[Review] Manker E11 XP-L AA/14500
157 posts / 0 new
Aggressor
Last seen: 1 year 8 months ago
In this image Klarus Mi7 looks so much better than Manker E11. How come the difference is so dramatic? I like the looks of Manker E11 much better, but Klarus Mi7 seems to be a better light and much cheaper too (in real life, not MSRP).
Update:
Here is the same Klarus Mi7 review by kj75, where the animated gif comparison comes from, this time in English.
Budda
Budda's picture
Kusie wrote:
Graphs and pure lumen numbers are not everything Wink
100% agreed.
UI, design, beam type, size, weight, price… all factor that should also be taken in consideration.
All my reviews, in italian and english, here: Lumenreviews.com
Stevedog
Stevedog's picture
Last seen: 2 years 9 months ago
Kusie wrote:
Graphs and pure lumen numbers are not everything Wink Check THIS direct comparison GIF between E11 and MI7 on High with 14500 from the german TLF forum (from user kj75) For me the “winner” is clear, much better EDC capabilities because of much broader spill. YMMV! K.
I have both lights, and the differences between mine aren’t nearly as profound. In fact my Klarus is less flood.. due to it’s tighter hot spot it seems a bit brighter.
Budda
Budda's picture
how about a comparative beamshot
Budda
Budda's picture
WalkIntoTheLight wrote:
I have to wonder if the camera’s ISO, aperture, and shutter speed was fixed.
Not only those parameter but also the focusiong: matrix, spot, weighted average…
I can assure you it makes a lot of difference for a thrower and a flood light.
Firelight2
Firelight2's picture
Last seen: 2 hours 53 min ago
Mostly finished modding this light over the weekend.
Initially I tried an XPL HI reflowed onto the stock star. This took just 10 minutes and made for a nicer tint and throwier beam.
Then I tried upgrading the driver to a 17mm FET driver with moppydrv.
Installing a new microswitch was a pain. The rubber post from the button boot is at the very back of the driver compartment. Not centered like in other lights I own. This works fine if your microswitch is a side-mount SMD switch. Not so great if all you had on-hand is surface-mount switches designed to mount upright.
I also found installing the switch inside in the right position was awkward simply because the light is smaller than other side e-switches I’ve worked with.
  • Attempt 1: Made a small frame for the switch and tried to wedge it in place with longer wires going back to the driver board. — Failed.
  • Attempt 2: Made a circular frame for the switch and pressed it into place. Once in position, the driver board is then pressed in place. Thin wires connect the e-switch to the driver board with glue around the solder joins to help protect the wires when folding into position. — Failed
  • Attempt 3: Made a u-shaped frame for the switch and pressed it into place. Similar to attempt 2. Double-checked all solder joints and replaced driver wires. — Failed. Switch wires or solder joins kept breaking.
  • Attempt 4: Same as attempt 3, but glued the switch into position before mounting so I could be sure it would actually click. Then folding wires and pressed driver into place. — Failed.
  • Attempt 5: Glued the u-shaped frame to the back of the driver with arctic alumina. While the glue was curing I held the driver together with the stock driver to eyeball the correct position for the switch. This seemed promising. No more broken switch wires. However, results were intermittent. Finally, I installed flexible wires to connect the switch to the driver board, to counter the small amount of flex during installation and when switch is pressed. SUCCESS! Finally.
After that I replaced the stock aluminum star with a Sinkpad. Had to Dremel the Sinkpad to fit. Replaced emitter with a fresh 4000K XPL HI 5A2 tint. Overall, I’m quite pleased with how it came out. At max power this light is VERY bright…. easily over 1000 lumens on a fresh Efest purple. However, parts of the head get too hot to comfortably touch in 30 seconds or so. Not much heatsinking in this tiny little light. I set the turbo timer at 25 seconds.
Not sure if I’ll solder-braid the tailcap spring or not. This light probably doesn’t need it.
Budda
Budda's picture
Last night I changed the stock emitter with an 3000K 80CRI one…
and this happened!
cdjaney
cdjaney's picture
Last seen: 7 months 1 week ago
and this happened!
Forgive the ignorance…but WHAT happened? I see two E11 variants at $30….is that a new price or is the 3D a new tint? Orrrrrrrrrr………did a hyperlink just automatically get added to your post because you changed out your emitter in the E11? Wink
John 1:5 "The Light shines in the darkness, and the darkness did not comprehend it."
Streamer
Streamer's picture
I’m guessing he put in a 3K and Tint was Toooooo.. yellow…and now E11 is offered in 5K 3D nice neutral tint ????
Kusie
Kusie's picture
Last seen: 10 months 3 weeks ago
It was available in two tints (NW and CW) right from the start … don´t get his post either… Question
Aggressor
I think he means Manker E11 became available at GearBest, something we thought isn’t going to happen.
Aggressor
Which 14500 battery would you recommend for Manker E11?
Will Sanyo UR14500P (800 mAh) work?
Aggressor
Just ordered Manker E11.
Which 14500 to order for it, flat top or button top (both unprotected)?
Stereodude
Last seen: 6 months 6 days ago
Yeah, but it’s the same price, so…
Stereodude
In your beamshot the E11 looks to have wider spill than the Mi7, but this one says something totally different.
They both can’t be right…
WalkIntoTheLight
Last seen: 4 months 4 days ago
The last picture (gif) is obviously crap or faked. The camera was likely set to auto-exposure, and the exposure time or other settings are completely different between the two images.
I completely disregard that gif image, unless the settings are detailed in full. Don’t believe it. And given that the photographer doesn’t know how to operate a camera, I wouldn’t be surprised if he also doesn’t know how to set the flashlights to max.
Aggressor
Actually in that comparative beemshot the spill of Mi7 is wider, just like in the gif.
WalkIntoTheLight
It sure looks to me like the E11 is wider in the beamshot.
Anyway, my point was that nothing in the gif can be believed, without seeing the exif data from the image (and believing that the photographer isn’t faking something else, which I’m not even sure of, given the more believable beamshot comparison picture).
Aggressor
That gif is from review done by kj75, who does a lot of very competent reviews. There is always a possibility of mistake of course, but faking is definitely out of the question in this case.
Stereodude
Actually, he might be right. After looking closer it looks like it has a faint wide spill in the middle you can barely see in the picture.
Aggressor
WalkIntoTheLight
Well, maybe he knows his flashlights. But it doesn’t appear he knows how to use the manual settings on his camera.
I suppose it’s possible he got a bum E11 light, or a bum battery. But given the huge difference in his gif, compared to side-by-side beamshots, I think he left the camera on auto. Or perhaps he let the camera blow out some of the highlights or something. Anyway, something is definitely off about it.
Witterings
Can anyone who has the 2 lights comment on the difference in throw between them ….. I would have thought the Mi7 with the XP-L Hi would have a tighter hotspot and longer throw but I know that’s not the only contributing factor …. mainly interested in if one has a much better throw than the other???
Aggressor
I agree something looks very odd about this image, but the spill of Mi7 is wider on the beamshot comparison image also, so that itself is not the problem.
He says all camera settings are always on manual and always the same for every review. He also says the two images were shot one after another both with fresh batteries.
WalkIntoTheLight
Okay, looking at the beamshots again, yes, I agree the Mi7 spill is wider, however it is very faint.
In any case, I think the gif images are very misleading. They imply the Mi7 is far brighter than the E11, which just isn’t the case. If he really did keep all the camera’s settings the same, then the scene topography is misleading the viewer. i.e., the scene is chosen to give a bonus to a light with a large, faint, spill.
Aggressor
I just thought about something else. What is the distance between camera and the flashlight mount? If it isn’t negligible, that would explain why flashlight with wider spill looks so much better in the image.
WalkIntoTheLight
Good point. Also, you can tell by the shadows that the flashlight mounting point isn’t fixed.
agent80
Last seen: 11 hours 5 min ago
Does this mean the E11 is brighter than the Mi7 on AA?
Aggressor
On AA (Eneloop Pro) batteries, E11 produces about 300 lumens for 60 minutes, while Mi7 produces about 160 lumens for 80 minutes. For the first 2-3 minutes E11 even produces 400 lumens.
Budda
Budda's picture
Stereodude wrote:
In your beamshot the E11 looks to have wider spill than the Mi7, but this one says something totally different. They both can’t be right…
I am a terrible photographer, and so I set all the parameters as indicated in the pics.
I can barely answer for my pics, can’t make judgement from pics took from other people.
