LiitoKala 26650-50A 5000mah 26650 - great first impressions
283 posts / 0 new
teacher
teacher's picture
Last seen: 28 min 40 sec ago
snakebite wrote:
absolutely.test equipment is a triton hobby charger.
i still have 2 and will test them over the holiday weekend.
the other 4 from the order are in box mods and doing great.
Thank you ‘snakebite’, looking forward to the results. Thumbs Up
      You never know how a horse will pull until you hook him up to a heavy load. / Paul "Bear" Bryant ~/~\~ "Slow is Smooth, Smooth is Fast"
       Texas Lumens Flashlights  <>   M4D M4X Deals : sign up - save $$$$    ||||
         Rudeness Level /\ mΩ /\ {width:70%} /\ LightWiki /\ LED Tint Chart /\ LED Tint Picture /\ Xlamp size chart /\ BatteryU                   Flashaholic? Need Professional Help???   wink   /\ TheOriginal /\ TAB /\ LightSearch /\ BatterySearch /\ 14500's /\ DiCal
snakebite
snakebite's picture
Last seen: 6 days 15 hours ago
cell 1 cycle 1
5117@1a
cell 1 cycle 2 after fixing the test rig.
5211@1a
cell 2 cycle 1
5277@1a
cycle 2
5451@1a
teacher
teacher's picture
snakebite wrote:
cell 1 cycle 1
5117@1a
Good info, thank’s ‘snakebite’. Thumbs Up
They (LiitoKala 26650’s) seem to be staying fairly consistent as time goes on. I hope it continues. Wink
wstrachan
Last seen: 6 hours 41 min ago
Are you at all interested in modding my Utorch UT02 (Manker U21)? I would certainly pay for materials. Maybe work a trade of some kind? Maybe a new in package Lumintop TD16? Or something else.
light addict....yeah I've got the bug.
Haikelite MT07S
Imalent DT70
Klarus XT12GT
Olight javelin mx3x
thrunite tn32 ut
acebeam k60
many, many others...
snakebite
snakebite's picture
update.
i discovered high resistance in my test rig.banana plugs to my holder were losing their tension.
charged the cells again and started another discharge.holding 4.13v @ 1a at start.
was 3.96v.
so these are likely better than we thought.
stay tuned…
Tom E
Tom E's picture
Last seen: 1 week 3 days ago
What do you want done with it? I like a dedomed XPL in it, but some might prefer it domed.
khas
Last seen: 1 day 9 hours ago
I received four from GearBest yesterday, first charge>discharge cycle @ 1A down to 2,8V :
I started the cycle this morning before I went to work so the cell voltage recovered a bit.
I am recharging them now :
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 6 hours 42 min ago
What is the max current draw you get these from these in a direct drive set up? I just bought 6 shipping was 11 USD so i hope they do well.
snakebite
snakebite's picture
well i found a bug.
kingkong 26.21mm
liitokala 26.63mm
too fat for one mod.
will post brand/model when i get it.
they fit all my lights though.
Texas_Ace
Texas_Ace's picture
Last seen: 14 min 17 sec ago
These are a bit wider and a bit shorter then most other 26650’s, it fits like a glove in the L6, it doesn’t fall when inserted it just slowly lowers itself to the bottom.
Know guns, know peace, know safety. No guns, no peace, no safety.
The ultimate result of shielding men from the effects of folly is to fill the world with fools. --Herbert Spencer , English Philosopher (1820-1903)
Texas Avenger Driver Series
My LED Test series - XP-L2 V5  - Nichia 219C 90+ CRILatticebright "XM-L"XHP35 & PWM efficiency - XHP50 - XP-L V5 - XM-L2 U2 - XP-G3 S5  - XP-L HI V2 - Oslon Square & direct comparison to Djozz tests - Nichia 319A - Nichia 219B 9080 CRI - Nichia 219C D320 - Nichia 229AT - XHP70.2 P2 - XHP50.2 J4 - Samsung LH351D
Easy comparison tool for all my LED tests
Barkuti
Barkuti's picture
Last seen: 20 min 50 sec ago
Gonna get some serious amps mangled from them pretty soon…
The BMS low voltage/under discharge protection works well. I accidentally hard-shorted the BP+/B- terminals while assembling the stuff, a lil smoke crept away…  Had to hook the thing up to the charger board to relive it. Quite interesting to notice my multimeter could actually measure some volts at the output terminals after the “accident”, a below 1Hz voltage signal oscillating between very high 6s and low 7s.
Cheers
madsnake
Yesterday i received my 2 pcs. I put them to the test with my Opus.
1 cell at 1A – 5434mAh
2 cell at 1A – 5534mAh
I will test them these days on my L6 and will see how they perform.
lumiere
Last seen: 1 month 1 week ago
Received one from Banggood. Did discharge test in Opus BT-C100: 4898mAh. A bit disappointing. Impedance test afterwards showed 76mR.
Just noticed that the product listing has disappeared from Banggood…
StandardBattery
Last seen: 5 days 18 hours ago
Interesting, I picked up some of these because of good reports earlier, but I have not tested them, waiting for some nice new light. Maybe I will test them when my test charges arrives and then put them back at storage voltage until I have a need for them. They sure seem like a pretty good bargain.
bella-headlight
Last seen: 10 hours 34 min ago
Well HKJ has now reviewed these cells & says about them “The cell live up to its rating and is one of the top performers for 26650 at the current time.”
http://www.candlepowerforums.com/vb/showthread.php?429598-Test-review-of...(Cyan) Thumbs UpThumbs UpThumbs Up
Ian
teacher
teacher's picture
Thanks for that link! As far as I am concerned this pretty well verifies what we thought all along. Thumbs Up
Which brings me to another realization.
If HKJ’s “Discharge Capacity numbers” are accurate, and I feel sure they are; my LiitoKala Lii-500 is much more accurate than my Opus BT C-3100 v2.2 when measuring “Discharge Capacity”. Interesting…….. Wink
Edit: Forgot to say…… Facepalm
My Opus reads consistently high, and from some of the Opus numbers some others have posted in the past, mine appears not to be the only one. Wink
bella-headlight
Yes I think that it is generally accepted that the OPUS is a little “optimistic” in terms of cell capacity.
My OPUS certainly is.
Ian
teacher
teacher's picture
“Optimistic” that is a very scholarly way to say that!! I “b” impresseded. Thumbs Up
Do you happen to be a “scholar” ??? Wink
Innocent
Edit: I was doing some looking back on things I had written down, and best I remember Ian; you and I compared numbers from LiitoKala 26650’s done on both chargers. Our numbers were very comparable for both chargers as each of us has a Lii-500 & a BT C-3100. Pretty interesting results for two different continents. Wink
bella-headlight
Yes our numbers were almost identical.
These cells have proved to be pretty uniform in capacity tests done by many different members Thumbs Up
It is nice also to now have HKJ“s review to confirm what many members have experienced with these cells.
Also the Lii-500 chargers seem to be pretty consistent as well Smile
Ian
teacher
teacher's picture
Well said, I agree completely. Thumbs Up
will34
will34's picture
Last seen: 1 week 2 days ago
Anyone ordered recently and got the good batch? from where?
Thanks
Slayer1
Slayer1's picture
Last seen: 3 hours 22 min ago
GB flash sale tdy for 1pc. Ordered 2pcs..
sac02
sac02's picture
Last seen: 3 weeks 5 hours ago
Is there anywhere to get these with free shipping any more?
Tom E
Tom E's picture
Just ordered qty 4 of the singles - shipping to us is only $3.73 now for qty 4, much less than previous. I was able to use some pts so got it down to $21.95 shipped for 4.
sac02
sac02's picture
haha, I did the exact same!
Mitko
Mitko's picture
Last seen: 3 days 11 hours ago
GB ones are exellent though! The last 5-6 shimpents came kinda slow yet they are from the good ones
Speed4goal
Last seen: 1 week 5 days ago
After 40-50 cycles mine still test at 5200 mah on my opus. I do tend to baby them. No more then 1 amp charging usually very rarely 2 amps. And if no other cells need charging I’ll let them charge at 500mah overnight
Edit wanted to add my opus slightly undercharges. So capacity may have been slightly higher if it was charged to 4.20 or higher. I regret not getting another 4 of these cells last summer. I regret not stocking up on old xpg2 as well. But I digress.
My vc2 goes to the high end of 4.23-4.24 which is fine with me its within spec. My liito 100 overcharges. Just saw the other day 4.27 and was on the right setting. Wonder how long its been cooking my cells.
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
Zebretta
Last seen: 2 weeks 2 days ago
Did these work in your L6 without modification? I was wondering if they will need a solder blob to work in series?
Speed4goal
It depends sometimes two work with no modification. And sometimes they don’t. The jaxman connecters work great. And cheap. I ended up taking a small knife and bending each of the openings on the top just barely up so they make contact. Works flawlessly now. Its luck of the draw some peoples work in series without a blob or connector and some don’t.
kuoh
Last seen: 13 hours 41 min ago
These are flat tops and will not work in the L6 without modification. I just bought a Jaxman battery adapter instead of trying to solder on the batteries.
https://www.aliexpress.com/item/Connector-for-flat-battery-series-instea...
KuoH
