Cree XP-G3, testing a S5 3A emitter
105 posts / 0 new
Texas_Ace
Texas_Ace's picture
Last seen: 4 hours 31 min ago
garrybunk wrote:
Ah, ok. So I guess they typically don’t fit a Quad XP-G2 optic? So perhaps the XP-G3 is the safer bet.
-Garry
The teardown pics looked like XM-L2’s in the stock light? Or are those G2’s?
If G2’s then yeah I would just go with the G3’s and be done with it.
The issue is finding a local source for them. Cutter has them and there are a few local places that offers them as well, just not in a very wide range of tints and bins.
Or the XP-L HI. The HI version throws basically the same as an XP-G2 with less tint shift around the edges if your lens has an issue with that.
garrybunk
garrybunk's picture
Last seen: 18 hours 18 min ago
They’re XP-G2’s.
Good to know. Guess I wouldn’t have any issue with the optic resting over the XP-L HI’s would I? Hmm . . . or would I? Seems I would as there is no dome to rest the optic on. The legs of the optic don’t touch anything, just go down through the openings around the pcb. I’d probably just go XP-G3 anyway.
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
The_Fat_Controller
The_Fat_Controller's picture
Cree, Inc. has introduced a new high-efficacy (HE) edition of the XLamp XP-G2 LED, a progression that the company claims yields greater output and higher efficiency than its predecessors.
The new XP-G2 is optically compatible with the original XP-G – providing drop-in-ready performance enhancements to shorten the LED fixture design cycle and improve time to market. A new high-efficacy option is available, as well. The High Efficacy XP-G2 LED leverages Cree’s latest high-power chip technology to deliver 25% more light output via a higher maximum current of 2000 mA, higher efficacy and lower thermal resistance. Combining high light output, reliability and efficacy, XP-G2 is optimized for directional, high-lumen applications
I know these are relatively new out but does anyone know of supplier with stock?
Xp-G2 S4 HE 180Lumens @ 350ma XPGBWT-BE-0000-00L50
More importantly can this new emitter knock the XP-G2 S4 2B of its pedestal for king of the throwers??
Scallywag
Scallywag's picture
Last seen: 3 days 8 hours ago
It has been dethroned. Comparison table here.
Old Lumens Contest 2020 - Hand-made light category
ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20 | Baton S1
Boruit D10 w/ Quadrupel Fet+1/Anduril | EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Olight S15 Ti | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special | Thrunite T10Tv2
Supfire M6 3xXHP50.2, Sofirn C8F, Unfinished: Sofirn SP70, IYP07/Tool AAA hot-rods, Jetbeam E3S
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
The_Fat_Controller
Wow!! good god!! dethroned , its been lane waste, thank you so much for answering I have spent days reading posts and asking questions on CPF all to no avail first post I make on here an i have an answer , so the Osram KW CULNM1.TG is now the king for a super tightly focused thrower presumably the 1mm version? do you still dedome them or jut buy the flat version?
Been looking to upgrade a nigthmaster Xsearcher with a new driver/emitter combo & crelant 7g5cs this should be just the ticket
djozz
djozz's picture
Last seen: 21 min 29 sec ago
The only place to buy the KW CULNM1.TG is at led4power.com. The bare leds are out of stock, but he still has 2 reflowed on a 20mm MCPCB, and 4 on a 16mm MCPCB. Not sure when or even if he will get them in stock again.
These are very low voltage leds so even if you want them at 5A you need to regulate the current or they die from overcurrent. For output/voltage information see the OP of this thread: http://budgetlightforum.com/node/63255 . The KW CULNM1.TG is the last one discussed in the OP, you need some scrolling.
Scallywag
Scallywag's picture
Wow!! good god!! dethroned , its been lane waste, thank you so much for answering I have spent days reading posts and asking questions on CPF all to no avail first post I make on here an i have an answer , so the Osram KW CULNM1.TG is now the king for a super tightly focused thrower presumably the 1mm version? do you still dedome them or jut buy the flat version? Been looking to upgrade a nigthmaster Xsearcher with a new driver/emitter combo & crelant 7g5cs this should be just the ticket
First... I like to think of this forum as a bit more helpful than the other forum Wink Thumbs Up
The White Flats are already domeless (or "flat-dome"?). The CULNM1.TG is a 1mm2 version with 4040 footprint, but is already discontinued by Osram. Led4Power got a limited quantity but it currently says only two remain. However, it looks like the other two (CSLNM, 1mm2 on 3030 footprint, and CSLPM, 2mm2 on 3030 footprint) are still available, and they are nearly as good - still better than XP-G21. Do pay attention to the low Vf of these emitters and the recommended current to run them at - they turn angry blue on simple FET drivers with halfway decent cells.
1: This gets complicated with a Wavien Collar, as the XP-G2 gains more from collars than white flats.
The_Fat_Controller
It is A LOT more helpful, I have literally spent days trying to ascertain what the best possible upgrade i could drop into these units would be , wasted money on bad advice and was not really any closer to an answer , it seems most people like to just buy something off the shelf and hope the manufacturer tells the truth about its specifications and parts used.
The_Fat_Controller
Bit confused by these numbers
the XPGBWT-BE-0000-00L50 (2amp) lists
Minimum Luminous Flux (lm)
@ 350 mA = 180Lumen with a max current of 2000ma which is 5.7×350=2amps / 1026 lumens.
Looking at the chart above i have to run 6 amps into the KW CULNM1-TG to get 1023 lumens
What am i missing here?
djozz
djozz's picture
luminance, see your answered PM
The_Fat_Controller
Edit: (penny drops)
even if i only run 2 amps into the CULNM1-TG it will still give higher FC than the g2 because of that die size, its a have your cake and eat it situation and doesn’t have to come at the cost of run time….. I had it in my head i was going to have to Run 6amps into it to get the same performance as 2amps on S4 in reality for the same 2amps il get way more lux / fc I didnt realise the S4 was being over driven
Sorry guys im very new to this!
This forum Rocks!
trailhunter
Can xp-g3 be swapped to sst20 or nichia
Jerommel
Jerommel's picture
Last seen: 5 months 2 days ago
Yes, luckily they can.
Same footprint.
trailhunter
Jerommel wrote:
Yes, luckily they can. Same footprint.
Nice!
