Brinyte B158 mod – copper brass hybrid
20 posts / 0 new
Cula
Cula's picture
Last seen: 3 weeks 5 days ago
Well, this one was fighting me all the way trough the building process and it took almost two months to finish this project. Problems with driver, LED’s, focusing and almost anything that I laid my hands on. Never the less, when I look back, it was fun to customize this zoomie to my specs. Everything that was done is probably unnecessary and overkill but what can I do? I like my flashlights highly customized and built to my imaginary standards.
Few words about the problems that had to be solved:
1. Driver problem – I accidentally cut trace when removing it from the pill. If interested, there is more info in this thread – http://budgetlightforum.com/node/45639
2. LED’s – well known problem with new XP-G2 S4 2B, I never managed to get the old one. I have thrown away exactly three new XP-G2 S4 ordered from IOS, and six or seven XP-G2 S2 ordered from FT and Kaidomain all due to ugly color when dedomed, high VF and low throw in general. Finally I managed to pick a few “good ones” from Kaidomain (Triples in series on aluminum star) that showed good results.
3. Focusing – It was very hard to focus properly due to the changed pill dimensions (height of the pill). It was mainly trial and error kind of thing.
Let’s start!
1. Brinyte B158
2. Disassembled.
3. I don’t like forward clickie switches. Plan is to swap it with omten reverse clickie. It is going to be mounted on a new contact board.
4. Made a groove in the contact board to accommodate 20 AWG wire. Due to the height differences, new omten switch is raised by few millimeters with epoxy putty.
5. 20 AWG wire threaded trough the grove and spring.
6. Preparing for spring and brass lid bypass.
7. Copper top added. Just a small amount of solder is needed to finish the bypass.
8. Switch mode done. Cleaned and polished.
9. Pill is cut. There is no turning back now.
10. Copper cylinders cut and trimmed to fit inside the brass cylinder.
11. Tight fit.
12. Soldered. Time to do some cleaning.
13. Copper brass ring cleaned and polished. Preparing the base, three 1 millimeter copper circles soldered together.
14. Ring and base joined.
15. Another look.
16. Pill cut and trimmed to fit inside the body. Maxtoch 32mm was almost the perfect fit. No problem there.
17. Perfect fit for both pill and MCPCB.
18. Repaired FET driver, finished hybrid pill and dedomed XP-G2 S2 1A led.
19. Preparing the 20 AWG wires. They are going to be connected to small copper plates and everything should stay below the led.
20. Wires soldered.
21. Top view.
22. Bottom view.
23. Assembly day. MCPCB is mat painted with heat resistant paint (for ovens). MCPCB is going to be tightened with 2mm screws.
24. Polished copper pill in its place.
25. Almost done…
26. All wired.
27. Arctic MX-4 thermal paste is added and MCPCB is bolted down.
28. All done!
Also did some measurements:
XP-G2 S2 1A dedomed is pushed at 4.95A on high so it is a probably from some older batch with low VF.
270 Kcd at 5.3 meters after 30 sec.
Not to bad, I’m happy.
If you like my mod please comment. I’ll gladly answer any question.
Cheers!
Edited by: Cula on 02/12/2018 - 02:40
Sal415
Last seen: 1 week 4 days ago
All I can say is wow!!!
Ouchyfoot
Ouchyfoot's picture
Last seen: 6 months 1 week ago
Love the copper work. It makes me feels so satisfied.
tzmxxhh
Last seen: 25 min 26 sec ago
amazing work!
Hoop
Hoop's picture
Last seen: 2 months 4 days ago
Excellent job all around! I especially like the switch work.
M4D M4X
M4D M4X's picture
Last seen: 1 hour 59 min ago
wow – nice job!
 all new deals are posted here:
deals.m4dm4x.com
ask MARTIN@M4DM4X.COM - i will try to save you money!
Rufusbduck
Rufusbduck's picture
Last seen: 1 year 6 months ago
Wonderful. I think I’m gonna hope that hoop makes some. I have other plans for the body of the light.
Scott
Dutcheee
Last seen: 9 hours 52 min ago
Very nice!
MRsDNF
MRsDNF's picture
Last seen: 11 hours 19 min ago
What a very nice mod. Love the way you ran the power leads for the led. Smile
LightRider
LightRider's picture
Last seen: 2 years 5 months ago
I’ve always wondered why they don’t make MCPCBs with recessed solder pads. It would make led focusing in reflector lights much easier. I may try your method sometime.
Cula
Cula's picture
Thank you guys for your comments Beer .
Attaching the wires like this didn’t improve the beam. It stayed pretty much the same. It was probably unnecessary but it surely looks neat. Black paint did some “cleaning” of the beam but only when white wall hunting. Artifacts are less visible.
Wish I could get my hands on some old XP-G2 S4’s. Like this it always feels like unfinished job.
Did try to make some beamshots last night but I failed miserably.
FmC
FmC's picture
Another nice piece of work, Cula. Beer
mhanlen
mhanlen's picture
This is awesome… The light really screams now.
ImA4Wheelr
Very nice build. Dig your style and problem solving. For builds where I plan on driving the emitter near it’s limits, I like to build pills similar to this one with higher melting temp silver bearing solder and then reflow the MCPCB to the pill with 60/40 or 63/37 solder. May I ask what was your source for the copper used for the top of the pill?
You may not have an old XP-G2 S4 right now, but something even better will eventually come out and you will have this great light waiting for it.
Cula
Cula's picture
Thanks FmC, glad you like it Beer
I fell in love in this flashlight after your review. It is a proper budget light, very well built and on top of all, a performer.
I got one big sheet of 1mm copper on the local scrapyard long time ago. I got lucky I guess. The seller didn’t know what it was, payed only few dollars for it. I bought it and it collected dust for a couple of years until I got myself into this hobby. Everything else on ebay (pipes, rods). It is very expensive so you have to choose carefully to buy exactly what you need.
KawiBoy1428
KawiBoy1428's picture
Last seen: 7 hours 9 min ago
Very cool. I like your ingenuity (seems there’s no problem you can’t solve, with an highly upgraded effectiveness) with the copper/brass pill and the mcpcb, brilliantly righteous!! Thumbs Up
KB1428 “Live Life WOT
djozz
djozz's picture
Last seen: 1 hour 46 min ago
An extremely nice build, perhaps not everything was necessary, but who cares with such beatiful work! Smile
ImA4Wheelr
Cula wrote:
ImA4Wheelr wrote:
Very nice build. Dig your style and problem solving. For builds where I plan on driving the emitter near it's limits, I like to build pills similar to this one with higher melting temp silver bearing solder and then reflow the MCPCB to the pill with 60/40 or 63/37 solder. May I ask what was your source for the copper used for the top of the pill? You may not have an old XP-G2 S4 right now, but something even better will eventually come out and you will have this great light waiting for it.
Was thinking your answer would be along those lines.  Saw that aged look in the pic before you lapped the top of the pill.  Really respect your resourcefulness.  My hat is off to you.
luminarium iaculator
luminarium iaculator's picture
Last seen: 2 days 12 hours ago
Sorry,
I did not seen this so far…
Very nice and beautiful(real beauty Wink ) but complicated and labor demanding mod.
Imho same could be achieved only via driver and emitter swapping with necessary generic style bypasses Smile
270kcd with old XP-G2 S2 1A is not something to be underestimated… Although you probably weren’t to lucky in pick.
You are modding artist.
Will you apply for 4th Annual Old-Lumens Scratch Build contest?
Boaz
Boaz's picture
Last seen: 3 hours 39 min ago
I want to pick you for my dodge ball team .
 beautiful mod and a nice walk thru
thanks
