if its oxidised or dirty
Barkuti
Barkuti's picture
sidecross
sidecross's picture
!{height:300px; width:300px}http://g03.a.alicdn.com/kf/HTB1zCuYJVXXXXXGXFXXq6xXFXXXH/-Connector-for-...!
AliExpress is showing this product no longer available.
The Miller
Tested the jaxman connector in my Opus and Liitokala charger and did not see resistance go up http://s.aliexpress.com/qMZJ3aaq
(from AliExpress Android)
Nice thingy
But after testing the inside of my S70 and L6 tube I know the anodization is good and it is not conducting
So I choose magnet for connecting and when charging I put the magnet on the top cell before putting it in the charger so it becomes the bottom one and every charge their position changes (idk if it makes a difference it just feels good to do it like this)
Theodore41
Last seen: 13 hours 20 min ago
Mitko wrote:
Well there are offers for 6$+
I looked at the link you put,but it is a mess there.The prices differ 50% between them.Which are good and which not.
sidecross
sidecross's picture
I decided to use non-protected batteries that can be used in series; there are quite a few to choose from that have a positive terminal suitable for vertical series connection.
I use the Liitokala batteries in my single cell 26650 flashlights.
teacher
teacher's picture
Or you can get them where I get mine……….. RIGHT HERE . Never a problem so far with 3 separate orders.
That Jaxman connector works great by the way……. Thumbs Up
Theodore41
I look at the alphanumeric writings on these batteries,and I see that there are not the same in different sites.Do you know if some of them are better than others?
https://www.aliexpress.com/item-img/Free-Shipping-2PCS-LOT-Real-Capacity...
https://www.aliexpress.com/item/1PCS-LiitoKala-26650-50A-5000mah-26650-L...
sidecross
sidecross's picture
I had no problem ordering the batteries either, what I tried to write is that the Jaxman ‘connector’ is no longer available from AliExprees. Smile
