Replace 20w halogen with LED
Hi all,
I am coming to the experts to ask which LED bulb would you use to replace these 20w halogens? As you can see from the pic, the fixtures have a Hi and Low setting. I would be okay if they could only go on high… Also, I have 1.4” to 1.8” of clearance. I have 2 fixtures with 3 bulbs and one fixture with 2 bulbs for a total of 8. So, which bulbs would you go with and why? I am okay with Amazon and Alibaba suggestions.
Thanks!
John
edit: sorry, dropbox pics have a magic way of rotating lately. The text says Order Code UCX3B/DW/120, 120VAC, 60Hz, 60W, Use 20W Max
I don’t know what bulb are those but I assume they are g9 bulbs?
http://www.aliexpress.com/item/2016-NEW-g9-led-5W-AC-220V-230V-240V-G9-lamp-Led-bulb-SMD-2835-LED/32583166949.html?s=p&spm=2114.01010208.6.8.BXOrWy
Can you post a picture of the bulb outside of the fixture? I need to see what type of base it has.
If it is a G9 there are a couple options at SuperBrightLeds:
https://www.superbrightleds.com/cat/jc-series-bulbs/filter/Base_Type,G9,1,4563:
Looking at the specs it looks like only one of them may fit.
They are based in Missouri and they ship out same day in most cases. I’ve ordered tons of stuff from them and the stuff is always high quality and exactly as specified.
Crap, the first one I looked up looked like mine, so I thought it was going to be a standard base. This looks to be a G8. I can confirm at home tonight if any of the bulbs still have lettering.
It is a Feit G8 120v 20W.
I decided to go nuts and buy 3 cheap lights from Aliexpress just to see how they turn out. I have seen lots of complaints of something similar to pwm on Amazon reviews. Not sure if any 120v led will do anything different there.
I am still interested in any input from the experts here.
dice roll 1 7W,80 leds
dice roll 2 3W, 80leds
dice roll 3 5W, 64 leds
yes, it is a G8 bulb.
Thanks. Does your company offer G8s?
