Test/Review of Xiaomi ZI5 1800mAh (White or Black)
8 posts / 0 new
HKJ
HKJ's picture
Last seen: 3 hours 9 min ago
DSC_5070
Official specifications:
  • Brand: XiaoMi
  • Battery Type: NiMH
  • Rechargeable: Yes
  • Protected: No
  • Capacity (mAh): 1900mAh
  • Practical Capacity (mAh): 1800mAh
  • Voltage(V): 1.2V
  • Charge Current: 550mA
  • Max. Discharge Current: 3600mA
  • Charging Time (h): 4h
  • Mercury Free: Yes
Xiaomi%20ZI5%201800mAh%20(White%20or%20Black)-info
Maximum temperature raise at different discharge currents: 1A:+1,1°C, 2A:+3,1°C, 3A:+5,4°C, 5A:+10,7°C, 7A:+15,7°C, 10A:+2,8°C
This is a Chinese brand of NiMH, a pack contains both white and black cells with the same specifications.
DSC_5069
DSC_5071 DSC_5072
DSC_5073
DSC_5074
DSC_5075
Xiaomi%20ZI5%201800mAh%20(White%20or%20Black)-Capacity
The discharge curves for the two cells tracks very nicely. The capacity varies significantly with load.
Xiaomi%20ZI5%201800mAh%20(White%20or%20Black)-CapacityTime
Xiaomi%20ZI5%201800mAh%20(White%20or%20Black)-CapacityTimeHours
Xiaomi%20ZI5%201800mAh%20(White%20or%20Black)-Energy
Xiaomi%20ZI5%201800mAh%20(White%20or%20Black)-PowerLoadTime
Xiaomi%20ZI5%201800mAh%20(White%20or%20Black)-CurrentTest
Xiaomi%20ZI5%201800mAh%20(White%20or%20Black)-Charge
Conclusion
The cells looks good, they easily deliver the rated capacity, but has a problem at very high current.
Notes and links
The batteries was supplied by Gearbest for a review.
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
fran82
Last seen: 1 week 6 days ago
Some store claims “manufactured by famous japan company”.. (or similar)
Are they rebadged eneloops??? The venting holes seems similar…
This post/thread "may" contain referrals, a little contribution I "earn" in form of points ONLY if you buy the item. The purpose is to redeem items using the points and then making reviews of them in the forums to shar
Techno
These are made in China Wuxi. Not Japan FDK Eneloop.
Liber8
I don’t think so. None of my eneloops have venting holes. And I think the eneloops tested better at high discharge rates.
fran82
Ok… Too good to be true.
Eneloop is the way to go
Honeyclover
Last seen: 11 months 1 week ago
Panasonic
Xiaomi ZMI ZI5 1800mAh (White or Black)
While comparing between
GP ReCyko+ 2 AA 2000mAh ard SGD $4.50 ea,
ZI5 1800mAh ard SGD $2.50 ea, and
Eneloop 2000 mAh Made in Japan White SGD $5 ea.
Which is more worth it?
While comparing, I came across this Panasonic rechargeable battery from the same factory as ZI5.
Is ZI5 consider a made in china Eneloop? or just ‘Panasonic’?
If you have the above 3 choices, what will you get?
d_t_a
Last seen: 2 hours 26 min ago
These are Low-Self-Discharge NiMh right?
Honeyclover
Yes, GP ReCyko+ Manufacturer claimed 1,000 times.
ZMI ZI5 1,500 times, 1 year later 80%
Panasonic 1,500 times, 1 yr later 80%
Eneloop 2,100 times, 2 yrs later 90%
