Hiya hiya!
Seems the lathe has been calling my name lately. This time, something uniquely different from my 2 previous builds. A fatboy tube light, utilizing the Trustfire 32650 cell that has 6000mAh capacity! This is a triple XP-L V6 1D with a CUTE-3 optic on a 32mm Noctigon and using 18ga Turnigy leads.
I bought a piece of T6061 Aluminum at the local machine shop in a 2” x 6” size. Started by building the internals, beginning with the copper pill. This piece of 100% pure copper must be inlaid with diamond chips or something, it was brutal on my lathe and took me 4 hours just to make the pill! Once that was done, I cut the inset hole for the switch and threaded the top portion for a brass retaining ring. The idea was to keep the light a one piece design save for this removable tail end to change the big cell. On the top, the copper pill is inset and threaded in, with an aluminum retaining ring holding the optic down.
Walls at the top are 6.5mm thick, while at the cell they’re 9.5mm thick! Big, tough, and enough mass to run the light in accordance to the fat cell, I hoped.
So here’s the initial light, a smooth shiny bar of 6061 aluminum. Yes, that’s a complete light!
The aluminum retaining ring and brass retaining rings were both “lathe tight” meaning I didn’t cut any tool holes but machined them to match the light and let the cutting forces thread em in tight. I loved the look, but ultimately had to alter that to “mod” it. lol
Looking into the fat cell tube. The aluminum retaining ring there just happened to fit when I came in Tuesday night, so I put it together to see if it’d work.
The tail section with a bronze phosphor bypassed spring feeding the mini Omten switch.
But the smooth finish was too slippery, clicking the tail switch would push the light through my fingers. So I took it apart and headed back out to the shop yesterday morning.
While the machined-as-one-piece light hid the tail section amazingly well, I still used the fin to further make it impossible to see where the one break is… I hid the joint in the corner of the fin, this also helps keep any dings from showing that might occur changing the cell.
As you can see in this image, I made the fins the same shallow depth the entire length of the light, then went back and cut the ones at the copper pill deeper for actual thermal dispersion. A staggered step-up toward the head gives a semi-reflector appearance to the inner profile.
Removing the top ring and optic
A look at the top, XP-L V6 1D’s with 18ga leads… I ran out of black so I used a Sharpie to mark the negative lead. lol
The top of the body, shelved and threaded for the copper pill
A seriously solid chunk of aluminum!
The copper pill, with it’s new brass retaining ring and copper disc on the spring for a good flat positive connection to the big cell.
Before the copper disc, showing off the MTN ATTiny25 FET+1 driver that I loaded with Bistro
And I polished the honeycomb pattern off the Ledil CUTE-3 optic, this netted me over 300 lumens in conjunction with the copper disc on the spring.
So, initially I was seeing 13.88A for 3519 lumens in Turbo. After the polished optic and copper disc, I got it up to 3881.25 lumens. Low is a measeley 9 Lumens.
Then I recut the opening between the driver and cell, allowing the pill to fully seat and I put a brass post with an 18ga bypass in the tailcap for a solid gain up to 14.2A and 4502.25 Lumens! I Like It!
So there ya go, my big fat beefy 32650 tube light, XP-L Triple at 4500 lumens. Beam outside is a big coverage, not a hot spot per say once you get a bit of distance but not purely flood either. I’ll try to get out and get a shot, we’re having more storms roll through…
Thanks for checking it out! Love doing this, except for the grisly copper part, and especially love the output!
Oh yeah, forgot to mention, with the Trustfire 32650 cell installed it weighs in at 665 grams!
Edit: 5-29-16 5:33PM
I did a little fine tuning on the tail switch end this afternoon, after all the modifications and such it was getting a little scratched and the brass retaining ring was seating deeper, exposing threads. So I tweaked it and now have it at a finished level.
I’ll have some brass or 7075 to make a final optic bezel from sometime next week so that should finish it and I can proudly shelf it. lol
Edit: Finished! I got a piece of 1/2” thick 2” wide x 2” long Alloy 385 Architectural Bronze and made a new Optic retaining ring. This took me a few hours, having to make a tool to cut a plunge cut into the square piece of bronze to get a round out of it. Fun fun fun! I placed the o-ring, used the friction of the lathe when fitting it in place to tighten it, so it’s in there with no easy way to get it out. lol
Love it!
