Handmade AAA Copper Tube Light
34 posts / 0 new
CRX
CRX's picture
Last seen: 1 min 49 sec ago
This little one is made from some 12mm copper tube, copper squares, magnets, an extendable aerial and an old aluminium marker pen using only small hand tools. Smile
The light slides apart so is held together via friction and neodymium magnets soldered to both the driver board and switch contact which hold on to each end of the battery.
I used cold bluing solution to make it look antiquated.
Three mode memory driver, 0.9A, 0.4A and 0.10A
XM-L2 4C on Copper DTP MCPCB in handmade aluminium pill
Reverse clicky tailswitch
Modified TIR Optic (floody)
Weight with cell 39g
I usually modify lights but this is my first built from scratch (or bits n pieces really) Wink
Sorry i did not take pictures during the making.
hank
hank's picture
Last seen: 1 day 13 hours ago
Nice!
CRX
CRX's picture
Thanks, it was about the only option i could think of without the use of threading.
WWW
Last seen: 2 weeks 1 day ago
Got to love the look of aged Cu. Great job by the way.
Firelight2
Firelight2's picture
Last seen: 1 hour 15 min ago
Very clever way of holding the light together. Great job!
The Miller
The Miller's picture
Last seen: 4 months 4 days ago
Very VERY nice!
OscarM
Last seen: 2 years 5 months ago
nice and clever build!
Ouchyfoot
Ouchyfoot's picture
Last seen: 3 weeks 1 day ago
I love it. I’ve always considered making a tube light out of copper plumbing pipe, but could never figure out how I would access the battery without the ability to make threads.
MG
Nice job! Enjoyed the pics.
djozz
djozz's picture
Last seen: 11 min 3 sec ago
Nice work!
I think every modder has at least thought about how to make a light of plumbing pipe.
MRsDNF
MRsDNF's picture
Last seen: 21 hours 2 min ago
12mm Copper tube? That is one tiny (skinny) light. Great light you have built from scratch using your own mind and tools at hand. I love every bit of it. Now for the million dollar question. Whats next? Smile
ImA4Wheelr
Last seen: 1 week 5 days ago
Congrats on a good looking and handy creation.
WillyD
Last seen: 1 day 2 hours ago
Excellent work! It’s been a while since I’ve seen a thread on a copper pipe light.
Beachlogger
Bump to the top, this is what makes this forum great! Super
TexasLumens
TexasLumens's picture
Nice light…. Creative I guess!!! LOVE THE PATINA ON BOTH!!!! BEAUTIFUL! TL
Texas Lumens Website… http://www.texaslumens.com
WE LIVE IN THE LAND OF THE FREE ONLY BECAUSE OF THE BRAVE!
Andyman
Love it! Thanks for sharing!
If these were for sale, I’d definitely consider buying one… Cool
scrumpypaul
scrumpypaul's picture
Last seen: 3 days 2 hours ago
CRX – that is just lush. I love the industrial look.
Well done,
SP
MRsDNF
MRsDNF's picture
I’m with you here Beachlogger. Its certainly a change from some of the shenanigans thats been going on lately. Smile
patmurris
patmurris's picture
Last seen: 2 days 20 hours ago
Pretty clever! Thumbs Up
xevious
xevious's picture
Last seen: 9 hours 34 min ago
Wow, this is VERY cool! Fantastic work, CRX. Would be so great if at some point you could do a write-up of assembly and where you got the parts. What’s the inner tube you fashioned that the copper tubing slides over? Is it aluminum?
I could see this easily being used as a flashlight prop on some minimalist sci-fi production.
CRX
CRX's picture
Hey, thanks for all the great comments, much appreciated!
Yes that’s the barrel from a silver aluminium pen, it’s the only piece of tubing i had handy that was a snug fit for both the inner diameter of the (plumbers radiator) copper pipe and the outer diameter of the cell. It is quite thin, approx 0.5mm.
The pill is made from the same pen with a piece of aerial tube press fitted inside to make a ledge on which the 10mm copper MCPCB sits, the LED board has a 3mm round of copper ( made from copper squares ) soldered onto the back which fits tightly inside the aerial tube inside the aluminium tube inside the copper tube… LOL
The driver is potted with RTV silicone inside the pill and filed down to press fit in the copper host with a 5×2mm neodymium magnet soldered on, same with the switch.
Because of the design waterproofing is not really possible so the copper switch cover made from 1mm copper squares again is epoxied to the top of the switch, but there’s a fair amount of thick silicone grease around the plunger and this is also press fitted & fixed in place with thermal adhesive so i reckon it could take a quick dunk. Wink
I also soldered a round piece of 1.5mm solid copper wire to the underside of the outside rim of the switch cover to help with stability. The TIR from an old light is filed slightly to press fit also and sanded on front.
The decorative lines are done by wrapping insulating tape around the light three or four times at 0.5mm intervals to make a guide for a junior hacksaw, i just sit the light on top of open vice jaws and lightly go around the grooves a few times while rotating the piece.
The patina is achieved with Birchwood Casey Brass Black .
The light was made on a whim when i came across a couple of cuttings of pipe from when the radiators were installed, the other stuff i already had and it took about six hours to make.
MRsDNF
MRsDNF's picture
I’m not sure if I read the above correct. Pens, silver at that, aerial tube, bits of copper and on we go. I think I best go have a lie down and come back and read it again. Silly
CRX
CRX's picture
Might be wise LOL
TexasLumens
I keep finding myself wandering back to this post. These are both just so creative and innovative. Thank you for sharing.
TL
bugsy
Last seen: 3 years 7 months ago
That triple maratac is pretty.
CRX
CRX's picture
Yeah, one of my favorites. It has 3 Nichia 219C emitters now and a 17mm FET driver, pulls over 8A at startup with a 20 second turbo timer to 50%. It’s a fair chunck of copper so just gets nice & warm all round set up like that.
erik
erik's picture
nice work
i like also the maratac triple, do you have a build topic
xevious
xevious's picture
Thanks so much for the details, CRX. Thumbs Up
Looks like a fun build. Also, hadn’t heard about cold bluing before. Might be fun to try this cosmetic treatment out on a copper Astrolux A01. Big Smile
lumenzilla
lumenzilla's picture
Last seen: 13 hours 38 min ago
That’s an awesome build, man.
ReyLight
ReyLight's picture
Last seen: 12 hours 22 min ago
Nice build, thanks for sharing. I’m actually very interested in the tri-Maratac, what is the size of optic and where to get the copper pill?
TexasLumens
I have one of those Maratac but the natural patina isn’t as pretty as what is on yours. It must me that Scottish salt air!!! Wink
TL
