Introducing Brinyte USB direct charging 18650 lithium battery
Hey,fellows. I’m pleasure to present our newest Accessories : Brinyte USB 18650 battery.
No matter in traveling or in daily life, people is inseparable from electronic products, such like mobile PC, Pad, Power bank, camera, MP3….
With taking these electronic with you, we should take many accessories.
At least, chargers is necessary.
Without any charger, will you hangout two days?
I guess few people will answer this question without hesitation.
Many people will feel annoy to think to have to take so many chargers with.
Now, Brinyte new released patent micro USB charging battery can solve charger problem. One USB cable can make battery charged.
1.Brinyte direct charging lithium batteries 18650 is a tradition-based lithium-ion rechargeable battery upgrade products, with imported Panasonic 3400mah capacity cell.
The battery adopted innovation USB direct charging technology.
You only need one micro USB cable for it.
The battery is compatible to mobile charger, power bank or computer interface.
It is 4 hours that battery fully charged. This makes charging easier and more convenient.
Of course, this USB battery can be powered by charger.
2.Reliable and durable
The USB direct charging lithium batteries 18650 using imported Panasonic 3400mah large capacity cell, which makes charge and discharge cycles can reach 500 times at least.
It also adds a triple protected circuit board for Micro-USB charging interface. The battery provides anti-overcharge, over discharge and triple overheat protection functions.
3. Status indicator
In positive of USB 18650 lithium battery, there is a LED indicator with a two-color.
When using the Micro-USB interfaces for charging,red indicator turned on.
When its fully charged, the green indicator will on. Battery state ,safe and clear.
This bump design 18650 USB straight rechargeable battery length is 69mm, no difference with conventional 18650 lithium batteries.
No matter it is a flashlight, e-cigarette, or any other products, which use 18650 lithium battery, can be used in this USB Direct rechargeable battery.
Feel free to be charging!
Well, THIS is interesting. May I be the first to suggest that you send some samples to HKJ and have him test them? Strike that, let’s take up a collection and order some anonymously that get sent to HKJ for testing.
What supplier can we order these from? Expected price point? Details, we need Details!
One detail they do give is that they are 69mm long, too long for most lights :expressionless:
Cheers David
Real 3,400mAh?
This is a cool idea but it has a few draw backs. Keep it up and you can perfect the technology.
These Panasonic cells are already long now even longer! Some light wont fit them. These are also 20 grams heavier then stock ones.
Discharge amperage is low at 5 amps but more then acceptable.
These are NCR18650B?
Charge time should be closer to 5 hours if you are using CC/CV.
Price?
Charge current / amps?
Over-current protection (during discharge)?
This looks nice!
I travel a lot, so if they fit my favourite flashlights, I will buy some!
Thanks Brinyte for presenting this new cell.
This seems so much smarter done then that other 18650 with a USB connector build in.
Status LEDs a big plus
Panasonic 3400mAh cell a big plus
A bit shorter then a normal protected Panasonic 3400mAh a big plus
Extra circuit board protector a big plus
Also to be charged by normal charger a plus
I think it looks very nice.
So if charging is done right I can only see a very high price as con but we don’t know that.
Yes please send 1 or 2 to HJK for testing since we need some reliable test data on these!
The concept looks good to me, but why panasonic NCR18650B?
This is a very old cell with inferior capacity under load compared to the new generations cells Sanyo GA, LG MJ1, Samsung 35E, all these can handle higher currents than the NCR-B.
Brinyte, you can get your cells in the queue for review — send him some
Hello, Lazy-R-us. Thanks for your advice, we will think about it. The MRSP of one USB 18650 battery is about USD11.69 . Then, More quantity, lower price.
Thanks for you feedback,David. I will retell it to our engineers.
Yes,WWEFANS.
Hey,survival.Thanks for your reply. You have known it very well.
Hello,Halo.
Charging current: 800mah
Brinyte USB Direct-charging lithium battery adds a triple with Micro-USB charging interface protection circuit, so the battery also provides anti-overcharge, over discharge and overheat protection.
Thanks.
Hi, Dutcheee. Thanks for your interests. :beer:
Hey, Miller. Thanks and Don’t worry about the price. It may fluctuate according to the order quantity.
Hello, hank.You’re really warmhearted. Thanks very much.Many guys there advise it to me too.I will apply to my boss for the review and then contact with HJK.
Thanks for your reply,will34.I will retell your advise to our engineers.
Are you able to charge this battery in standard 18650 charger as well?
