UltraTac K18 Brass - Mods & Lighted Switch
16 posts / 0 new
CRX
CRX's picture
Last seen: 41 min 26 sec ago
Nichia 219C D320 5000K on Cu DTP MCPCB
Flat top cell compatible
Potted driver
Lighted low profile GITD switch 0.7ma drain
Tailstands
Magnetic tail
Lockout-able
Graphite aesthetics
Chemical patina
Max – 340lm
cd – 1140
Throw – 68m
Out the box
Cut off keyring attachment and applied graphite/ resin mix
Swapped emitter to Nichia 219c, upgraded wires, installed LED under switch and filed out retaining ring
Lighted switch operation
Thanks to member Saypat for gifting me this light. Thumbs Up
Edited by: CRX on 03/13/2017 - 02:19
giorgoskok
giorgoskok's picture
Last seen: 2 months 4 days ago
Very nice Crx! Way better than the stock now Wink
CRX
CRX's picture
Thanks Smile
djozz
djozz's picture
Last seen: 1 hour 5 min ago
Saw this one in the wdymd thread as well today, very nice mod!
MRsDNF
MRsDNF's picture
Last seen: 4 hours 7 min ago
Sweet. Very nice. Its unrecognizable from the original light. Thanks for making its own thread as well. Smile
CRX
CRX's picture
Thanks guys Thumbs Up
Woytas
Last seen: 1 year 4 months ago
Very nice one!
For me the tailstand is also very important. How did you cut the tail?
jdm
jdm's picture
Last seen: 3 years 3 months ago
 Very nice mod! Regarding the non-fitting positive driver contact: I had the same problem with mine, Efest 10440 just didn't make contact because of the driver retaining ring. I just put a blob of solder on the positive driver contact and then it worked.
Where did you get the neodymium magnets from?
Regards, jdm
CRX
CRX's picture
Woytas wrote:
Very nice one! For me the tailstand is also very important. How did you cut the tail?
Thanks. A junior hacksaw and file will do it no problem.
CRX
CRX's picture
jdm wrote:
 Very nice mod! Regarding the non-fitting positive driver contact: I had the same problem with mine, Efest 10440 just didn’t make contact because of the driver retaining ring. I just put a blob of solder on the positive driver contact and then it worked.
Thanks. I would usually solder a thin copper circle to the driver contact but i made the copper button disc as a temporary measure until i work up the courage to go for getting that retaining ring out, then i will dremmel the offending ledge away so the cell fit through it.
I use spider magnets in the UK
MG
Last seen: 5 months 4 days ago
Nice read. Great Pix!
CRX
CRX's picture
Cheers mate.
CRX
CRX's picture
OP updated with pill removal & emitter swap.
chinooker
chinooker's picture
Last seen: 9 hours 49 min ago
CRX
CRX's picture
But i don’t have any of them Silly
Handy to know though, thanks for pointing them out.
chinooker
chinooker's picture
and I didn’t want to spoil your fun Wink
