Manker E14 Mods
58 posts / 0 new
Edness
Edness's picture
Last seen: 7 months 1 week ago
CRX wrote:
It’s a fairly simple swap, i think i just cut the nub off the rubber boot and used a slightly thinner washer.
Thanks for the tip. I was able to reuse the plastic washer and installed a forward clicky with spring bypassed. Much brighter!(and more useless as it heats up even quicker)
I was wondering if XP-L will fit under the optics? Or you think I should stick with XP-L HI?
CRX
CRX's picture
Last seen: 7 hours 56 sec ago
I was wondering the same, the new XP-L2’s might fit but i haven’t looked at it properly yet.
I did buy an extra optic so will probably install some higher powered emitters even if the optic needs modified a little Evil
Edness
Edness's picture
Hmm…Now I might wait until XP-L2’s available and wait for you to mod it first! Thumbs Up
I guess if they do come out with XP-L2 HI then it’s a no brainer for me. No need to worry about the optics dedoming the LEDs.
PowerRam
Last seen: 1 year 12 months ago
This has been my dream light for a while now and I finally got one! I’m following your lead on some of the mods I’m doing as well. I hope you don’t mind. Acouple questions though. How do you like the forward clicky with the way the modes are set up on this light, and WHERE CAN I GET A TAILCAP LIKE THAT!! HAHA. Sorry but you took what I thought was a work of art and turned it into an absolute masterpiece! I’m serious about the copper tail cap thoughlol. Is it a one off or something? great work man. my hat is off to you.
CRX
CRX's picture
Thanks friend, the tritium tailcap has a forward clicky in it and the 18500 tube has a reverse clicky.
I changed the driver to a MTN fet with guppydrv1 so it works nicely with either.
The 18500 tube I made from an 18650 extension tube, switch and copper wire.
SeniorXJ
Can you show us how you did the copper on the bottom and on the tail cap? I’d like to build one myself just like yours so any help would be highly appreciated!
Thanks
scrumpypaul
scrumpypaul's picture
Last seen: 3 weeks 18 hours ago
Ridiculously sexy
MascaratumB
MascaratumB's picture
Last seen: 59 min 41 sec ago
CRX,
The last picture (down-right)…was it there before? Silly
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
CRX
CRX's picture
Yes it was there, I just re-arranged stuff.
MascaratumB
Oops, I fail to remember that then, sorry Facepalm
Anyway, that “all black” version is quite nice Thumbs Up Smile
OL Contest 2019
GIVEAWAY: 1 / 2
SeniorXJ
Any chance on showing us how you did the copper rings & tailcap??
CRX
CRX's picture
Thanks
Persistent aren’t you Big Smile
I can’t show you, some experimentation is required on your part but I used an 18650 tube, cut some of the threads off to suit the cell and switch length then made up some copper circles of the correct size and soldered them.
I placed them on the end of the cut down tube with some JB weld and spacing them with 1mm o-rings , removed the o-rings once hardened, applied more JB weld and smoothed off.
Another smaller copper ring from 1mm wire for around the switch boot.
CRX
CRX's picture
Yeah that was done with cold bluing solution.
HONDARIDER
HONDARIDER's picture
Last seen: 3 days 16 hours ago
Can you provide a link to the 18500 tube you used? Anybody else familiar with it? I have a lot of 18500’s.
CRX
CRX's picture
pinkpanda3310
pinkpanda3310's picture
Last seen: 2 hours 18 sec ago
New tube and tail looks awesome Star
SeniorXJ
What model# clicky switch is the black one you upgraded to? Tks!
CRX
CRX's picture
SeniorXJ
CRX
CRX's picture
What model? You can usually fit these in lights with rubber boots that have a reverse clicky switch, it just requires a little work like cutting the nub off the boot, maybe a different washer and sometimes sanding down the retaining ring a little.
I put one in this S2+.
You just need to equalize the heights.
Umpi2000
Last seen: 22 min 31 sec ago
Hi CRX,
how many of the measurements can you give me of the copper head of the e14/s41? in the perfect world I’d love a CAD Wink
CRX
CRX's picture
Em, none Big Smile . I sold this light quite a while ago.
Maybe another owner could help you out.
Umpi2000
Thanks CRX
scintillator
Last seen: 16 min 19 sec ago
Hi all Just checked my E14 and found the same faults as CRX great to have this thread for reference.
My first time going this deep into a light and it is fun.
One novice question why did you switch the + and – leads?
Does that cause any problems if I reuse the stock driver and switch?
Thanks much.
CRX
CRX's picture
There was a huge uproar at the time about a safety issue with the positive MCPCB trace being on the outside, very close to the fixing screws so I turned the LEDs around on the pads and connected the wires correspondingly.
You wont have any problems using the original switch and driver as long as they are connected properly, ie you can’t just swap the wires, you would need to reflow the emitters with the same polarity.
scintillator
Thank you I understand now.
When I screwed the pcb down I cranked pretty hard on the screws and one of them shorted through the red paint and made smoke.
I checked and led`s still work so I need to insulate those screws or use plastic ones.
cheers
CRX
CRX's picture
Yeah, that was the problem. Really not good, if that had been the negative trace instead the light would have just come on in direct drive, single mode but instead with the trace the way it is it shorts the cell Facepalm
