Warsun X65 Discount code wanted
15 posts / 0 new
wishiwereaskibum
Last seen: 1 week 20 hours ago
I’ve been recommended to check out this light, am and looking for a code for this cheapie. Anyone offering up a code to Banggood or gearbest or any place else?
Thanks
WishIwereaSkibum
The Miller
The Miller's picture
Ah it is on M4DM4Xs list
Warsun X65 82e201 $13,50
Andrew2007
Andrew2007's picture
Last seen: 3 years 1 month ago
Freeme can also get discount codes, just sent a pm to ask.
http://budgetlightforum.com/node/42825
dropout
Last seen: 3 years 2 months ago
warsun x50 is the newer model of x65?
wishiwereaskibum
Is this a disable light, as in multiple modes, or is it simple off /on interface? It looks to be a simple off /on. Correct?
WishIwereaSkibum
The Miller
Idk about the X50 bit my X65 has high low blink (when watching the beam on a wall with camera: on high with li ion and alkaline there is no flicker to be seen the entire runtime. On low one cannot use it for film work because there is a very noticeable flicker in the can view.)
Flashy Mike
Flashy Mike's picture
Last seen: 9 min 52 sec ago
Yes. AFAIK the only difference is the LED: XM-L in X65 and XM-L2 in X50.
Same interface (high, low, strobe), pwm in low as well, not visible with bare eyes.
No mode memory.
Andrew2007
I’m sure my X50 has mode memory. Wink
Flashy Mike
Checked mine again. No memory, always starts in high after a few seconds off. Do I have to activate it?
Andrew2007
You’re correct, no mode memory. Just checked mine again and it always starts in the mode following the one you left it in. Facepalm
Low, strobe, high.
Flashy Mike
That would be “next mode” memory. But mine doesn’t even have this. I noticed that I have to leave the light off for quite some time (10 seconds or more) to get it started with default 1st mode (high), otherwise it goes to next mode.
The Miller
when it comes to
option A start in high
or
option B next mode memory
I very much prefer A
Andrew2007
Ahh, that’s my first with next mode memory.
It’s annoying as I always want it on high, I’ll replace the driver.
mapache
mapache's picture
Last seen: 5 months 2 days ago
A graphite pencil can sometimes remove next mode memory, just draw a thick line across the capacitor.
Flashy Mike
A next mode memory of max. 10 seconds is not really memory. I would rather say the capacitor for offtime measurement (if there is any) is way to big – what is probably compensated with the pencil line.
