This is the official sales thread from this feeler.
Specs:
Convoy S2+ 18350 host
Cree XPG3 S5 LED in 2C, or 3A tint on copper MCPCB
Mosfet linear driver with DrJones Guppy2drv
Optional parts:
AR coated lens
Snap on Pocket clip
These will be assembled and ship from the USA, and will carry the Adventure Sport Flashlights warranty. 100% premium components will be used in the build of each light. They will be individually tested before shipment.
Full disclosure: The only thing I can find that is anything less than what should be expected in a much higher price light is this. Because the emitter hole is for XML and I am using the XPG size butterfly insulator the reflector does not always center perfectly around the emitter.
The beam is not hindered by this. The Cree XPG3 still produces a very nice hot spot with bright soft spill.
Cost for the optional parts is listed next to them.
Please post your items ordered here as well, for the public record.
Hello everyone, is there much difference at all in the 3a vs 2c tints? They are very close to each other on the tint scale. Since I’m red/green colorblind I usually go for the cooler tints, but I can perceive the difference in way cool vs way warm, but not so much in the neutral areas of tint. I guess I just want the brightest of the 2? Any help would be appreciated. TIA
Both emitters are the same output bin S5. As far as a visual difference I think most often the eye “perceives” cooler tints as being brighter so the 2C may give you a bit of an edge. My 2 cents.
