Vollsion SP-11S Mods
9 posts / 0 new
CRX
CRX's picture
Last seen: 9 min 14 sec ago
XP-L HD V6 2C on 10mm sinkpad
Momentary magnetic tail switch/ Twisty
Brass tube lined
11mm FET driver
4A max current
Max – 820lm
cd – 1800
Throw – 85m
Installed XP-L HD 2c emitter, Sinkpad & 22AWG wires
Changed the driver to an 11mm FET
Installed tail momentary switch with glow ring and magnet.
Momentary or Twisty on.
Edited by: CRX on 03/09/2017 - 06:20
MRsDNF
MRsDNF's picture
Last seen: 21 hours 22 min ago
Nice mod CRX. Its good to see you took the initiative in modding this light instead of the other option. Thumbs Up
CRX
CRX's picture
Thanks mate.
Ouchyfoot
Ouchyfoot's picture
Last seen: 3 weeks 1 day ago
Nice little mod. All those inner and outer hi-lo rings still have me confused.
It makes me want to dig out my box of 10440 lights to see if any of them want some special attention.
CRX
CRX's picture
Do it! Wink
-X3-
-X3-'s picture
Last seen: 1 day 6 hours ago
Nice upgrade once again !
how do you manage to use an e-switch in the tail of such a tiny host ?
Did you run a wire from tail to head ?
Also, really nice finish of the button !
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
CRX
CRX's picture
Thanks mate, should have taken pictures, it’s not an e-switch, just a momentary contact switch.
I removed one pad from the switch board bottom and connected that directly to the light body by soldering on a piece of copper on top of the switch and press fitting it in, the other pad on the switch bottom has a spring soldered on, so pushing the cell towards the head. Just in front of the switch board is a press fit copper ring so when the head is screwed down the battery makes contact but is otherwise kept clear by the spring pressure. Hope that makes sense Smile
These are just stock photos but might help give an idea
-X3-
-X3-'s picture
Wow, and can it handle the current ?
SUch tiny switch are usually rated at a hundred mA max
CRX
CRX's picture
Yeah i did consider that but thought i would try it and see how long it lasts, it might need changed to one of my more robust mechanical versions, will report if it goes Wink
